- Forum posts: 1
May 7, 2018, 4:50:09 AM via Website
May 7, 2018 4:50:09 AM via Website
How do I find the low limit setting for the battery. Need to know when to recharge.
Regards Henry
Regards Henry
May 12, 2018, 6:51:37 PM via Website
May 12, 2018 6:51:37 PM via Website
Heinrich
To get your battery status displayed on your notification bar on the home screen.
Go to settings, tap on the battery icon.
There you will see a toggle to display battery status , toggle it on, and you should see it on the notification bar at the top of your home screen.
— modified on May 12, 2018, 6:56:52 PM
