- 1 Xiaomi vacuum robots with wiping function in comparison
- 2 Table of contents
- 3 Xiaomi X10+: Top model with full features
- 4 Xiaomi X10: Robot vacuum cleaner with dust station
- 5 Xiaomi S10+: Robot vacuum cleaner with double wiping pads
- 6 Xiaomi S12: Robot vacuum cleaner with wiping plate
- 7 Xiaomi E12: Entry-level vacuuming robot
| All-round top model | Comfort vacuuming robot | All-rounder without station | Professional vacuum cleaner without station | Entry-level model | |
| Product |
Xiaomi X10+
Xiaomi S12
Xiaomi E12
| MSRP |
| Suction power |
| Wiping |
| Mapping / Navigation |
| Suction station |
| Dimensions |
| Deals |
The top model from this table was already introduced by Xiaomi in 2022—all other models then followed on May 22, 2023. The full range is only available with the top model Xiaomi X10+, which, by the way, is almost identical in construction to the excellent Dreame L10s Ultra NextPit reviewed.
Note: Already a big Chinese conglomerate, Xiaomi owns hundreds of smaller sub-brands, including (at least) two specialized in robovacs: Dreame (or Dreametech) and Roborock, besides other general brands including Mijia and Viomi (besides others). Some of the offers in this article will link to the same product from the sub-brand.
Table of contents
- Xiaomi X10+: Top model with full features
- Xiaomi X10: Robot vacuum cleaner with dust station
- Xiaomi S10+: Robot vacuum cleaner with double wiping pads
- Xiaomi S12: Robot vacuum cleaner with wiping pad
- Xiaomi E12: entry-level vacuuming robot
With the Xiaomi X10+, you don’t have to make any compromises when it comes to features. The top model introduced in 2022 has strong suction power and also wipes very thoroughly with two rotating wiping pads. The station automatically vacuums dust from the tank integrated into the robot vacuum and refills clean water for mopping. And best of all, the mop pads are rinsed and even blow-dried in the station after the cleaning process. However, so much convenience has its price, of course.
If wiping is not that important to you, then the Xiaomi X10 might be the right model for you. Instead of two rotating wiping pads like the X10+, there is only one vibrating wiping plate here. In terms of suction capabilities, however, the X10 has the full package. In addition to the 4,000 Pa suction power, there is also a suction station that empties the tank integrated into the robot vacuum after each cleaning process.
Admittedly, things now get a bit complicated in Xiaomi’s robot vacuum portfolio, starting with the S10+. This model does completely without the suction station, and instead, only a small charging station is included in the box. In return, the Xiaomi S10+ again offers the two rotating mops from the X10+, and its 3D camera on the front. Thus, the S10+ offers strong cleaning qualities, but you will always have to refill the water and empty the dust tank.
Unfortunately, Xiaomi’s nomenclature does not become more understandable with the next model. Namely, the S12 without Plus does without the rotating wiping pads again and instead pulls a wipe behind itself again—i.e. like the X10 without Plus. You also have to do without the 3D camera that is used for precise obstacle detection in the S12. Nevertheless, all models up to this point rely on the LiDAR scanner on the top, which is also good for precise navigation and mapping in the dark.
The last model sounds like a light bulb socket, but it is an entry-level vacuum robot. Probably the most important compromise with the E12 compared to all other models: It forgoes LiDAR navigation and relies instead on an optical system. If you only want the vacuum to work during the day and you do not have any extremely sensitive furniture, this should not be a big issue.
Besides that, the Xiaomi E12 offers the same 4,000 Pa suction power as all other Xiaomi vacuum robots, relies on a wiping plate like the S12, and of course, also does without a suction station.
- Looking for other models? Click here for NextPit’s robot vacuum best list!
- Want other comparisons? This is the robot vacuum lineup from Roborock
What do you think of Xiaomi/Dreametech’s robot vacuum lineup? Do you need a mopping function? And can you handle the confusing nomenclature? I’m looking forward to your comments! And of course, we’re eagerly awaiting robot vacuum test devices and will hopefully update this comparison with the test reports soon.
