8 essential Sony Xperia Z5 Premium tips and tricks
Androidpit Xperia Z5 Premium 1
The Sony Xperia Z5 Premium is a big phone with big talents, but some of its best features aren’t immediately obvious. Discover how to control the camera, get better battery life and organize your apps the way you want them with these excellent Sony Xperia Z5 Premium tips and tricks.
sony xperia z5 premium front display
Sony's super-sized flagship is great, but some of its best features aren't obvious. / © ANDROIDPIT
1. Use Stamina Mode for longer battery life
The Z5 family benefits from an improved version of Sony’s Stamina Mode, which is designed to prolong battery life. If you’re running Android Marshmallow, Sony reckons you’ll get 400 percent longer battery life with Stamina Mode engaged.
It achieves that by reducing what your phone gets up to, so, for example, background data traffic is reduced, notifications are quietened and apps won’t sync in the background. These are all little things but collectively they make a huge difference to how long your Z5’s battery lasts. If you’re really short of battery there’s a second, more severe mode called Ultra Stamina mode that turns off everything but the most basic phone functions.
You’ll find these modes in Settings > Device > Power Management.
xperia z5 battery options
The Z5 Premium has an improved version of Sony's Stamina Mode. / © ANDROIDPIT
2. Get some sleep
There’s a growing body of opinion that believes the blue light from mobile devices is messing with our bodies’ rhythms and ruining our sleep. If you suspect your Xperia is part of the problem you can change the white balance to make the screen less blue.
The bit you need is in Settings > Display > White balance. It’s also useful for getting better color reproduction if you feel your photos appear a little too cool or too warm on the Sony’s otherwise excellent screen.
3. Get rid of unwanted stock apps
Sony isn’t the worst offender on Android when it comes to stuffing smartphones with apps, but there’s a good chance that you won’t use some of the apps it provides such as the PSN Network or Lifelog.
Getting rid of them is simple enough: open the app drawer and press and hold on an empty space. Little X crosses will appear in the icons of the apps you can uninstall, and you can tap those Xes to get rid of the apps you don’t want.
If the Sony apps aren’t all removable using this method you can disable them in Settings > Apps > All. Find the appropriate apps and then tap the Disable button to turn them off.
Androidpit Xperia Z5 Premium 10
It's easy to remove or disable any apps you don't want. / © ANDROIDPIT
4. Get more pixels from the camera
The Z5 Premium has a 23 MP sensor, but the camera app is set to a default of 8 MP. That’s because the camera app uses a technique called oversampling to try and get the best shot under any circumstances: it takes extra pixels so you can zoom in on an 8 MP image without losing any quality.
If you’d rather get all the megapixels, you can set 23 MP in the camera app by tapping the three-dot settings icon.
Teste camera xperia z5 premium 1
The Z5 Premium has 23 MP but shoots 8 MP by default for lossless zooming. / © ANDROIDPIT
5. Reorganize the camera options
The various camera modes in the camera app are handy, but it’s likely that the ones you use most won’t be the ones at the top. You can move tiles around by long-pressing them and dragging them, and you can also delete the ones you don’t want: long-press and then look for the trash icon at the top of the screen.
6. Avoid blurry photos
As we explained in our Xperia Z5 camera tips feature, the Xperia Z5 has stabilization all over the place. So make use of it.
In Auto mode, hit the settings and head to the video tab and turn on SteadyShot for stabilized video. In Manual mode, hit the settings and flick the switch for Image stabilizer. In 4K video mode you have a SteadyShot option, so turn that on too. If you get a blurry photo or video after all this, you need to ease back on the caffeine.
sony xperia z5 premium camera
The camera has image stabilization for smoother shooting. / © ANDROIDPIT
7. Make your ringtone less frightening
You want your ringtone loud enough that you can hear it when it’s in a pocket or purse, but you don’t want it so loud that when it goes off you jump out of your chair and spill your coffee. What to do?
On the Xperia, there’s a brilliant feature that makes your ringtone start relatively quietly and build in volume with each ring. You’ll find it in Settings > Call > Increasing Ringtone.
8. Turn on the special modes
The Z5 has some useful display modes, some of which are off by default, but you should turn them on and start making the most of them.
Glove mode is designed to help you use your phone while using gloves, which is handy in cold weather; smart backlight cControl uses sensors to decide if you’re reading, in which case it doesn’t turn the screen off; and Tap To Wake Up enables you to wake up your Z5 by tapping twice on the screen. You’ll find all of these options in Settings Display.
xperia z5 smart backlight control
Smart Backlight Control is a useful feature, but it's not activated by default. / © ANDROIDPIT
Do you have any other top tips you’d like to share with your fellow Xperia owners? Let us know in the comments.
Go to comment (5)
Gary Marshall
Gary Marshall
Freelance writer
5 comments
  • hassan bouchta 10
    hassan bouchta Jan 28, 2016 Link to comment
    No not every normal user know this i think this can still help some ppl
    Ibraim Sued
  • Parvind Chahal 21
    Parvind Chahal Jan 27, 2016 Link to comment
    there is no need to waste time on things likes this every normal user knw these shits well
      Dale Kana Jan 27, 2016 Link to comment
      You people sure are rude.
      Brad ScottIbraim Sued
    • Dimitrya Dimitrova 2
      Dimitrya Dimitrova Apr 7, 2016 Link to comment
      I am interested to know what a normal user means to you? Moreover, why are you reading "these shits" if you know them? Normal users read about things like these because nobody is born with an unlimited knowledge about devices, as obviously you are! But I think that it will be better if you try not to dispense your negative, idiosyncratic attitude on people, nobody wants to know how much time you actually spent on your mobile device!!!!
      Brad Scott Dec 13, 2016 Link to comment
      I personally am very into phones and electronics and stuff, but I live in the US, where this phone hasn't been released, so I need articles like these - how else am I supposed to know about hings like glove mode - I don't know anyone who has this.
