- Forum posts: 1
Apr 14, 2016, 2:18:20 PM via Website
Apr 14, 2016 2:18:20 PM via Website
am writing this message to complain about the latest Marshmallow release reached my note 5 , I did update my phone OTA and it was successfully installed, once I navigate the phone and the powr saving is always on I noticed the following proplems:
If you are connecting through the WiFi and use the default browser, you will find an issue as follow: try open the browser and close it using the back button then go back to browser icon and press on it the system will show you a message that no Internet connection or data connection even the WiFi is on and work fine
Samsung Snote sync, when the phone on save mode and try to sync my notes manually the system shows error in the sync : we have a proplem please try again later... when I turn the save mode off then everything works fine.
These are my issues a5bd look for a solution but keep in your mind that I did the following :
- Clear the cash from the startup screen.
- Reset network setting
- Restore factory reset
none of the above details worked with me, I would appreciate if there are fixes to what mentioned above OR I would appreciate if you can provide resolution for the above issues.
