- Forum posts: 2
Jan 18, 2017, 7:52:12 PM via Website
Jan 18, 2017 7:52:12 PM via Website
Samsung s7 edge screen keeps flashing every 30 seconds, if anyone has ideas on how to fix it would appreciate it, thanx
Jan 19, 2017, 4:57:04 AM via Website
Jan 19, 2017 4:57:04 AM via Website
Screen flickering issues can actually range from a minor app and firmware issue to a more complicated hardware problem.
Boot your S7 Edge in safe mode to temporarily disable all downloaded apps and third-party services and see if the problem still occurs.
Should the problem occur in safe mode, then it could be an issue with the new firmware or possibly a hardware problem. The next thing you have to do is try to delete the cache of the previous system.
At this point, if the problem remained, it could mean that it’s a serious firmware or hardware issue.
Backup the data on the phone and reset the phone to bring it back to its default settings.
Last solution: factory reset
Jan 19, 2017, 3:48:48 PM via Website
Jan 19, 2017 3:48:48 PM via Website
Thank you for your help Stephen, I really appreciate it and I will try those suggestions
Mar 27, 2017, 11:24:02 AM via Website
Mar 27, 2017 11:24:02 AM via Website
Put it into recovery mode and wipe the cache to have a check which may work for you.
