- Forum posts: 18
Jul 30, 2018, 7:39:40 PM via Website
Jul 30, 2018 7:39:40 PM via Website
Hi.
I have code bellow. Please, would you tell me how to wait if I call getSpeechInput(); (bottom of the code) while TextView is filled and then call again getSpeechInput(). I tried Thread.sleep, but it doesn't work.
Thank you.
package com.example.oco.SpeechToText;
import androidx.appcompat.app.AppCompatActivity;
import androidx.core.util.Pools;
import android.content.Intent;
import android.os.Bundle;
import android.speech.RecognizerIntent;
import android.view.View;
import android.widget.TextView;
import android.widget.Toast;
import java.util.ArrayList;
import java.util.Locale;
import java.util.concurrent.SynchronousQueue;
import static java.lang.Thread.sleep;
public class MainActivity extends AppCompatActivity {
private TextView txvResult;
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
txvResult = (TextView) findViewById(R.id.txvResult);
public void getSpeechInput() {
Intent intent = new Intent(RecognizerIntent.ACTION_RECOGNIZE_SPEECH);
intent.putExtra(RecognizerIntent.EXTRA_LANGUAGE_MODEL, RecognizerIntent.LANGUAGE_MODEL_FREE_FORM);
intent.putExtra(RecognizerIntent.EXTRA_LANGUAGE, Locale.getDefault());
if (intent.resolveActivity(getPackageManager()) != null) {
startActivityForResult(intent, 10);
} else {
Toast.makeText(this, "Your Device Don't Support Speech Input", Toast.LENGTH_SHORT).show();
@Override
protected void onActivityResult(int requestCode, int resultCode, Intent data) {
super.onActivityResult(requestCode, resultCode, data);
switch (requestCode) {
case 10:
if (resultCode == RESULT_OK && data != null) {
ArrayList<String> result = data.getStringArrayListExtra(RecognizerIntent.EXTRA_RESULTS);
txvResult.setText(result.get(0));
break;
public void test(View view) throws InterruptedException {
getSpeechInput();
**Thread.sleep(10000);//Wait when first getSpeechInput is finished**
getSpeechInput();
— modified on Jul 30, 2018, 9:16:15 PM
