Samsung Galaxy Note 2 — Help
Michelle Burk-Thomas
Nov 3, 2016, 3:42:55 AM via Website
I have a galaxy note 2. Only way it will stay on is if it's plugged in. It will say it is fully charged or less. Second I unplug it it shuts off no matter how long it charged? I tried the hard reset it stayed on to do that now it won't stay on even if plugged in. Wat do I do??
Bastian Siewers
  • Forum posts: 9,729
Nov 3, 2016, 10:02:47 AM via Website
Hi Michelle, welcome to AndroidPIT! :)
Have you tried a different battery?
If the phone was working while plugged in, it sounds like the battery was dead.
Liebe Grüße, Bastian
Die Regeln | Die Moderatoren und Admins | Screenshots richtig posten
James Watson
  • Forum posts: 770
Nov 3, 2016, 1:01:40 PM via Website
It's definitely the battery.
Spin the battery on a flat surface, if it spins then the battery is dead
Ready To Help You.
James Watson
Denial Carberry
  • Forum posts: 11
Nov 4, 2016, 10:57:01 AM via Website
Change your battery asap. Looks like it's the problem with you battery. However, how long are you using this Note 2?
James Watson
