Gio
- Forum posts: 15
Aug 31, 2017, 7:13:51 PM via Website
Aug 31, 2017 7:13:51 PM via Website
Does anybody know if Whatsapp or Android will fix this common problem, this is a virus which will send messages to you (on your contact list) and then will attach a file to access your cam. It will then drain your battery.The only way to remove it is to do a factory reset.
Will Android do something to fix this ??
