Well, I'm not sure if such an algorithm is used anywhere, so my best guess would be that I won't find it online. I'm using OpenCV, that's where the Mat comes from. Although I do not think there is much optimisation to be done to the code itself, it must be something to do with Android Studio... Well, either way, here's the code (the website messed up the indentation):
public static Mat dissolve(Mat inputImage, final int checkLength, final int stepSize, int type)
// check input format
if(inputImage.channels() != 1)
throw new IllegalArgumentException("Input image must have one channel. Found: " + inputImage.channels());
// ensure the matrix is continuous.
if(!inputImage.isContinuous())
inputImage = Mem.add(inputImage.clone());
// get byte array
final byte[] dataIn = new byte[(int) inputImage.total()];
inputImage.get(0, 0, dataIn);
// create output array
final byte[] dataOut = new byte[dataIn.length];
// some value pre-calcs
final int imgCols = inputImage.cols();
final int yDelimiter = inputImage.rows() - checkLength;
final int xDelimiter = inputImage.cols() - checkLength;
// select an algorithm and process it
switch (type)
case TYPE_X: processTypeX(checkLength, stepSize, imgCols, xDelimiter, yDelimiter, dataIn, dataOut); break; // This is never called
case TYPE_L: processTypeL(checkLength, stepSize, imgCols, xDelimiter, yDelimiter, dataIn, dataOut); break; // This is always called
default: throw new IllegalArgumentException("type must be selected from the static options (which are int values 1 and 2). Found: " + type);
// return adjusted mat
Mat mat = inputImage.clone();
mat.put(0, 0, dataOut);
return mat;
private static void processTypeL(int checkLength, int stepSize, int imgCols, int xDelimiter, int yDelimiter, byte[] dataIn, byte[] dataOut)
for (int y = checkLength; y < yDelimiter; y++)
for (int x = checkLength; x < xDelimiter; x++)
boolean xOk = true;
boolean yOk = true;
// get left
int rowModifier = y * imgCols;
int maxX = x + rowModifier;
int minX = x - checkLength + rowModifier;
for (int xLoc = minX; xLoc < maxX; xLoc += stepSize)
if (dataIn[xLoc] == 0)
xOk = false;
break;
// get right
if (!xOk)
xOk = true; // if this one suceeds, that's fine
maxX = x + checkLength + rowModifier;
minX = x + rowModifier;
xOk = false;
break;
// only check the other axis if x is OK, because we need both
if (xOk)
// get top
int maxY = ((y + checkLength) * imgCols) + x;
int minY = (y * imgCols) + x;
int stepSizeMult = imgCols * stepSize;
for (int yLoc = minY; yLoc < maxY; yLoc += stepSizeMult)
if (dataIn[yLoc] == 0)
yOk = false;
break;
// get bottom
if (!yOk)
yOk = true;
maxY = (y * imgCols) + x;
minY = ((y - checkLength) * imgCols) + x;
yOk = false;
break;
dataOut[rowModifier + x] = (yOk && xOk ? (byte) -1 : (byte) 0);
And I think you got the country right
