Samsung Galaxy S10+ users reporting signal dips
AndroidPIT samsung galaxy s10 group shot ab34
According to our colleagues at Android Police, owners of Samsung's new $999 Galaxy S10 Plus are suffering from issues with LTE/4G signal in the US. It seems that simply holding the device in a certain way can cause significant dips in signal strength.
The issues seem to be affecting multiple carriers, with reports coming in from customers at AT&T, T-Mobile and Sprint, although Sprint is being affected more than the others. In a not entirely new development, using a case to protect your expensive new thousand-dollar smartphone also reduces your signal strength.
Sprint has responded to the issue on its community forum. Reporting that: "Sprint and Samsung are receiving a small number of reports about unexpected roaming, data loss, or voice issues on the Galaxy S10 models." The post said that active investigations are ongoing to validate and address any concerns.
AndroidPIT samsung galaxy s10 plus front camera g3gt
Have you had a problem with your S10 Plus? / © NextPit
The solution? According to Sprint, basic device troubleshooting steps are the way to go, including but not limited to PRL update, Profile Update, Software update, Power cycle, and factory data resets. "If a resolution is not found, then a ticket should be opened through customer care for further network investigation," is the advice given by Sprint.
According to another source, some S10 Plus owners managed to fix the issue by disabling Band 41 and Band 25 via a hidden Data Programming menu. The staff at Android Police reported that those on T-Mobile or AT&T using Band 12 had more trouble than those on T-Mobile in an area using Band 2. Our own review device cannot be used to test this hypothesis as our editorial office is in Berlin, Germany.
It is also possible that this issue affects the regular Galaxy S10 and S10e, although most of the reports indicate that the issue is much worse on the largest and most expensive variant on Samsung's 2019 flagship phones.
Have you suffered any signal dips or network issues on your S10 Plus? Let us know in the comments below. Don't forget to mention your carrier if you have had problems.
Go to comment (5)
David McCourt
David McCourt
5 comments
    Roshni Sharma Jun 11, 2019 Link to comment
    Apart from this problem, many users reported about fingerprint problem that prevents them from unlocking device randomly. And a few more bugs have been reported by users (check this resource to troubleshoot them https://techshali.com/most-common-samsung-galaxy-s10-plus-problems-fixes/ )
    We hope that Samsung would prepare a stable firmware build and release it soon. Otherwise, users would need to seek solutions on their own.
    Andy May 30, 2019 Link to comment
    I have my s10plus since late march with Verizon and I'm having network issues for the past month, every now and than I do network reset and it helps for some time
  • Cynthia LaCroix 1
    Cynthia LaCroix Apr 2, 2019 Link to comment
    Had my s10plus for 3 weeks, last 3 days it's in roaming constantly, basically an expensive paper weight right now. Glad for the insurance, getting a replacement sent. Have Sprint service. Guess they say it's a known problem with this phone. Hope it gets resolved.
    JeffD Mar 28, 2019 Link to comment
    I had this problem on AT&T with an unlocked S10+ and had to buy a branded one.
  • David Martrano 29
    David Martrano Mar 27, 2019 Link to comment
    I use the s10plus with Verizon and have encountered no problems whatsoever. Everything works just fine, I do think this is a specific carrier problem!
