Hi I need your help!!!
Mellissa Izoka
  • Forum posts: 15
May 24, 2018, 9:23:33 AM via Website
Hello everybody. I am newbie in this forum. Can I ask for some help? Can anybody help me in my problem on my S7 Edge. Whenever I am opening an app, a pop up window is always appearing. It says "Play Store has stopped working". I tried few solutions like force stop google play store or disable it but it doesn't work. Advance thanks guysss....
AC&MM
  • Forum posts: 1,155
May 24, 2018, 11:47:52 AM via Website
Try a factory reset. If it doesn't work, you need to reinstall Stock ROM.
AC&MM
Galaxy J7 Pro
Moto X Force
Galaxy Tab S3
Helpful?
James Watson
  • Forum posts: 1,605
May 24, 2018, 3:18:32 PM via Website
It seems that your play store doesn't work properlly. Try to restore it by a factory resetting.
Helpful?
