Choetech T513 S
In the medium term, Apple could try to establish wireless charging as a standard, and thus abolish the last physical interface. However, this step requires more courage than simply killing off the USB Type-C port.
ANDROIDPIT qi laden nachruesten 2
You can even retrofit for wireless charging. But for what purpose? / © NextPit
...in practice, it’s a flop.
Review: Apple iPhone 15 Pro
Go to comment (25)
Hans-Georg Kluge
Hans-Georg Kluge
25 comments
  • Alex Moroni 7
    Alex Moroni Mar 2, 2017 Link to comment
  • Natanael Bodanese 16
    Natanael Bodanese Mar 2, 2017 Link to comment
  • Michal Horna 14
    Michal Horna Feb 24, 2017 Link to comment
    No problems here
    remyj Feb 24, 2017 Link to comment
    My 2 cents
  • Shankar Prasad Nandi 18
    Shankar Prasad Nandi Feb 24, 2017 Link to comment
    Pankaj Saini Feb 23, 2017 Link to comment
    • 28
      itprolonden Feb 24, 2017 Link to comment
  • 12
    Deactivated Account Feb 23, 2017 Link to comment
    Pankaj Saini
  • Patrick Callaghan 11
    Patrick Callaghan Feb 23, 2017 Link to comment
    Ralf Fensch Feb 23, 2017 Link to comment
  • Mark G. 28
    Mark G. Feb 23, 2017 Link to comment
    Peace 🖖
  • 10
    David Turner Feb 23, 2017 Link to comment
    Maurice Feb 23, 2017 Link to comment
  • 31
      Biffstar1234 Feb 24, 2017 Link to comment
  • 46
    itprolondenShankar Prasad Nandi
    • 12
      Paul Cirrus Feb 23, 2017 Link to comment
      haha nice trick you got
  • 12
    itprolondenSheena F
    Shankar Prasad Nandi Feb 23, 2017 Link to comment
    The basic question is: What are the advantages of wireless charging? I can think of two. First, no repeated plugging and unplugging of the USB cable, which might damage the port. Second, the ability to charge the phone where it's not possible to keep it near the power supply. That is, if the power point is at a location in the room where it's not possible to attach your power cord and keep the phone, wireless charging comes in handy.
    Next, the refutation of these two advantages. From my experience, the USB port outlasts the mobile phone. The situation where your phone USB port is malfunctioning due to repeated plugging and unplugging of the power cord, yet your phone is functioning flawlessly, is rare. The solution to the second point, is to simply use a power bank where it is inconvenient to bring your mobile close to the power point.
    So, goodbye wireless charging. It's one of those important landmarks of technological innovation that prove ultimately useless yet serve to mark what aspects of our daily lives could REALLY be improved by technology.
    itprolondenDeactivated Account
    • 28
      Good post
  • 26
    Andrew Burgin Feb 23, 2017 Link to comment
    Its to slow for charging when we have fast charging on phones
    storm Feb 23, 2017 Link to comment
    It was never an important selling point or well implemented technology.
  • GrimJimCrowley 14
    GrimJimCrowley Feb 23, 2017 Link to comment
    I use my wireless charging on my S6 at work. It's a lot more convenient for me.
