- Forum posts: 11
Aug 13, 2015, 11:32:50 AM via Website
Aug 13, 2015 11:32:50 AM via Website
Author: Apriorit (Device Team)
Permanent link: www(dot)apriorit(dot)com/our-company/dev-blog/130-development-for-android
In this article I’ve described:
• How to develop simple Java service for the Android Devices;
• How to communicate with a service from the other processes and a remote PC;
• How to install and start the service remotely from the PC.
1. Java Service Development for the Android Devices
Services are long running background processes provided by Android. They could be used for background tasks execution. Tasks can be different: background calculations, backup procedures, internet communications, etc. Services can be started on the system requests and they can communicate with other processes using the Android IPC channels technology. The Android system can control the service lifecycle depending on the client requests, memory and CPU usage. Note that the service has lower priority than any process which is visible for the user.
Let’s develop the simple example service. It will show scheduled and requested notifications to user. Service should be managed using the service request, communicated from the simple Android Activity and from the PC.
First we need to install and prepare environment:
• Download and install latest Android SDK from the official web site www(dot)developer(dot)android(dot)com);
• Download and install Eclipse IDE (www(dot)eclipse(dot)org/downloads/);
• Also we’ll need to install Android Development Tools (ADT) plug-in for Eclipse.
After the environment is prepared we can create Eclipse Android project. It will include sources, resources, generated files and the Android manifest.
1.1 Service class development
First of all we need to implement service class. It should be inherited from the android.app.Service (www(dot)developer(dot)android(dot)com/reference/android/app/Service.html) base class. Each service class must have the corresponding declaration in its package's manifest. Manifest declaration will be described later. Services, like the other application objects, run in the main thread of their hosting process. If you need to do some intensive work, you should do it in another thread.
In the service class we should implement abstract method onBind. Also we override some other methods:
onCreate(). It is called by the system when the service is created at the first time. Usually this method is used to initialize service resources. In our case the binder, task and timer objects are created. Also notification is send to the user and to the system log:
01.public void onCreate()
02.{
03. super.onCreate();
04. Log.d(LOG_TAG, "Creating service");
05. showNotification("Creating NotifyService");
06.
07. binder = new NotifyServiceBinder(handler, notificator);
08. task = new NotifyTask(handler, notificator);
09. timer = new Timer();
10.}
onStart(Intent intent, int startId). It is called by the system every time a client explicitly starts the service by calling startService(Intent), providing the arguments it requires and the unique integer token representing the start request. We can launch background threads, schedule tasks and perform other startup operations.
1.public void onStart(Intent intent, int startId)
2.{
3. super.onStart(intent, startId);
4. Log.d(LOG_TAG, "Starting service");
5. showNotification("Starting NotifyService");
6.
7. timer.scheduleAtFixedRate(task, Calendar.getInstance().getTime(), 30000);
8.}
onDestroy(). It is called by the system to notify a Service that it is no longer used and is being removed. Here we should perform all operations before service is stopped. In our case we will stop all scheduled timer tasks.
1.public void onDestroy()
2.{
3. super.onDestroy();
4. Log.d(LOG_TAG, "Stopping service");
5. showNotification("Stopping NotifyService");
6.
7. timer.cancel();
8.}
onBind(Intent intent). It will return the communication channel to the service. IBinder is the special base interface for a remotable object, the core part of a lightweight remote procedure call mechanism. This mechanism is designed for the high performance of in-process and cross-process calls. This interface describes the abstract protocol for interacting with a remotable object. The IBinder implementation will be described below.
1.public IBinder onBind(Intent intent)
2.{
3. Log.d(LOG_TAG, "Binding service");
4. return binder;
5.}
To send system log output we can use static methods of the android.util.Log class (www(dot)developer(dot)android.com/reference/android/util/Log.html). To browse system logs on PC you can use ADB utility command: adb logcat.
The notification feature is implemented in our service as the special runnable object. It could be used from the other threads and processes. The service class has method showNotification, which can display message to user using the Toast.makeText call. The runnable object also uses it:
01.public class NotificationRunnable implements Runnable
02.{
03. private String message = null;
04.
05. public void run()
06. {
07. if (null != message)
08. {
09. showNotification(message);
10. }
11. }
12.
13. public void setMessage(String message)
14. {
15. this.message = message;
16. }
17.}
Code will be executed in the service thread. To execute runnable method we can use the special object android.os.Handler. There are two main uses for the Handler: to schedule messages and runnables to be executed as some point in the future; and to place an action to be performed on a different thread than your own. Each Handler instance is associated with a single thread and that thread's message queue. To show notification we should set message and call post() method of the Handler’s object.
1.2 IPC Service
Each application runs in its own process. Sometimes you need to pass objects between processes and call some service methods. These operations can be performed using IPC. On the Android platform, one process can not normally access the memory of another process. So they have to decompose their objects into primitives that can be understood by the operating system , and "marshall" the object across that boundary for developer.
The AIDL IPC mechanism is used in Android devices. It is interface-based, similar to COM or Corba, but is lighter . It uses a proxy class to pass values between the client and the implementation.
AIDL (Android Interface Definition Language) is an IDL language used to generate code that enables two processes on an Android-powered device to communicate using IPC. If you have the code in one process (for example, in Activity) that needs to call methods of the object in another process (for example, Service), you can use AIDL to generate code to marshall the parameters.
Service interface example showed below supports only one sendNotification call:
1.interface INotifyService
2.{
3.void sendNotification(String message);
4.}
The IBinder interface for a remotable object is used by clients to perform IPC. Client can communicate with the service by calling Context’s bindService(). The IBinder implementation could be retrieved from the onBind method. The INotifyService interface implementation is based on the android.os.Binder class (www(dot)developer(dot)android(dot)com/reference/android/os/Binder.html):
01.public class NotifyServiceBinder extends Binder implements INotifyService
02.{
03. private Handler handler = null;
04. private NotificationRunnable notificator = null;
05.
06. public NotifyServiceBinder(Handler handler, NotificationRunnable notificator)
07. {
08. this.handler = handler;
09. this.notificator = notificator;
10. }
11.
12. public void sendNotification(String message)
13. {
14. if (null != notificator)
15. {
16. notificator.setMessage(message);
17. handler.post(notificator);
18. }
19. }
20.
21. public IBinder asBinder()
22. {
23. return this;
24. }
25.}
As it was described above, the notifications could be send using the Handler object’s post() method call. The NotificaionRunnable object is passed as the method’s parameter.
On the client side we can request IBinder object and work with it as with the INotifyService interface. To connect to the service the android.content.ServiceConnection interface implementation can be used. Two methods should be defined: onServiceConnected, onServiceDisconnected:
01.ServiceConnection conn = null;
02.…
03.conn = new ServiceConnection()
04.{
05. public void onServiceConnected(ComponentName name, IBinder service)
06. {
07. Log.d("NotifyTest", "onServiceConnected");
08. INotifyService s = (INotifyService) service;
09. try
10. {
11. s.sendNotification("Hello");
12. }
13. catch (RemoteException ex)
14. {
15. Log.d("NotifyTest", "Cannot send notification", ex);
16. }
17. }
18.
19. public void onServiceDisconnected(ComponentName name)
20. {
21. }
22.};
The bindService method can be called from the client Activity context to connect to the service:
1. Context.bindService(new Intent(this, NotifyService.class),
2.conn, Context.BIND_AUTO_CREATE);
The unbindService method can be called from the client Activity context to disconnect from the service:
1.Context.unbindService(conn);
1.3 Remote service control
Broadcasts are the way applications and system components can communicate. Also we can use broadcasts to control service from the PC. The messages are sent as Intents, and the system handles dispatching them, including starting receivers.
Intents can be broadcasted to BroadcastReceivers, allowing messaging between applications. By registering a BroadcastReceiver in application’s AndroidManifest.xml (using tag) you can have your application’s receiver class started and called whenever someone sends you a broadcast. Activity Manager uses the IntentFilters, applications register to figure out which program should be used for a given broadcast.
Let’s develop the receiver that will start and stop notify service on request. The base class android.content.BroadcastReceiver should be used for these purposes (www(dot)developer(dot)android.com/reference/android/content/BroadcastReceiver.html):
01.public class ServiceBroadcastReceiver extends BroadcastReceiver
02.{
03.…
04. private static String START_ACTION = "NotifyServiceStart";
05. private static String STOP_ACTION = "NotifyServiceStop";
06.…
07. public void onReceive(Context context, Intent intent)
08. {
09. …
10. String action = intent.getAction();
11. if (START_ACTION.equalsIgnoreCase(action))
12. {
13. context.startService(new Intent(context, NotifyService.class));
14. }
15. else if (STOP_ACTION.equalsIgnoreCase(action))
16. {
17. context.stopService(new Intent(context, NotifyService.class));
18. }
19.
20. }
21.}
To send broadcast from the client application we use the Context.sendBroadcast call. I will describe how to use receiver and send broadcasts from the PC in chapter 2.
1.4 Android Manifest
Every application must have an AndroidManifest.xml file in its root directory. The manifest contains essential information about the application to the Android system, the system must have this information before it can run any of the application's code. The core components of an application (its activities, services, and broadcast receivers) are activated by intents. An intent is a bundle of information (an Intent object) describing a desired action — including the data to be acted upon, the category of component that should perform the action, and other pertinent instructions. Android locates an appropriate component to respond to the intent, starts the new instance of the component if one is needed, and passes it to the Intent object.
We should describe 2 components for our service:
• NotifyService class is described in the tag. It will not start on intent. So the intent filtering is not needed.
• ServiceBroadcastReceived class is described in the tag. For the broadcast receiver the intent filter is used to select system events:
01.<application android:icon="@drawable/icon" android:label="@string/app_name">
02.…
03. <service android:enabled="true" android:name=".NotifyService"
04.android:exported="true">
05. </service>
06. <receiver android:name="ServiceBroadcastReceiver">
07. <intent-filter>
08. <action android:name="NotifyServiceStart"></action>
09. <action android:name="NotifyServiceStop"></action>
10. </intent-filter>
11. </receiver>
12.…
2. Java service remote installation and start
2.1 Service installation
Services like the other applications for the Android platform can be installed from the special package with the .apk extension. Android package contains all required binary files and the manifest.
Before installing the service from the PC we should enable the USB Debugging option in the device Settings-Applications-Development menu and then connect device to PC via the USB.
On the PC side we will use the ADB utility which is available in the Android SDK tools directory. The ADB utility supports several optional command-line arguments that provide powerful features, such as copying files to and from the device. The shell command-line argument lets you connect to the phone itself and issue rudimentary shell commands.
We will use several commands:
• Remote shell command execution: adb shell
• File send operation: adb push
• Package installation operation: adb install .apk
I’ll describe the package installation process in details. It consists of several steps which are performed by the ADB utility install command:
• First of all the .apk package file should be copied to the device. The ADB utility connects to the device and has limited “shell” user privileges. So almost all file system directories are write-protected for it. The /data/local/tmp directory is used as the temporary storage for package files. To copy package to the device use the command:
adb push NotifyService.apk /data/local/tmp
• Package installation. ADB utility uses special shell command to perform this operation. The “pm” (Package Manager?) utility is present on the Android devices. It supports several command line parameters which are described in the Appendix I. To install the package by yourself execute the remote shell command:
adb shell pm install /data/local/tmp/NotifyService.apk
• Cleanup. After the package is installed, ADB removes the temporary file stored in /data/local/tmp folder using the “rm” utility:
adb shell rm /data/local/tmp/NotifyService.apk.
• To uninstall package use the “pm” utility:
adb shell pm uninstall
2.2 Remote service control
To be able to start and stop the NotifyService from the PC we can use the “am” (Activity Manager?) utility which is present on the Android device. The command line parameters are described in the Appendix II. The “am” utility can send system broadcast intents. Our service has the broadcast receiver which will be launched by the system request.
To start NotifyService we can execute remote shell command:
adb shell am broadcast –a NotifyServiceStart
To stop the NotifyService we can execute remote shell command:
adb shell am broadcast –a NotifyServiceStop
Note, that the NotifyServiceStart and NotifyServiceStop intents were described in the manifest file inside the … tag. Other requests will not start the receiver.
Appendix I. PM Usage (from Android console)
01.pm [list|path|install|uninstall]
02.pm list packages [-f]
03.pm list permission-groups
04.pm list permissions [-g] [-f] [-d] [-u] [GROUP]
05.pm path PACKAGE
06.pm install [-l] [-r] PATH
07.pm uninstall [-k] PACKAGE
08.
09.The list packages command prints all packages.
10.Use the -f option to see their associated file.
11.The list permission-groups command prints all known permission groups.
12.The list permissions command prints all known permissions, optionally
13.only those in GROUP.
14.
15.Use the -g option to organize by group.
16.Use the -f option to print all information.
17.Use the -s option for a short summary.
18.Use the -d option to only list dangerous permissions.
19.Use the -u option to list only the permissions users will see.
20.
21.The path command prints the path to the .apk of a package.
22.
23.The install command installs a package to the system. Use the -l option to
24. install the package with FORWARD_LOCK. Use the -r option to reinstall an
25.exisiting app, keeping its data.
26.The uninstall command removes a package from the system. Use the -k option
27.to keep the data and cache directories around after the package removal.
Appendix II. AM Usage (from Android console)
01.am [start|broadcast|instrument]
02.am start -D INTENT
03.am broadcast INTENT
04.am instrument [-r] [-e <ARG_NAME> <ARG_VALUE>] [-p <PROF_FILE>] [-w] <COMPONENT>
05.
06.INTENT is described with:
07. [-a <ACTION>] [-d <DATA_URI>] [-t <MIME_TYPE>]
08. [-c <CATEGORY> [-c <CATEGORY>] ...]
09. [-e|--es <EXTRA_KEY> <EXTRA_STRING_VALUE> ...]
10. [--ez <EXTRA_KEY> <EXTRA_BOOLEAN_VALUE> ...]
11. [-e|--ei <EXTRA_KEY> <EXTRA_INT_VALUE> ...]
12. [-n <COMPONENT>] [-f <FLAGS>] [<URI>]
13.
14.<h2>
Sources of the Sample Project can be downloaded at the article official page www(dot)apriorit(dot)com/our-company/dev-blog/130-development-for-android
