I get screen message asking whether to allow/deny location info, but when I tap nothing happens
Darwinized
Nov 18, 2019, 7:42:42 PM via Website
I have an issue where websites generate the pop-up message:
"www.site.com" wants to use your device's location. Allow Block"
or
the popup asking whether to allow notifications or not
Problem is I cannot select either allow or deny. I tap, hold, double-tap - all manner of trying to select one or the other, but it's like the Allow / Block links/buttons are just text and have no function at all. In order to clear it, I hit the back button on my phone and no option is set.
I have cleared app data, browser cache, forced stop on the browser. Nothing works.
I visited a website and got the problematic popup. Then I downloaded the app for that same site and the popup works fine.
I use Chrome
Android version: 8.1.0
Android and all apps are up to date
LG screenshot
— modified on Nov 18, 2019, 7:54:19 PM
  • Forum posts: 1,011
Nov 19, 2019, 3:16:31 AM via Website
Strange. Try a scan with malwarebites.
Helpful?
Darwinized
Nov 19, 2019, 6:36:55 PM via Website
The Malwarebytes Scan is clean
Helpful?
James Watson
  • Forum posts: 1,605
Nov 20, 2019, 3:10:50 AM via Website
You can disable the "location tracking" and "desktop notifications" features in your Chrome browser's settings.
But after disabling these features, use the 'Manage exceptions' (if available) button to manually allow these features on the required websites as location tracking is required for any Maps website (like Google Maps) to get precise results.
Helpful?
