Samsung Galaxy S4 Active — Device Not recognizing SD card
Christine Day
  • Forum posts: 3
Nov 28, 2016, 12:39:25 AM via Website
My Galaxy S4 does not recognize my SD card nor does it show the option to mount/dismount, format. Does anyone have a solution to this issue? I have inserted a 32GB SD card.
lla dermis
  • Forum posts: 13
Nov 28, 2016, 7:44:55 PM via Website
Actions you can take:
Check your SD Card first if it's okay...
Check your phone with another SD card ...
If it's okay with 1 of them you will find your answer
but if your SD card is working with other device and your phone doesn't recognized your alternate SD card ... You should take your phone to the professional ...
Christine Day
Christine Day
  • Forum posts: 3
Nov 28, 2016, 9:15:32 PM via Website
Thanks, I appreciate your feedback & will try the solution you suggested.
Gordon Herd
Nov 29, 2016, 12:47:58 AM via Website
card is probably corrupted through not being ejected properly,try fixing it in windows pc/laptop.
Christine Day
Christine Day
  • Forum posts: 3
Nov 30, 2016, 10:01:44 AM via Website
I appreciate your suggestion however, my pc & laptop do not have the slots for this size card. I have a card reader but it also does not accommodate my card. Any further suggestions?
