Google Pixel 6 smartphone (unlocked) for $599
“Waiting for network connection” even when connected
The notification is related to the Speech Services by Google (Play Store) which is used for text-to-speech features on the mobile OS in apps like Google Maps, voice calls, accessibility features, and other apps.
To fix the problem, you need to go through a few steps in Google’s app:
Voice services 01
Similar steps can be done in the “Digital Assist App” settings for Google Assistant / © NextPit Image source: NextPit
  1. With the Google app opened, tap on your profile picture and then select Settings.
  2. Tap on the Voice option.
  3. Select Offline speech recognition.
  4. Choose the AUTO-UPDATE tab.
  5. Tap on the Auto-update languages at any time option.
  6. Confirm that you are connected to a Wi-Fi network, then go back to the Installed tab.
  7. Tap on the language that is not updating, English (US) in this case.
  8. Press the UPDATE button.
Voice services 02
Hidden settings to fix the Speech Services Waiting for network connection notification / © NextPit Image source: NextPit
Restart your phone, and the notification should not come back. Important: remember to repeat the steps to select the Auto-update languages over Wi-Fi only option to avoid surprises with data charges on your phone’s bill.
Depending on your phone’s settings and system version, the same procedure can be done following one of these paths:
  • Settings > Google > Settings for Google Apps > Search, Assistant & Voice > Voice > Offline Speech Recognition
  • Settings > AppsDefault apps > Assist app > Cog/Gear icon > Offline Speech Recognition
Clearing the cache for Speech Services by Google
Another possible solution to this problem suggested in our comments section is to clear data for the Google Search and Speech Services by Google app, with varying results on our devices:
  1. Open the Settings app.
  2. Select Apps & notifications (or simply Apps).
  3. Tap on the See all apps option (or All)
  4. Scroll down and select Speech Services by Google.
  5. Tap on Storage / Cache.
  6. Tap on the Clear Cache option.
NextPit Speech Services Google Clear Cache
Clearing the cache is another option to remove the notification / © NextPit Image source: NextPit
Other solutions
Another option is to simply uninstall and reinstall the Speech Services by Google app from the Play Store. Remember that any settings related to text-to-speech services may be reset in the process.
One solution suggested in the comments is to simply disable the app’s notifications:
  • Open the Settings app.
  • Go to the Apps & notifications (or simply Apps) option.
  • Open the See all apps option.
  • Select Speech Services by Google.
  • Tap on Notifications.
  • Turn off the Notifications.
Google Speech Services disable notifications
The brute force way to solve the annoyance / © NextPit Image source: NextPit
Lastly, you can also disable or force stop the app from running. But that drastic measure also disables text-to-speech features in many popular apps, such as navigation, accessibility, and more.
What are the Speech Services by Google?
The Services triggering the notification are responsible for text-to-speech (TTS) and speech-to-text (STT) features on Android phones. They are used by many different apps for voice recognition to screen reading features, such as:
  • Voice searches on navigation apps, like Google Maps.
  • Phone call transcriptions.
  • Accessibility features for controlling the phone using voice commands.
  • Dictation apps.
  • Live translations.
To activate the features, you can go to Settings > System > Languages & input > Text-to-speech output.
Did you experience this strange notification on your phone? Which solution worked for you? Share your tips and experiences in the comments below!
Updated on March 7th: Added step-by-step instructions on how to brute-force disable notifications for the Speech Services by Google app.
