- Forum posts: 4
Sep 12, 2016, 11:53:44 PM via Website
Sep 12, 2016 11:53:44 PM via Website
Hello, I recently launched a new Calculator on the play store.
It is simple and works like typical physical ones and it is AD-FREE. Also, it uses just a little memory (RAM) usage as it uses (<20 mb mainly) unlike other "popular" calculators that use 80+. It is stable and I have not encounter any crashes yet.
Also, it implements a history panel with any calculations you have made (calculations are stored after you press "=") and next to them there is the date you made them in order to be easier to remember what is for.
It has many customization options, from different thousands and decimal seperators and different languanges ( English, Italian, French, Spanish, Russian, Serbia, Croatian, Greek are supported for now ) to different themes to use. More themes and languanges will be added in the future.
It uses permissions only for analytics & stats and vibration for click effect.
Any feedback, review, downloads & rates () are much appreciated..!!
Link to playstore for screenshots and more information:
play.google.com/store/apps/details?id=com.tzegian.Calculator
