Pros of the Amazon Echo Dot (3. Gen.)
  • Compact design
  • Improved sound
  • Possibility of pairing with a second speaker
  • Price
Cons of the Amazon Echo Dot (3. Gen.)
  • Alexa app
Jump directly to:
Price unchanged for the Echo and Echo Dot (2019)
In order to remain competitive in the fight between connected speakers, Amazon has sensibly decided to keep its prices the same. You can, therefore, buy the new Amazon Echo Dot (2019) for $49.99/£34.99. A clock version of the Echo Dot with a white LED display is available for £44.99/$59.99.
AndroidPIT Amazon Echo Dot Light
Four colors are available: Twilight Blue, Sandstone, Heather Grey and Charcoal / © NextPit Image source: NextPit
The Amazon Echo is still available for £89.99 and in four colors (Twilight Blue, Sandstone, Heather Grey and Charcoal).
AndroidPIT Amazon Echo Kitchen 2
The Amazon Echo can easily be placed in any room of the house / © NextPit Image source: NextPit
Revised and improved sound
At first sight, it is difficult to see the differences with the previous generation. However, Amazon has slightly modified the design of its speaker with a more refined result. In particular, they now have more rounded edges and new colors.
Given the relatively compact size of the speaker, it is always difficult to significantly improve the sound quality of the device generation after generation. Amazon has nevertheless taken up the challenge by transforming the sound experience of the Amazon Echo. It was a wise decision as the American giant has been behind in this field, especially compared to Google, but even more so against the many third-party competitors that are compatible with Alexa.
AndroidPIT Amazon Echo Kitchen 1
The Echo retains a relatively compact format / © NextPit Image source: NextPit
In addition to its Dolby compatibility (like last year’s generation), the Echo has a more immersive sound thanks to a 7.6-centimeter bass driver and new neodymium diaphragms, hardware already present on the Echo Plus. Above all, Amazon finally allows you to pair the speaker with other Alexa speakers for stereo sound. It is also possible to pair the speaker with an Amazon Echo Plus 2nd generation speaker too.
  • You can now ask Alexa to erase everything you’ve told her
AndroidPIT Amazon Echo Light
The new Amazon Echo speakers are obviously compatible with Alexa / © NextPit Image source: NextPit
Amazon Echo Dot: a version with clock
The smallest of the Amazon speakers is also entitled to an update. This third-generation, a real hit in terms of sales, aims to compete with the new Google Nest Mini launched around the same time. Amazon has also improved the sound, but the difference in sound quality with its older brother is still significant, due to its very compact design. As with the main Echo, it is possible to pair the speaker with a second one for stereo sound.
AndroidPIT Amazon Echo Dot Screen
The LED display offers functions other than time (alarm, weather, etc.) / © NextPit Image source: NextPit
The colors have also been revised but it is especially the appearance of a version with clock that is appreciable (and that is this model I tested). It’s a kind of clock radio 2.0, the Echo Dot has a small white LED display hidden under the fabric of the device. The white light is very bright and the brightness automatically adapts to the room. At night, if you place the Echo Dot in your bedroom (which was my case), you are absolutely undisturbed. In addition to the time, the small display can also display the outdoor temperature, a timer and of course alarms.
Unlike the Nest Mini, Amazon does not offer any assistance for wall mounting. If this detail does not really matter for the model with a clock, whose use is primarily reserved for bedrooms, it would have been nice to have wall mounting possible on the classic Echo Dot.
  • How to set up your Amazon Echo Dot
AndroidPIT Amazon Echo Dot Ports
A headphone socket is available if you want to plug in headphones / © NextPit Image source: NextPit
How are the new features?
In terms of sound quality, there has definitely been an improvement in both models. Of course, the Echo offers a much richer and more powerful sound than the Echo Dot. The sound is also immersive with a 360-degree effect that is particularly enjoyable. Compared to the previous generation, the difference is significant, especially in terms of bass and the depth of the sound. The Echo is perfectly sufficient to deliver powerful sound capable of filling the rooms of a small home. The volume is high enough to bother your neighbors. Only the mid could do with a little more care.
Coupled with an Echo Dot, the experience is very pleasant thanks to the possibility of combining two speakers together. The result is a very pleasant stereo sound for a fair price (£135 for the whole package). For an apartment of about forty square meters, the association Echo (living room) + Echo Dot (bedroom) is a perfect combo to enjoy a good sound experience.
  • 10 cool things to do with your Amazon Echo Show
AndroidPIT Amazon Echo Bedroom
Finally, it is possible to have stereo sound with several Alexa speakers / © NextPit Image source: NextPit
The Echo Dot alone provides a relatively good sound considering the size of the device but obviously remains weaker than that of the Echo. However, Amazon has really improved the sound quality of its small speaker to match the new Google Nest Mini. It’s not the best small speaker but it’s the best with Alexa. The model with the clock is more than enough to fill a small room. The time display is also very good and the Echo Dot is for me the perfect modern alarm clock radio.
On both models, the buttons are easily accessible and easy to use. It is always possible to turn off the microphone to avoid incessant triggering (or for your seven-year-old niece to ask Alexa for the sounds of the different animals for a whole afternoon).
AndroidPIT Amazon Echo Buttons
Don’t worry, it is still possible to turn off the microphone for Alexa / © NextPit Image source: NextPit
Compared to Google’s speakers, I must admit that Alexa is much easier to activate, even when you don’t call her. I would like to be able to adjust the trigger sensitivity. Unfortunately, no such options are available. It should also be noted that, compared to Nest speakers, questions asked to the assistant are not processed on the device but on Amazon’s servers.
  • The big talk: Alexa, Siri, Google Assistant and co. compared
The Alexa app could be improved
To set up and use your speakers, but also to pair Alexa speakers, you must use the Alexa app available for free on iOS and Android. It is quite simple to use but its interface could be improved for more clarity, especially for neophytes who are not always familiar with setting up this type of product, which is always popular during the Christmas and New Year holidays because of their affordability.
Thus, loading times can sometimes be quite long. Another concern is that if you have several Echo speakers, it becomes complicated to distinguish between the different devices. I therefore advise you to rename them and specify where the speakers are located in order to avoid any problems.
androidpit alexa app echo
The Amazon Alexa app / © NextPit Image source: NextPit
Fine verdict: is it worth buying it?
The Echo and Echo Dot (2019) are excellent. Without revolutionizing its speakers, Amazon has succeeded in significantly improving the sound quality of its devices whilst keeping prices as affordable as ever. The possibility of combining two or more speakers finally allows you to enjoy stereo sound and is an interesting advantage. Alexa is still as easy to use on both models as Google Assistant is.
If you want to enter the world of Alexa and equip your home with stereo sound, the Echo + Echo Dot combo is a perfect option. If you are looking for a good quality speaker without breaking the bank, the Echo one to consider. If you’re looking for a modern clock radio, the Echo Dot is probably the best option at the moment too.
