Virus need help
bionix
Jul 22, 2021, 5:50:38 PM via Website
Hey,guys as topic says my Huawei P10 lite is infected with malware.
Which remain after factory reset.
What to do ?
James Watson
  • Forum posts: 1,585
Jul 23, 2021, 3:05:06 AM via Website
In addition to 'Wipe data / factory reset', run 'Wipe cache partition'. (smug)
Download size < 0.15 MB. But also accurate enough, ad-free & free.
Blog: https://okblackcafe.blogspot.com Your 5-star is appreciated.
Helpful?
bionix
Jul 23, 2021, 1:15:43 PM via Website
James Watson
Does it will remove the virus?
I have not identified what exactly is the virus,but read in internet that i needed to flash/reinstall the firmware to remove it.
What you can suggest me to do guys?
Thanks.
Helpful?
