Previously, users could control their TVs by selecting the connected device within the SmartThings app and launching the Remote tool. Alternatively, the Quick Remote feature on the lock screen provided limited functionality and was restricted to basic shortcuts.
A Faster Way to Control Your Samsung TV
With the latest SmartThings update (as reported by Android Authority), Samsung now allows users to add a home screen widget for remote control.
The new widget, labeled Screen Remote, comes in a 4×2 rectangle layout. It includes essential controls for volume, channel selection, power, home, and mute, alongside a directional wheel for basic navigation.
Samsung SmartThings app interface showing controls for a living room TV.
Samsung’s SmartThings App adds a TV remote control widget. / © Android Authority, Edited by nextpit Image source: Android Authority, Edited by nextpit
However, this widget is limited to TVs or monitors designated as “Living Room TV” or “My TV.” It remains unclear if users can customize the widget to work with other devices in future updates.
SmartThings Remote Control Customization and Compatibility
Unlike the in-app remote control, the Screen Remote widget lacks customization options and there are no alternative widget sizes. Despite these limitations, the widget significantly improves usability by eliminating the need to launch the SmartThings app each time.
The widget is currently available for Samsung smart TVs and monitors manufactured in 2022 and later.
This feature was included in the December update for both Android and iOS versions of the SmartThings app. However, its rollout appears to be gradual, with availability varying by region.
Have you tried the remote control function in the SmartThings app on your Android or iPhone? Share your experience in the comments below!
