Samsung Galaxy S5 — Help please
jojo Hamilton
Sep 30, 2017, 11:38:39 PM via Website
Are there any software updates for my s5 at all? I dont have a computer and phone gone all strange saying sorry phone not working when i receive calls i cant answer...laymans terms if poss please thank u x
James Watson
  • Forum posts: 1,604
Oct 1, 2017, 8:35:45 AM via Website
If your phone does not work properly and you could not fix the issue anyway, maybe you have to do a factory reset.
As for system updating, go to Settings > About > Check for system updating.
ajazgames
D. L.
  • Forum posts: 4
Oct 2, 2017, 5:17:49 AM via Website
Before you do anything as drastic as a factory reset, first, reboot the phone by turning it completely off. And then back on. Before that, though, open main settings app, find storage, and open that, then clear all apps cache.
Now, hold the power button down until a pop up screen shows 2 or 3 options, and tap the top one, "power off" let it completely go dark, wait 10 seconds or so, then push power button till screen lights, and let go. Phone should reboot at that point. Then test out your problem.
ajazgames
Rachael Alice
  • Forum posts: 162
Oct 2, 2017, 7:41:00 AM via Website
Just reboot/restart your phone once and then let me set all its setting and try to operate it. If still it doesn't work, backup your data, and do the factory reset.
https://play.google.com/store/apps/details?id=com.autostamper.datetimestampphoto&hl=en
ajazgames
ajazgames
  • Forum posts: 137
Oct 3, 2017, 7:17:25 AM via Website
no special softweres are available to clear it. you should clear by manual ...like the suggessiond given above
Alice Potter
  • Forum posts: 14
Oct 4, 2017, 9:32:20 AM via Website
Before you do a factory reset, you need to backup all data of your telephone.
Isabel Jason
Oct 5, 2017, 12:19:33 PM via Website
Hi Hamilton,
Most of the android phones works once when they have reboot. So, try to solve it once or twice by performing reboot on you device. It can be done By Long press your Power Button --> You will see power off, reboot, screen capture etc.
Select the reboot option and leave it to reboot itself.
Another scenario Phone Update also plays a scenario in which the android phones behave like u explained.
B4 Factory data Reset Try these once it would be helpful or else you will loose your valuable data.
— modified on Oct 6, 2017, 6:57:21 AM
