- Forum posts: 4
Jan 12, 2018, 9:39:32 AM via Website
Jan 12, 2018 9:39:32 AM via Website
Hello. I probably corrupted some system files, because my device (lenovo P70) restarted automatically and now can't run. When I try to restart device it loads to pin-enter screen, then restarts in a minute or immediately, when I touch the screen. After this device loads bootloader - IMAGE: vgy.me/TJtRED.png - but I completely can't do anything with this screen, buttons doesn't work, and the arrow automatically jumps between options every 0,5s. If i unplug battery and restart - after 2/3 resets device turns back to this bootloader and nothing works.
I installed "Android Studio", Android SDK, I can run ADB, but my device can't be found via USB: IMAGE: vgy.me/IJqYrN.png
Also I downloaded USB driver (which should be installed, I used my device with USB before), but I don't know how/where can I install it: IMAGE: vgy.me/RCeZI8.png
So basically - I don't know how to reset my device, because it's suspended on bootloader.
I will be really thankful for any help. If I don't explained it enough, please tell me.
