Samsung Galaxy Note Edge — Having problem with incoming calls
Sharad Isloor
Nov 10, 2015, 7:37:05 AM via Website
Hi All,
I am facing an issue with my Note 4 Edge. I purchased an unlocked note 4 edge from Verizon and am using an ATT SIM. I face a weird problem where incoming calls get attached with "+" symbol and then when I try to return the call it starts considering it to be an international call causing issues. This problem comes up randomly and goes away after some time. I am not able to isolate the issue whether any app is causing it or is it a misconfiguration.
Have any of you faced this problem and able to fix it . Pls Help
Regards
Sharad
James Watson
  • Forum posts: 1,605
Nov 10, 2015, 10:28:30 AM via Website
I think you may get contact with your carrier ATT. Maybe he/she will help you work around to the issue. Good luck to you.
