Previously, iOS allowed users to adjust the media volume directly from the lock screen while playing music or podcasts. However, this feature disappeared with the iOS 16 update. Now, two years later, Apple has quietly brought it back to iOS 18.2.
How to Enable Volume Control on the Lock Screen
By default, the volume control feature is turned off and hidden within the Accessibility settings, making it easy to miss for those who are not aware of the feature before. Follow these steps to enable it:
  1. Open Settings on your iPhone.
  2. Go to Accessibility.
  3. Select Audio & Visual.
  4. Toggle on Always Show Volume Control.
iOS 18 settings screen showing various options, with u0027Accessibilityu0027 highlighted.
Go to Accessibility section in the settings.
Quelle: nextpit
iOS 18 accessibility settings screen showing Audio u0026 Visual options highlighted.
Tap on Audio and Visual.
Quelle: nextpit
iPhone screen showing Accessibility settings for Audio u0026 Visual in iOS 18.
Quelle: nextpit
iPhone displaying a character with fireworks background, playing u0027Die With A Smileu0027 by Lady Gaga and Bruno Mars.
The lock screen without the volume control.
Quelle: nextpit
iPhone screen displaying the date and time with a music player for u0027Die With A Smileu0027 by Lady Gaga and Bruno Mars.
Once enabled, you can adjust the volume level via the slider or through the physical buttons.
Quelle: nextpit
How to Use the Volume Control on the Lock Screen
The updated volume control works with both the built-in speaker and Bluetooth-connected headphones. This also works depending on whether you’re playing a media or not.
  • Media Playback: The volume slider appears at the bottom of the media widget on the lock screen. Simply slide it left or right to adjust the volume.
  • System and Call Volume: The system volume slider appears on the left edge of the screen, aligned with the physical volume buttons.
iPhone screen displaying the time 10:52 and music controls for u0027BIRDS OF A FEATHERu0027 by Billie Eilish.
Volume control adjustment supports media playback.
Quelle: nextpit
iOS 18 interface showing a lock screen with time and date. Volume control icon highlighted.
If no media is played, volume control can still be accessed for the system or call volume.
Quelle: nextpit
Tips for Using Volume Control on the Lock Screen:
  • When media is playing, slide the media widget to adjust the volume.
  • Alternatively, use the physical volume buttons on the side of your iPhone.
  • During phone calls, adjust the volume using the physical buttons. A volume slider will appear on the screen for additional control.
Compatibility and Availability
The lock screen volume control feature is available on iPhones running iOS 18.2 or later. Unfortunately, older models like the iPhone X and iPhone 8, which were last updated to iOS 16, won’t be able to access this feature.
Have you updated your iPhone to iOS 18.2? What do you think of the return of the lock screen volume control? Share your thoughts in the comments!
