Hi Douglas. Thanks for all the help you are offering
I am running windows 7 on both my laptops.
I was just experimenting with Bluetooth connections when I connected (or tried to) my phone to the laptop. I was wondering whether |I could use Bluetooth to synchronise rather than a data cable. Later on I realised that the phone only charges when connected by cable so the Bluetooth connection to the laptop is not much use to me.
With the Tomtom I just wish to use the hands free capabilities.
The phone, as supplied, has very limited Bluetooth options. Can these be enhanced using an App?
On page 57 of the TT guide there is the following
Tips
• Make sure that you switch on Bluetooth® on your phone.
• Make sure that your phone is set to ‘discoverable’ or ‘visible to all’.
• You may have to enter the password ‘0000’ on your phone in order to connect
to your TomTom GO.
• Make your TomTom GO a trusted device
Tip 1 is easy to satisfy using the phone menu
Tip 2 is not so easy as it can be set to discoverable for only 120 seconds
It seems that i have to effectively pair it with the TT from scratch every time I use it.
— modified on Aug 19, 2010, 12:19:34 PM
