If you happen to be an ardent tech enthusiast, chances are high that you know about most of the secret codes for mobile phones, you know, the ones that usually begin with “*#.” For those unaware, mobile phones have long had hidden codes that can be used to access interesting hidden apps and settings.
These codes can be broadly classified into two main categories USSD codes and MMI codes. While mostly not very useful to the average smartphone owner, these hidden codes can be used once in a while just to satiate your curiosity. The purpose of this article, therefore, is to create a comprehensive list of these secret codes for Android devices.
While the average user might not even need to know the difference between these two, it is always good to know what the differences are. Both USSD and MMI codes usually begin with an asterisk or a pound symbol/hashtag. These codes are updated regularly as new versions of Android software are released, and some manufacturers have their own additional special codes.
The code entry procedure is very simple and only requires you to bring up your dialer keypad and enter the appropriate number sequence. It's important to note that some codes are carrier-specific, so they won't work on all devices. So if your phone doesn't respond to a code, don't dwell on it, just move on and find another one.
USSD Codes
USSD stands for Unstructured Supplementary Service Data, and these codes are typically used to communicate between your smartphone and your mobile network operator. This also means that you almost always need to be connected to your carrier for USSD codes to work.
In the past, USSD codes were used to start/stop specific value-added services. They were also helpful in letting you know about the data usage and prepaid balance and accessing a whole lot of carrier-specific information.
While these are still used by smartphone enthusiasts, USSD codes have largely fallen out of favor among general users because most carriers have their own app/website where most of this information could be easily accessed. USSD codes are typically carrier-specific and will differ from one carrier to another. You will need to contact your carrier for the ones relevant to you.
MMI Codes
As for MMI codes, these are part of something known as the Man-Machine Interface schema and are generally specific to a smartphone brand or model. MMI codes let you access several interesting things on your smartphone – ranging from your IMEI number and SAR values to hidden menus that are generally used by smartphone engineers and repair services.
For example, several smartphones let users type in an MMI code and let them access a 'test’ menu. This menu lets users quickly perform various tests on their smartphone ranging from the camera and vibration motor tests to speaker and display tests.
Note that there are only a few MMI codes that typically work on all Android smartphones. We have listed the most popular ones in the generic list of codes below.
Generic secret codes for Android devices
These codes are mostly universal and should work on all Android devices, no matter the manufacturer. There might still be carrier restrictions on certain codes, though, so they're not all guaranteed to work.
Generic secret codes for Android phones (Info codes)
CODE
FUNCTION
*#06#
Show phone's IMEI
*#07#
Displays the Specific Absorption Rate (SAR) value of the device
*#*#225#*#*
Displays calendar storage info
*#*#426#*#*
Google Play Services info or Firebase Cloud Messaging diagnostics (Select devices only)
*#*#759#*#*
Access Rlz Debug UI (Select devices only)
*#0*#
Info menu (Select devices only)
*#*#4636#*#*
*#*#34971539#*#*
Camera info (Select devices only)
*#*#1111#*#*
FTA software version (Select devices only)
*#*#1234#*#*
PDA software version
*#12580*369#
Software and hardware info
*#7465625#
Device lock status
*#*#232338#*#*
MAC address
*#*#2663#*#*
Touchscreen version
*#*#3264#*#*
RAM version
*#*#232337#*#
Bluetooth address
*#*#2222#*#*
Hardware version
*#*#44336#*#*
Software version and update info
*#*#273282*255*663282*#*#*
Backup all media
Testing codes
Code
Function
*#*#197328640#*#*
Test mode
*#*#232339#*#*
Wi-Fi test
*#*#0842#*#*
Brightness and vibration test
*#*#2664#*#*
Touchscreen test
*#*#232331#*#*
Bluetooth test
*#*#7262626#*#*
Field test
*#*#1472365#*#*
GPS quick test
*#*#1575#*#*
Full GPS test
*#*#0283#*#*
Packet loopback test
*#*#0*#*#*
LCD display test
*#*#0289#*#*
Audio test
*#*#0588#*#*
Proximity sensor test
Configuration codes
Code
Function
*#9090#
Diagnostics settings
*#301279#
HSDPA/HSUPA settings
*#872564#
USB logging settings
Developer codes
Code
Function
*#9900#
System dump mode
##778 (+green/call button)
EPST menu
Manufacturer-specific codes
Samsung codes
Code
Function
*#0*#
Access diagnostics
*#011#
Network details and serving cell information
*#0228#
Battery status
*#0283#
Loopback Test menu
*#0808#
USB Settings
*#1234#
Software version/ Model details
*#2663#
Firmware details (Advanced)
*#7353#
Quick test menu
*#9090#
Advanced debugging tools
*#9900#
SysDump
*#2683662#
Service mode (Advanced)
*#34971539#
Camera firmware details
Xiaomi Codes
Code
Function
*#*#64663#*#*
Access test menu
Realme codes
Code
Function
*#800#
Feedback menu
*#888#
Engineer mode - displays PCB number
*#6776#
Software version
OnePlus codes
Code
Function
*#66#
Encrypted IMEI
*#888#
*#1234#
Software version
1+= (In stock calculator app)
Displays 'NEVER SETTLE' on the calculator app
*#*#2947322243#*#*
Wipes internal memory
Asus codes
Code
Function
*#07#
Regulatory labels
.12345+= (In calculator)
Open engineering mode
Motorola
Code
Function
*#*#2486#*#*
Opens engineering mode
*#07#
Shows regulatory information
##7764726
Hidden Motorola Droid menu
HTC
Code
Function
*#*#3424#*#*
HTC test program
##786#
(Caution!) Phone reset menu
##3282#
EPST menu
##3424#
Diagnostic mode
##33284#
Field test
##8626337#
Launch Vocoder
*#*#4636#*#*
HTC info menu
Sony codes
Code
Function
*#*#73788423#*#*
Access service menu
*#07#
Certification details
Nokia codes
Code
Function
*#*#372733#*#*
Open service menu (FQC Menu)
Other codes
Code
Function
*#7780#
(Caution!) Factory reset
*2767*3855#
(Caution!) Full factory reset
*#*#7594#*#*
Power off the phone
*#*#8351#*#*
Activate dialer log mode
#*#8350#*#*
Deactivate dialer log mode
Stay away from these codes!
Think before using!
Code
Function
*#*#7780#*#*
(Caution! Risk of data loss and rendering phone useless) Factory data partition reset
*2767*3855#
(Caution! Risk of data loss and rendering phone useless) Format device
USSD codes for US carriers
These aren't the secret ones, but they're not so well known. USSD, or Unstructured Supplementary Service Data, codes connect to the phone's network once dialed to perform certain functions, like finding out how much credit you have left on your prepaid phone or how much data you've used this month. They change often, and the codes vary from carrier to carrier. Here are a few you can try for some of the major US carriers, along with links to more carrier-specific codes:
AT&T
Code
Function
Code with Spanish reply
*3282#
Check your data and messaging (SMS) usage (*DATA# | *DATO#)
*3286#
*646#
Check your remaining minutes' balance (*MIN# | *USO#)
*876#
*225#
Check your balance, get the next bill due date, and the last payment received (*BAL# | *SAL#)
*725#
Verizon
Code
Function
#3282
Check your data usage (#DATA)
#225
Check your balance (#BAL)
#646
Check your minutes (#MIN)
T-Mobile
Code
Function
#225#
Check your account balance and the last contract payment (#BAL#)
#999#
Check prepaid account balance
#646#
Check minute usage (#MIN#)
#674#
Check message (SMS) usage (#MSG#)
#932#
Check data used, data plan, and expiration date (#WEB#)
There's a good chance you'll never need to use most of these codes, but if you do, then now you know where to find them.
Are there any secret codes that you find yourself using all the time? Or are there any we haven't listed here that are really interesting? Let us know in the comments!
Article updated in October 2022 with additional US carrier USSD codes, and a layout cleanup. Comments published before the update were kept and may refer to an outdated version of this page.
How does one go about finding out if there has been any outside influence on my phone?
Airforce king
Nov 22, 2022
Link to comment
how can we get to the key service info on any android phone or Samsung s22 because the OG code of *#*#4636#*#* doesn't work? Thanks
storm
Oct 28, 2022
Link to comment
These were far more useful in the days of dumb phones. With smart phones, this is pretty esoteric or info otherwise available in the app or irrelevant. Most prepaid deals offer unlimited talk and text for the most part anymore.
davidkabwe Kateule
Aug 22, 2022
Link to comment
LG G8x grey area can't change APN I tried ##3282# with complications asked for code I'm in Zambia
Medo Samuel
Aug 22, 2022
Link to comment
Please help me unlock my Samsung network
Fabien Röhlinger
Admin
Staff
Aug 23, 2022
Link to comment
You need to check back with your provider.
Medo Samuel
Aug 22, 2022
Link to comment
I'm in ghana 🇬🇭 in west Africa I bought Samsung Galaxy but the network is locked, I need a code for that
Kirsten Barco
May 27, 2022
Link to comment
Is there anyway to get the network unlock pin from any of the hidden menus? i have a Motorola on metro pcs
Kathryn Clemens
May 24, 2022
Link to comment
Is there a code to see if someone has access to my camera or microphone? Or access to anything on my phone like google, messages, or anything?
Indyguy
Feb 10, 2023
Link to comment
Did you get any answers? I'd like to know as well.
Justin Johnson
May 11, 2022
Link to comment
I've a Samsung Galaxy a03s. What's the code to see if phones tapped or hacked? And what does it say if it is or isnt
Indyguy
Feb 10, 2023
Link to comment
Did you get any answers to this question?
Cory McEntire
May 6, 2022
Link to comment
How to get to developer options ? Note20
Kimberly Basso
May 4, 2022
Link to comment
I need moto codea
Mary Ruth Harrill
Feb 26, 2022
Link to comment
I need LG codes
Steve l l
Feb 23, 2022
Link to comment
I have a samsung note 8. I'm looking for codes to detect if my phone is hacked or cloned
Winston Beck
Apr 15, 2022
Link to comment
*#21# If it doesnt say not forwarded all across the board, you have a problem.
Lidia
Apr 16, 2022
Link to comment
It doesn't do anything at all for me on my pixel4a.... Is that bad?
Emily Amber
Apr 22, 2022
Link to comment
What is it says call forwarding unconditionally 🤔
Emily Amber
Apr 22, 2022
Link to comment
What if it says call forward unconditionally
Indyguy
Feb 10, 2023
Link to comment
Did you find out what that means. Mine says the same thing?
Cristi Dumitru
Feb 15, 2022
Link to comment
##7764726 this motorolla code does not work lol
Justin Hubert
Mar 2, 2022
Link to comment
try*#7764726#*
Sipiras Sipira
Feb 13, 2022
Link to comment
#31# DETAILS. How can I enable in my phone?
Jai
Jan 15, 2022
Link to comment
What is ##786# mmi code i see in groovypost as one to know if your mobile is p Refurbished.
Rubens Eishima
Admin
Staff
Jan 17, 2022
Link to comment
As far as we know, that MMI code does not allow you to check if the device is refurbished.
Stephanie Leach
Jan 21, 2022
Link to comment
Phone reset
Jenessa Blake
Dec 7, 2021
Link to comment
Does the network know when you use these codes??
Rubens Eishima
Admin
Staff
Dec 9, 2021
Link to comment
theoretically, no.
The ones related to devices features can even be used without a SIM card
M. A. Griesser
Oct 24, 2022
Link to comment
Yo Janessa how you doin'?
Melba
Nov 10, 2021
Link to comment
how do i delete temp files on android samsung a10. my phone is telling me "too many files have been created on your phone....do a factory reset...." this is interferring with my apps and more. Is Factory Reset my only option??
Zois Bekios Zannikos
Nov 10, 2021
Link to comment
How much free space does your device have? If it still has, probably resetting it would fix the bug. If you do not have enough free space, try deleting some items or bigger apps.
Exonica
Jul 19, 2019
Link to comment
I'm curious if doing a format would allow windows to be installed on a phone
storm
Dec 27, 2019
Link to comment
Nothing in this article would let you do that.
Justin
Sep 29, 2021
Link to comment
You are right
Technotechnotes
Jan 29, 2020
Link to comment
Windows as your talking about, cannot run on a phone. The architecture is completely different your phone is most likely an arm x86 or in that field and windows cannot run on that by default however there is a version of Windows built for the atom processors which are incredibly terrible in my opinion. However if you would like Linux on your phone there are plenty of ways to get Linux running on your phone
Darrellnterilynn Oliver
Mar 30, 2021
Link to comment
how would I install linux
storm
Sep 30, 2021
Link to comment
Just google the topic. Plenty of guides out there. Some of it will depend on the target phone, your technical competency and so on.
Link to comment
Thanks for the informative article 😊.
Brian Carr
Jul 17, 2019
Link to comment
nice useful article 👍
eSparkBiz
Jul 17, 2019
Link to comment
I tried the code for mac address in my phone dialer of Samsung a50, But it didn't give me mac address. I don't know how?
Mark G.
Jul 17, 2019
Link to comment
These codes are generic for Android - so for instance a Google device or other devices running the Stock version of Android. Whilst some will work on other devices running a manufacturer version of Android, it's a hit or a miss as to what works.
You can try searching for Samsung specific codes, though again it is not 100% certain that all of them will work. (some may be specific for the Galaxy range, or may change for different years).
You can download apps from the Google play store that aggregate these settings to a helpful UI.
Peace 🖖
Justin
Sep 29, 2021
Link to comment
I don't think any of these codes work for anything
Tarek Khaled
Apr 6, 2019
Link to comment
How can i type the code without having the dialer (SUMSUNG Note)
Mark G.
Jul 17, 2019
Link to comment
How do you make telephone calls?
If you can't access the Mobile network or make telephone calls then it won't be possible.
Peace 🖖
storm
Dec 27, 2019
Link to comment
On Huawei tablets, using these codes in the supplied calculator in Landscape orientation would work the same. I think that's specific to Huawei though. Replace # with parentheses as I recall.
Pat
Sep 1, 2020
Link to comment
I'm sure I'm missing something, but I'm not sure what you mean by not having the dialer. I've had several Note's and have the Note 9 now, and they have all had dialers. It's a phone.
Sravani Namburi
Nov 19, 2018
Link to comment
Hi this information helped me a lot nice article
sravan kumar
Oct 30, 2018
Link to comment
max codes not working on mi a1 oreo 8.1 Version mobile
The Nib Post
Aug 24, 2018
Link to comment
thanks for updating these codes i found very useful
Mister Tall
Feb 1, 2018
Link to comment
Sophia, did you even test any of these codes on a phone before publishing, most of them are copied from one website to another ad nauseum and don't actually work... Does androidPit just publish anything as click bait without checking?
Jerry's W.
Aug 28, 2018
Link to comment
yes they do
Mark G.
Jul 17, 2019
Link to comment
These codes are specific to Stock Android, they may work on manufacturer altered versions of Android though it's not guaranteed.
Peace 🖖
Mick Flynn
Jan 21, 2018
Link to comment
I tried one of these codes in 2015, it's 2018 now and I have only just arrived back in time again after the code allowed me to travel forward in time to 2023. Luckily I was able to enter the same code into my Trump z5s tablet and it worked fine. Treat these codes with caution.
z b
Dec 28, 2016
Link to comment
*#0*# works on Note 2, and Note 4.
Diptangshu M.
Dec 27, 2016
Link to comment
Just what I was searching for a long long time!
Mansoor Bozdar
Dec 27, 2016
Link to comment
wow! it is really good . but in backup code work when i have a backup of my data.
john p
Sep 22, 2016
Link to comment
Can someone PLEASE tell me the dialer code to remove the carrier picture that shows when you 1st boot the phone. There is one I found it once but am having a hard time finding it again.. It did work too i just need it again for my replacement phone now.
Jeffrey Smith
Sep 5, 2016
Link to comment
Is there any codes for a nobis nb09 android tablet or any that will work on it please help me and let me know
M. A. Griesser
Dec 28, 2016
Link to comment
You're joking right? What a funny guy! Nobis, Ha! I didn't even see Samsung. There was HTC and Motorola. That's it. I've never even heard of nobis and you're looking for a hidden code for an obscure tablet hahahahahahahahahahahahahahahahahahahaha hhahahahahahahahahahahaha hhahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahaha .
Thanks man I needed that.
Letit Rain
Apr 10, 2017
Link to comment
You're so very helpful. Quite the troll. Thanks for being a doosh and confirming my belief that the internet is simply filled with idiots who have nothing to contribute besides being an anonymous jerk.
Calbertrick
Sep 10, 2018
Link to comment
Laugh now, cry later...the next time you unzip, I imagine. It's a legitimate question and if you can't be any help, quit wasting oxygen and PLEASE don't reproduce.
Mel Agee
Jul 24, 2022
Link to comment
"D•o•u•c•h•e" by the way just saying. Just thought in the future you might want to know how to spell it before calling people idiots. Just saying.
M. A. Griesser
Oct 24, 2022
Link to comment
Anonymous jerk? That's my name and picture. That's the exact opposite of anonymous. As far as jerk? I was pleasant, polite, I even thanked him. I still think his question is hilarious. It's just so quaint and cute and naive. It compelled me to leave my comment. All the responders to me are the jerks. Honestly my intent was to help the guy. I thought maybe next time he might do a bit of critical thinking, look at who's writing the article, look at how broad it is, is there any real technical experts here, what type of comments are being left by others, maybe I ought to try googling my device make and model first then go from there.
ツツツツ
Jul 14, 2016
Link to comment
This does not work with Verizon HTC Phones! :-(
balajikasinathan
Dec 1, 2015
Link to comment
no code working on my phone model uber avvio794q or mx8562
balajikasinathan
Dec 1, 2015
Link to comment
i have uber avvio794q model mobile all not working ,it showing task locked ,kindly provide any code to complete reset.
Bee
Aug 28, 2015
Link to comment
I tried 6 or 8 of these. None of them did anything. Galaxy Note 4.
Link to comment
Some carriers block some/all of these codes.
Crystal Traner
Oct 25, 2018
Link to comment
youtube.com have many useful codes
William Diorio
Aug 27, 2015
Link to comment
Does anyone know how to enable Download booster on Samsung Note 4? I confirmed it should have it but cannot find it anywhere. I already enabled Developer Options but still no luck. Thanks!
Chad_Higgins
Sep 15, 2015
Link to comment
If u have a Sprint phone. They took it off. No download booster
radiocycle
Aug 26, 2015
Link to comment
*#*# doesn't do anything on MY HTC M8 :(
Barry Dugger
Jun 11, 2015
Link to comment
I use *#9900# to delete log files. This helps clear out memory, especially when a phone says "not enough memory" after an update.
tom burk
Sep 16, 2015
Link to comment
works for note 3 phone thanks Barry
Chad_Higgins
May 25, 2015
Link to comment
will i go back to kit kat if i do the complete phone wipe?
Chris M.
May 25, 2015
Link to comment
Any way to do this on a non-phone tablet? I The VoIP keyboard doesn't work (in spite of a small prayer).
Amir Khan
May 22, 2015
Link to comment
but some code not work...
My1
May 22, 2015
Link to comment
wrong. the code for Samsung screen (and other things) test is *#0*#. tested on Note 3
Amir Khan
May 22, 2015
Link to comment
All code is not working my Galaxy s3 neo...
donald elmore
May 22, 2015
Link to comment
does anyone have the codes for Motorola MOTO G
Martin Neal Burgess
May 22, 2015
Link to comment
Forgot to tick the box ... doh!
Martin Neal Burgess
May 22, 2015
Link to comment
I would like to know also, maybe it will take me back so i can start using the SD card like before !!
Jack Shaw
May 21, 2015
Link to comment
It appears U. S. Cellular does not want me to learn about my GS5. None of the codes work in any fashion. I was able to access the codes on my GS4.
Wallambok K D.
May 21, 2015
Link to comment
Codes for Moto G2, anybody?
Cameron N.
May 21, 2015
Link to comment
None Of THese Codes Work On ZTE 667T [Tmobile] The Kernel Requires Password To Access These Features.
djedred1
May 21, 2015
Link to comment
none of the codes will work on Verizon. Is this the case?
Jesenko Plecic
May 21, 2015
Link to comment
You'd prolly have to recover it after a complete wipe, if you do not know how do not play with this feature
Dimitris Zandes
May 20, 2015
Link to comment
With this, (*2767*3855# - Complete phone wipe, including firmware (not to be used lightly!)), does the phone reset to its first version of the OS or after that you dont have any software at all??
Carmelo Rivera
May 21, 2015
Link to comment
Good question. If you don't mind, I'm gonna just write this and if you get a reply I'll know too. Thanks.
Recommended editorial content
Jobbio
Please help me with to unlock pattern for Samsung
If you set a Samsung account on the phone, you can follow these steps to unlock the Galaxy phone:
https://www.nextpit.com/how-to-unlock-samsung-smartphone
I need moto codea
I need LG codes
try*#7764726#*
Refurbished.
Phone reset
theoretically, no.
You are right
Peace 🖖
Peace 🖖
yes they do
Peace 🖖
wrong.
