Sushi Bike review: the flagship killer of the e-bike world
ANdroidPIT Sushi Bike Maki M2 bike
If you are looking for an e-bike these days, you probably have a fat wallet. Most e-bikes cost several thousand dollars, are networked, and packed with electronics. If you are just looking for an attractive e-bike without a lot of frills, you should definitely check out the Sushi Bikes. We tested the Maki M2 model for one week under the hardest physical use for you.
What does the Japanese food sushi have to do with an e-bike? Both don't really go together, do they? But at the same time, the name sticks in your head. If you then put the name Joko Winterscheidt (German actor and presenter) into the mix, you could think that such an e-bike is already in the upper league with VanMoof and Cowboy. Far from it, because the Sushi Bikes of Andy Weinzierl and his prominent investor do not cost a thousand bucks. More precisely, just €999.
sushi e bike
Andy Weinzierl could inspire Joko Winterscheidt with his Sushi Bike. / © Sushi
An e-bike for under $1,000? What can the Sushi Bike do?
The Sushi Bike is available in different variations, or should I not better say 'flavors'? The Makis come as classic men's bikes with a straight top tube and are available in three frame sizes (50, 55, or 60 cm). The three California versions with their curved top tube are more like the classic ladies' bikes and are available in only one frame size. All frames are made of aluminum, and the fork is made of steel and is unsprung. All in all, the Sushi bike weighs only 15 kilograms.
The bike is delivered without mudguards. / © NextPit
About taste, one can surely argue, so surely also about the look of the Sushi Bike. Personally I find the very clean and puristic look with the brown accents on the tires and grips of the handlebars very attractive. Even the removable battery mounted on the frame fits the Sushi Bike, because it looks like a drinks bottle. The motor in the rear wheel is also inconspicuous so that the Sushi Bike still looks like a conventional single-speed bike even at close distance.
ANdroidPIT Sushi Bike Maki M2 engine
Thanks to the mechanical Tektro disc brakes, the Sushi Bike decelerates very well. / © NextPit
Technology without frills
Most modern e-bikes can be unlocked, configured, and also located via a smartphone. But do you really need so much technology to complete your daily commuter route during the week? In my opinion, no, that's why the simple technology of the Sushi Bike is so good. It works completely without a smartphone because there is a small control unit attached to the handlebars with which you can control the motor. In total there are three levels of support, which can be easily selected via this control unit. Of course, you can also switch off the support completely and use the Sushi Maki M2 as a regular single-speed bike.
ANdroidPIT Sushi Bike Maki M2 throttle
The electric support of the Sushi Bike can be easily and effectively controlled via this unit. / © NextPit
The motor is powered by a removable battery. This battery has a capacity of 124 Wh and should guarantee a range between 30 and 60 kilometers. This is absolutely sufficient to cover a typical daily commuter distance. Should it not be enough, you can simply remove the 800-gram battery and fully charge it with the power supply unit within 3.5 hours. A practical feature of the battery is that it can also be used as a power bank for smartphones, tablets, or speakers. So nothing stands in the way of a small party or a romantic picnic in the park. Wow!
ANdroidPIT Sushi Bike Maki M2 powerbank
The battery of the Sushi Bike can also be used as a power bank. / © NextPit
If you buy a Sushi Bike, you should remember that you get a nearly naked e-bike. Mudguards, stands, and luggage racks are not shipped as standard. These can be ordered as extras. Speaking of ordering: you can have the Sushi Bike delivered to a cycle dealer near you. The dealer will set up the bike for you for a fair fee. Of course, you can also order the bike to your home and mount the front wheel, adjust the handlebars, and everything else that is necessary to make the bike ready to ride yourself.
Sushi Bike Maki M2: technical specs and price
Power 200 watts
Battery Removable 125 Wh battery with USB-A connection for other devices
Range Between 30 and 60 km
Charging speed Full in 3,5 hours
Brakes Mechanical Tektro disc brakes
Frame Aluminum frame in three sizes (50, 55, and 60 cm)
Tires Rims: Power 700C, 28-inch, 36H drop center
Tyres: Kenda K-193, 700 x 28C
Speed Electrical support up to a maximum of 25 km/h
Weight 15 kg including battery
App None
Price €999
A hard ride, but smooth in everyday life
For our test, we got the Sushi Bike Maki M2. For one week I was able to experience the e-bike in Berlin and the weather was not always gracious to me. Right on the first day, it rained like buckets and the streets were covered with big puddles. What was exciting here was that the Sushi Bike still had good traction.
ANdroidPIT Sushi Bike Maki M2 mudguard
The mudguards are optionally available. / © NextPit
In the following days, the weather was better and dry and it soon turned out that with the medium support level you can easily maintain a comfortable cruising speed. If you want to accelerate a bit faster, no matter if at the traffic lights or for an intermediate spurt, just switch to the highest support level, and the full 200-watt thrust of the rear engine will push you forward. Most of the time I only used this level to overcome slopes more evenly. But it is no comparison to the boost of a VanMoof S3.
The Sushi Bike come to a halt well. In the beginning, the brakes squeaked, but after a few brake applications the two-disc brakes were applied and the squeaking was gone.
Conclusion after one week: hard, but hearty
After an intensive week with the Sushi Bike Maki M2, I have to say that this e-bike probably offers one of the best value for money option in this market. It is simple, practical, and looks damn good at the same time. In everyday life, I found that the Sushi Bike provides driving fun immediately.
ANdroidPIT Sushi Bike Maki M2 seat
The saddle of the Sushi Bike is very firm! / © NextPit
Only one thing you have to be prepared for: the e-bike is built for sport, not comfort. Bumps go almost unfiltered into your buttocks and that can be really painful. It is best to get another saddle for the Sushi Bike. Even if the battery runs out on the way, because you forgot to charge it, the bike can convince as a single-speed even without electric support. All in all, the Sushi Bikes are great e-bikes for everyday use, which you can also afford. This is the e-bike for everyday city folk.
Source: Sushi Bikes
Review: Samsung Galaxy S23+
Review: Samsung Galaxy A54
  • $1,199.99
  • $999.99
  • $1,799.99
  • $1,799.99
  • from $999.99
  • $999.99
  • $699.99
Go to comment (2)
Shu On Kwok
Shu On Kwok
2 comments
  • caritu 3
    caritu Jul 23, 2020 Link to comment
    Cool that it weighs only 15 kg
  • TriciaRay 5
    TriciaRay Jun 18, 2020 Link to comment
    Frankly speaking, I would like to have one.
