Xposed and Lollipop: the modules that work on Android 5.1
AndroidPIT Moto X 2014 xposed framework
As many of you know, work on the Xposed Framework slowed down a little with the transition to Android Lollipop. While development continues on Xposed for Android 5.0, Android 5.1 is on the back burner until 5.0 becomes stable. Nevertheless, many of your favorite modules still work on Android 5.1 and we have the list for you here. See below for the Xposed modules that work on Android 5.1 Lollipop.
What happened to Xposed Framework on Lollipop?
In case you missed the back story, Xposed, the framework that allows you to perform minor tweaks in the Android system without needing to flash ROMs - because the changes are stored in memory - has slowed a bit since Lollipop was introduced.
This is because the original developer of Xposed, rovo89, encountered problems with some Lollipop features. Android Run Time (ART) caused issues , as did SELinux, making development more time consuming and complex. Devices running TouchWiz wouldn't work at all.
xposed teaser
Xposed modules still work on Android 5.1 - you just have to know which ones. / © ANDROIDPIT
While rovo89 is continuing to stabilize Xposed for Android 5.0, other devs have picked up where he left off and have been working on Android 5.1 and Android 5.1.1 with his permission. A couple of these developers, romracer and C3C076 in particular, have released modified versions of Xposed that will work on the latest version of Android, although not all modules work and TouchWiz devices continue to have issues.
How do I get Xposed Framework on Android 5.1?
If you want to make use of the modules listed below, be sure to visit the XDA Developers thread for romracer's alpha version or C3C076's alpha version. Read up on what's working, what's not and how to fix any bugs you might encounter.
You will then need to flash the Xposed Framework zip through recovery and get the Installer APK on your device. Make a full backup of your system before proceeding and turn off any currently installed modules before flashing the zip file.
AndroidPIT Galaxy S5 Lollipop KitKat
ART on Android Lollipop and TouchWiz have caused issues for Xposed Framework. / © ANDROIDPIT
The exact files you want will depend on the Android version you're running and which alpha version you want to use. Keep in mind that development continues daily; for example, the dev behind Gravity Box has already made some additional tweaks that return functionality to Greenify, Flat Style Colored Bars, Amplify and Gravity Box amongst others, so don't use this list as definitive. Take a look at the latest posts in the XDA thread, get flashing and let us know which modules you like best.
xposed teaser
Xposed continues to deliver awesome tweaks to Android. / © Xposed
3Dot Mod
ACDisplay
Advanced Power Menu
Amplify
Always Expandable
Android Theme Engine
App Settings
APV Youtube Module
Awesome Pop-up Video
Battery History XXL
Battery Stats Plus
Boot Manager
BouncyBox
BurnToast
Chrome New Tab
Chrome Selection Patch
Clarity
Coolify Flat
Copy Toast
Cracker
CrappaLinks
Deep Sleep Battery Saver
Disable Flag Secure
Disable SU Indicator
Email – Kill Attachment Limits
Enable Ambient Display
Enable Notification Ticker Lollipop
Enable SwiftKey Prediction On More Fields
Enhanced Toast
Exchange Bypass For Lollipop
Exchange Fake User Agent
Force FastScroll
Force Immersive Mode
Greenify
Gesture Navigation
GravityBox [LP]
Google Play Music Listen Later
Hide Network Indicators
Hide Traffic Indicators
Holo Themer
Hosts Enabler
HowGiveLoliButton
Immersive Mode Don’t Panic
Lolistat
Lollipop Power Menu
LPThemer
Maxlock
Minimum Brightness
MinMinGuard
Network Speed Indicator
Network Speed Monitor
Nexus Navbarz
NoMoreOverlay
Obb on SD
OGXposed
Overflow Mod
PerAppFonts
PerAppHacking
Play Music Downloaded Only Remover
Remove Battery Saver Warning Color
Restore Notification Ticker
Root Cloak
Screenshot Delay Remover
Screen Off/On
Smooth System Progress Bar
Songza Patcher
Spotify AVCRP
Swiftkey Goodness Mode
SwipeBack2
TableMetrics
Tinted Recent Panels
Unbeloved Hosts
Unicon
Unicon Beta
VolumeSteps+
Wear Messenger
WebView Google
Wi-Fi-Pwd
XHangouts
XLDrawer
Xposed Custom Error
Xposed TableMetrics Module v3.0
XposedUnifiedNlp
XSuite
XToast V 1.7
XuiMod
XUtilities
Youtube AdAway
VolumeSteps+
Thanks to Shawn Pfeiffer for bringing this list to my attention. An actively updated list of Xposed modules working on Android 5.1 and Android 5.1.1 can be found on XDA Developers.
Review: Google Pixel 7
Review: Google Pixel 6a
Go to comment (3)
Kris Carlon
Kris Carlon
3 comments
  • Ryan Fatalla 1
    Ryan Fatalla Sep 15, 2015 Link to comment
    Tested and they are working fine, but you forgot to mention XInternalSD, it's very essential
  • 12
    [Batiste4] Sep 1, 2015 Link to comment
    Thank you very much ! I searched this answer since 1h !
  • Junaid Q. 17
    Junaid Q. Jul 26, 2015 Link to comment
    Thanks Kris Carlon
