Do you want to live in a comfortable place? Do you want to get a notification when your newborn baby will cry? or Do you want to get a notification when someone entered your house without your permission?
if your answer is 'YES' then I am telling you that you will get all features in just a single app.Sound meter application is considering an artificially intelligent software that measures the intensity of sound and gives you a notification via email.
The only thing you need to do is to set the threshold level and whenever volume will be more or above from threshold it will automatically send you a notification via email.
KEY FEATURES
- Easy to use
- User-Friendly GUI
- Easily adjust the threshold level
- Uses The mike of the phone to detect sound
— modified on Feb 25, 2020, 12:25:44 PM
