US HTC t mobile G1 work in India? urgent help required guys please
prasad b
Feb 15, 2012, 8:29:53 AM via Website
HI GUYS
1. i recently purchased a HTC t MOBILE G1 android from EBAY India.
2. i have got got GPRS settings done on it, internet works fine.
3. How ever even after repeated attempts i am not being able to sign in to MARKET. so i did the following :_
- I called up Htc helpline India
- They told me to mail HTC in US ( as per the IMEI number the MOBILE SET is from US)
4. So friends , can anyone please help me and tell me how do i make it run in India & how do i sign in MARKET.
5. Also if i upgrade my phone to higher version can the problem be overcome?
help please
regards
Steven Blum
  • Forum posts: 882
Feb 15, 2012, 10:25:33 AM via Website
What, exactly, happens when you try to sign into Android Market using your Google account?
Android News I Android Apps I App Center
Christopher Silva
  • Forum posts: 189
Feb 15, 2012, 2:41:20 PM via Website
prasad b
HI GUYS
help please
regards
If you have a standard signal with your provider you are already ahead of the game. You may need to enter the APN of your provider. Or instal the Marketenabler.apk..
Have a look at the APN setting and make sure it is correct. Type in Google search Android G1 APN setting Europe or USA or wherever you are.
Try these settings
Menu
Settings
Wireless & Networks
Mobile Networks
Access Point Names
Create new one
more info
http://flattr.com/thing/13012/How-to-set-APN-settings-in-Android
Eric McBride
  • Forum posts: 1,781
Feb 15, 2012, 3:09:03 PM via Website
Christopher Silva
prasad b
HI GUYS
help please
regards
Try these settings
Menu
Settings
Wireless & Networks
Mobile Networks
Access Point Names
Create new one
more info
Great advice Chris. I had the same issue when I used to have the G1.
Let us know if you get it working!
shahnawaznail
Oct 7, 2012, 8:53:26 AM via Website
HI GUYS
help please
regards
Casper Young
  • Forum posts: 8
Oct 15, 2012, 5:46:49 PM via App
If I am correct, You cannot sign on to Google Market unless you have a Google+ account. Then you enable two step verification and are given a 16 letter password. Then you use that 16 letter password to sign in to your Google account, not your regular password!
