OnePlus X problems and solutions
oneplus x screen 1
The OnePlus X is a great phone with a killer price, but inevitably a few corners have been cut – so the battery life isn’t brilliant and the camera could be better. Discover how to combat these and other irritations in this guide to OnePlus X problems and solutions.
oneplus x about phone
The OnePlus X is great value, but some corners have been cut. / © ANDROIDPIT
As with any smartphone, always check the obvious stuff before getting annoyed with your device. Switching it on and off again may be the stuff of tech support cliche, but it does solve the majority of niggling problems.
Make sure you have the most up to date software – OxygenOS 2.2.0 is starting to roll out right now, and should address some of the issues detailed here – and try going into Safe Mode to see if your problems go away when third party apps are disabled. If they do then you clearly have a problem with a specific app.
Thsse tips won’t solve everything, however, so read on for some more solutions.
OnePlus X microSD card isn’t working
We’ve seen reports from multiple users complaining that their microSD card isn’t being recognized by their OnePlus X. It seems to be a fairly widespread issue.
One solution is to reformat the card in NTFS format, which you can read about here. Prevention is better than cure though, so it’s a good idea to format the card in your phone before you use it.
oneplus x 15
Formatting your card as NTFS can solve the unrecognized card issue.  / © ANDROIDPIT
OnePlus X photos are rubbish
The camera in the OnePlus X isn’t brilliant, and there’s a very good chance that it won’t focus on what you’re trying to shoot – and even if it does, it’s very, very sensitive to camera shake.
Carrying a tripod around with you is one way to reduce the risk of blurred photos, but it’s hardly practical for everyday phone use. Making sure you have the most up-to-date version of the OnePlus software makes a bit of a difference to photo quality, but you may need to use a third-party program such as VSCO to sharpen up your images.
It’s a shame that OnePlus couldn’t have cut corners elsewhere and given us a decent camera.
andoridpit oneplus x camera focus problem issue
VSCO can improve the blurry photos the OnePlus X often takes. / © ANDROIDPIT
OnePlus X app permissions aren’t sticking
Some users have reported that their OnePlus X doesn’t remember the app permissions for apps such as Spotify and WhatsApp, resulting in annoying error messages on launching the apps.
You can usually solve this issue by going into settings for the app in question and clearing its cache. Restart your OnePlus and the problem should be resolved.
OnePlus X LTE connectivity is terrible
This one affects many US users: the OnePlus X doesn’t support LTE bands 12 and 17, which just so happen to be the bands delivering the best coverage in rural and urban areas.
Sadly there isn’t a fix for this one other than trying to find public Wi-Fi in areas where you can’t get a decent LTE connection.
oneplus x screen 1
The OnePlus doesn't support the two most common LTE bands in the US. / © NextPit
OnePlus X vibrates during phone calls
This isn’t a notification thing; it’s a phone vibrating for no good reason thing. The culprit appears to be the double tap to wake setting in the OnePlus X’s settings page; many users have reported that disabling this stops the mysterious and annoying vibrations.
OnePlus X battery life is terrible
The OnePlus X doesn’t have the biggest battery in its class, so you shouldn’t expect amazing stamina if you run really demanding apps for long periods. However, if you’re suddenly experiencing rapid battery drain then there are several possible reasons for that.
The most likely is that a new app is doing stuff in the background – syncing data, checking location services or something else draining – so it’s worth having a look at the Battery status page to see if anything’s having a disproportionately bad effect on your battery.
Failing that a hard reboot or a factory reset could solve the problems, but make sure you have the most recent version of the OnePlus software first, because that has solved battery drain problems for many OnePlus X owners.
oneplus x side 5
Dimming the screen makes a big difference to battery life. / © ANDROIDPIT
If the problem isn’t new and you’re just unhappy with the OnePlus X’s battery life, there are several steps you can take to prolong the battery: dim the screen, which is the biggest battery drain of all; prevent apps from syncing in the background; avoid using cellular data or making calls in a poor signal area, because the radio ups its power to compensate; and download media rather than streaming it. Check out more general Android battery saving tips in our dedicated article.
Have you encountered issues with your OnePlus X that we haven’t listed here? Let us know in the comments.
Review: Google Pixel 7
Go to comment (30)
Gary Marshall
Gary Marshall
Freelance writer
30 comments
  • Akhilesh Solanki 1
    Akhilesh Solanki Oct 7, 2016 Link to comment
    Radio is not working. It worked for around furst 2 months and then since almost 6 months it is not working. No response. Now after getting h marshmallow update it worked again for a day and now it's not working. It says app is not responding. Can anyone tell me way around. I am in Mumbai
  • Kamal Fadli 1
    Kamal Fadli Jun 21, 2016 Link to comment
    Ive got the incoming call problem like somebody trying to call me.. But they can't. In the same time. I can used the cellular data without any problem. Whats the problem acually is..? Need help.
  • ‫אופיר אלבכרי‬‎ 1
    ‫אופיר אלבכרי‬‎ Apr 14, 2016 Link to comment
    working fine fot me
    beatriceobinson Mar 29, 2016 Link to comment
    That I am not satisfied wiht my OnePlus X is no fingerprint identification
  • Joshua Gonsalves 1
    Joshua Gonsalves Mar 26, 2016 Link to comment
    I have a problem with the volume on my one plus X....the volume is too tini even at the highest volume...and the best (worst)part is that it reduces even further when I turn on the screen(which is very noticeable).
    Tiou Eldiaj Feb 12, 2016 Link to comment
    Hi Guys,
    hope u could help!.. My new opx after charged to 100% this morning and working a while, does not turning on at all for now, nor if the charger is plugged to it, or not. I hv tried to go to the recovery mode (power + volume down buttons) but nothing.
    Pls. help me, what to do, what the hell is this phenomenon could be!?
    Many thx in advance
    • Luis Rodriguez Lopez 2
      Luis Rodriguez Lopez Mar 21, 2016 Link to comment
      I have the same problem... you could fix??
      Joshua Gonsalves
    • Vendra Wasnury 1
      Vendra Wasnury Apr 29, 2016 Link to comment
      same happen here.....anyone can help on this? its totally dead
  • Nazimul Asif 1
    Nazimul Asif Feb 8, 2016 Link to comment
    Circle Camera Gesture Not Working
    Piyushi Sao Feb 7, 2016 Link to comment
    Phones open app is shutting down automatically.. N turning to recent apps page.. I m not able to open any app apart from those in home screen.
      Lies Apr 18, 2016 Link to comment
      I have the same problem, did you find a solution yet?
    Vishal Feb 4, 2016 Link to comment
    The launcher directly taking me into recent screens.. I fed up with that
    Piyushi Sao
    • Praveen Ortan 2
      Praveen Ortan Feb 5, 2016 Link to comment
      Reseting your mobile will solve this problem.
      Even after resetting if u get this problem. Use other launchers instead of oneplus launcher
      abhishek patilVishal
        Vishal Feb 5, 2016 Link to comment
        Yeah.. I didn't reset.. But using other launcher.. Thanq bro
        abhishek patilPraveen Ortan
      Happening with me as well
    • abhishek patil 1
      abhishek patil Feb 14, 2016 Link to comment
      Yeah m also experiencing that problem
    • abhishek patil 1
      Same problem experienced
    • Prashanth Deva 1
      Prashanth Deva Feb 26, 2016 Link to comment
      just enable google search bar if you have disabled it ur problem would be fixed
  • 10
    sam pack Feb 2, 2016 Link to comment
    The annoying Google search bar can't be removed from the home screen. That sucks! Opx, you need a major update asap!
      Karel-Willem Jaarsveld Feb 3, 2016 Link to comment
      Use Nova Launcher to edit the Google Search Bar. It's much better to look at now.
    • Praveen Ortan 2
      Praveen Ortan Feb 4, 2016 Link to comment
      Touch hold the home screen. Go to settings enable the hide search bar option. Google search bar will b removed.
  • Kuladeep K Arun 3
    Kuladeep K Arun Feb 2, 2016 Link to comment
    From yesterday, the launcher screen is redirecting to the recent screens page on my 5 days old phone. Solutions?
    Piyushi SaoRashmi D
      Ram S Feb 3, 2016 Link to comment
      Uskng Nova Launcher or Google Now LAUNCHER will solve thia problem. Nova launcher is simply great. i also came across this issue, and fohnd out issue with one plus launcher.
      Kuladeep K Arun
        you can install Nova launcher via Google. play. store
      • Kuladeep K Arun 3
        Kuladeep K Arun Feb 5, 2016 Link to comment
        thank you! :)
    Karel-Willem Jaarsveld Feb 2, 2016 Link to comment
    No problems at all, except for the 'not-so-great' camera.
  • Praveen Ortan 2
    Praveen Ortan Feb 2, 2016 Link to comment
    I owned a onplus x from amazon.
    My mobile gets unexpected reboots! Sometimes.
    Wat is the problem? How to solve it.
  • upendran m 1
    upendran m Feb 2, 2016 Link to comment
    I got a new OPX from Amazon (India).I have 2 problems in dual sim-1. if I miss a call, I am unable to find out from which sim (Sim-1 or Sim-2) the call had come. Previously I was using Moto G where along with the number the sim thru which the call was received will be registered. I am unable to find any such functionality here.
    2. Again when I see an incoming call thru any Sim, the call receiving screen is only blue. SO I need to look above the caller details to find out whether I am receiving this call from Sim-1 or Sim-2. Previously in Moto G, the calls thru Sim-1 comes in blue colour whereas from Sim-2 comes in green colour.
    Is there any soluton for both these issues.
      Fstop Live Feb 2, 2016 Link to comment
      So why not send phone back & use Moto G? Oh, just 1G RAM, CPU , Camera, Software Updates?
  • Parvind Chahal 21
    Parvind Chahal Feb 2, 2016 Link to comment
    gary u r only expert in writing same line for each phone's prblm
