Nexus 5X review: heroic return
androidpit Nexus 5X 5 8
The Nexus smartphone is now in its seventh generation, and for the first time, Google has released two versions of its developer smartphone in the same year. The Nexus 5X, reviewed here, is the successor to 2013’s Nexus 5, which set a new benchmark for price-performance ratios. In this Nexus 5X review, we investigate whether LG has hit that sweet spot once again.
Google Nexus 5X
  • Updates direct from Google
  • Monthly security updates
  • USB-Type C
  • Excellent camera for a Nexus
  • Software easy to mod
  • Type-A data cable not included
  • Design isn’t beautiful
  • Small internal memory
Google Nexus 5X
Google Nexus 5X
Google Nexus 5X: All deals
Google Nexus 5X release date and price
The Nexus 5X can be bought online directly from Google. The 16 GB base model costs US$379, the 32 GB model, US$429.
Google Nexus 5X design and build quality
The Nexus 5X design bears some similarities to the 2013 Nexus 5. Other smartphone manufacturers have injected flavor and beauty into their 2015 devices, by using more exotic materials, such as glass and aluminum. Google and LG have stuck with polycarbonate for the Nexus 5X, however, which leaves it looking like something of an ugly duckling. Despite this, die-hard Nexus fans will still be interested.
The velvety feel of the Nexus 5 was loved by many, and the Nexus 5X feels almost exactly the same. It's visibly larger, but is still easy to hold and use, even one-handed.
androidpit Nexus 5X 7
The soft, matte plastic finish is similar to the Nexus 5. / © ANDROIDPIT
The Nexus 5X is a little chubbier than the 5 too, with smoother edges, which will be pleasing to potential upgraders, as the edges of the Nexus 5 were a little too sharp. This device doesn’t exactly feel like a warm block of butter in the hand, but it's definitely grippier and more comfortable to hold than its predecessor.
androidpit Nexus 5X 3
This edge will not miss a speck of dust.  / © ANDROIDPIT
There is bad news for fans of narrow display bezels. The left and right bezels of the Nexus 5X screen are definitely wider than they could have been, and Google could have cut a few millimetres above and below the display too. As a result, the Nexus 5X looks a bit more old-fashioned than its current competition.
With its 5.2-inch display, the 5X is the smaller of this year's two Nexus devices. Its dimensions are 147 x 72.6 x 7.9 mm, so it's slightly larger than the Nexus 5, but also more slender. One aspect of its design that's been polarising opinions is the protruding camera design on the back of the phone. Whatever you think of it aesthectically, they way it sticks out means you can't lay the Nexus 5 flat on its back on a table or other flat surface.
androidpit Nexus 5X 4
You cannot lay the Nexus 5X flat on its back, thanks to the protruding camera. / © ANDROIDPIT
Its size means it's easy to reach the power button and the volume rocker on the right-hand side of the device, as well as the fingerprint sensor on the back of the device. Using this sensor to unlock this smartphone is fast and intuitive.
With all that polycarbonate, the Nexus 5X, is not a premium device like its bigger brother, the Nexus 6P. Those who want a posh smartphone should look elsewhere.
Google Nexus 5X display
The Nexus 5X display is a tried and tested Full HD number. Rather than go in for extravagant pixel adventures, like we’ve seen Sony do with the Xperia Z5 Premium and its 4K screen, Google decided on a perfectly adequate 423 ppi for the Nexus 5X screen. If you’re planning to use virtual reality glasses with a smartphone, however, the Nexus 5X wouldn’t be the best choice.
The Nexus 5X display is protected well by scratch-resistant Gorilla Glass 3. This is a sign that Google has scrimped a little with the 5X, because the Nexus 6P uses the newer, more robust Gorilla Glass 4. Too bad.
androidpit Nexus 5X 5 9
The Nexus 5X has a moderately large 5.2-inch display. / © ANDROIDPIT
The edges around the screen are slightly raised so that the screen never actually touches a surface when it’s placed face-down, which helps protect it from scratches. The screen brightness is adequate and its viewing angles are very good.
Google Nexus 5X special features
Both 2015 Nexus smartphones have a fingerprint sensor, along with native support for the feature in Android Marshmallow.
The sensor will automatically activate the first time you touch it with your finger, and setting it up takes fewer steps than other Android sensors. The unlocking process is quick, but not really any faster than on the OnePlus 2, Huawei Mate S or Honor 7.
The power cable and earphones plug in at the bottom of the Nexus 5X. / © ANDROIDPIT
The other specialty of the Nexus 5X is the USB Type-C port. This is great because you can now no longer plug the charging cable in the wrong way around. In addition, you can plug it into another device with Type-C connectivity, and recharge it directly from the Nexus 5X.
Unfortunately, Google hasn't provided the Nexus 5X with an adapter for the still-widespread Type-A connector, so that means you can’t connect it to most computers without an accessory. You can buy such a cable on Amazon for less than US$10, so it's a shame not to get one included.
Google Nexus 5X software
Along with the Nexus 6P, the Nexus 5X is the first smartphone that comes with Android 6.0 Marshmallow, making it the latest and most advanced Android smartphone you can get. Whoever appreciates pure Android will love the Nexus 5X, even though the differences between Marshmallow and Lollipop are incremental rather than revolutionary.
androidpit Nexus 5X 2
Android Marshmallow makes its debut on the new Nexus. / © ANDROIDPIT
A key advantage of the Nexus 5X great is that it is much easier to modify than other Android smartphones. You can unlock the bootloader via console commands and boot up third-party firmware and, if problems occur, you can restore your Nexus to its factory settings quite easily.
But it's worth noting that performing these kind of modifications will have an unpleasant aftertaste. Qualcomm has built a so-called QFuse into the chipset. This is a hardware function that is permanently changed once triggered by Android. Once triggered, your phone will show that it has been unlocked, and this can’t be changed by relocking it.
Google Nexus 5X performance
The Nexus 5X specs are similar to the LG G4's, but it offers lower performance. Its power is sufficient for everyday use  but is not as outstanding as the Nexus 5's was at the time of its release.
The Snapdragon 808 inside the Nexus 5X has two quad-core, power saving processors, and is sufficient for most tasks, but the phone suffers from heating problems. Its performance dropped by half after a few minutes of intensive use, according to our benchmark tests. Games began to stutter at this point too.
The Nexus 5X suffers heat problems. / © ANDROIDPIT
New to this chip is an improved signal processor. Its power-saving capabilities means that it collects performance and background services data. In addition, the antenna has been greatly improved. The Nexus 5X offers much better reception than many other test devices.
The Nexus 5X comes with 16 GB or 32 GB of internal storage. It can’t be expanded with a microSD card, meaning you’re stuck with the amount of memory you buy. The 32 GB model should be enough for most people, even those who use a lot of apps, but if you load up additional games and photos you might find that the 5X quickly becomes full.
Google Nexus 5X audio
The Nexus 5X audio is provided by one front-facing speaker. It sounds horribly tinny, but is quite loud. Google has not been stingy with the microphones, however. They are placed at the bottom, top and front of the device, so the 5X picks up sound well.
Google Nexus 5X camera
The quality of the Nexus 5X camera is pleasantly surprising. Granted, the standard set by old Nexus phones is quite low, but there's nothing to be ashamed of with the Nexus 5X's snapshots.
Image noise is relatively low and is smoothed by intelligent software filters. Dynamic range is OK and details are fairly well captured, although other cameras with more megapixels perform better. HDR gives poorly exposed images better overall color.
The selfie cam should be used in HDR mode. The front camera doesn’t have a flash, unlike the one on the Honor 7 or Moto X Pure Edition, and without flash, selfies are hard to get right.
androidpit Nexus 5X 6
Laser focus, dual-LED flash and the camera lens of the Nexus 5X / © ANDROIDPIT
Google’s pre-installed camera app has no manual mode, but has other strengths. Panoramic and Photosphere images are created as easily as with almost any other camera app and HDR mode keeps shutter speed so low that high-contrast images are not blurred. The Nexus 5X does not have dedicated OIS, but laser autofocus is a big help in getting the right shot.
The maximum resolution of the Nexus-5X camera is only 12.3 MP, but the pixels are larger than normal (1.55 microns) which ensures that they capture more light, thus producing better results, especially in poor lighting conditions. A relatively large f/2.0 aperture means that this camera is good, but falls short of the cameras on top-end Android phones this year.
Google Nexus 5X battery
The Nexus 5X battery is a slight letdown, with only a 2,700 mAh capacity. There are numerous lesser smartphones with bigger batteries; the Honor 6, Honor 7 and Alcatel OneTouch Idol 3, among others.
The Nexus 5X can run on one charge for more than a day with moderate use and can also be recharged quickly. The new USB Type-C port enables you to use the Nexus 5X to charge other devices. Wireless (Qi) charging was unfortunately left off the Nexus 5X.
Android 6.0 Marshmallow and Doze don’t provide a battery life breakthrough here. Standby time is quite good, but when you're actually using the Nexus 5X, its charge drops quickly. It takes about 80 minutes to fully recharge.
Nexus phones can charge each other, thanks to USB Type-C. / © ANDROIDPIT
We ran the Nexus 5X through an AnTuTu battery benchmark test, after charging it to 100 percent, setting it to airplane mode (with WiFi on) and the display turned up to 100 percent brightness. During the test, the Nexus 5X reached 7,465 points. For comparison, the Galaxy S6 Edge+ reached 6,659 points, Galaxy S6 Edge got 7,561, and the Moto G (2013) hit 8,352 points. Bear in mind that battery performance in real life is dependent on many different factors and isn't always accurately reflected in benchmark tests.
Google Nexus 5X technical specifications
The Nexus 5X didn’t offer much in the way of surprises. Rarely have I been so nonplussed by a new Android smartphone. As a former Nexus 5 owner, I was hoping for a serious update, or at least that the Nexus 5X would share more qualities with its predecessor.
The significant advantage you get in upgrading to a Nexus 5X is better reception, increased security and a fingerprint sensor, but it's not the only smartphone to provide that. The Nexus 5X will get three years of updates from Google, of course, but even that is no longer a unique selling point.
The pool of good alternatives — at fairer prices – has grown considerably since the original Nexus 5, and now the only people likely to buy the Nexus 5X are die-hard Google fans. To everyone else, this phone might pass by unnoticed.
Google Nexus 5X - where to buy?
Review: Samsung Galaxy S23+
Review: Samsung Galaxy A54
  • $1,199.99
  • $999.99
  • $1,799.99
  • $1,799.99
  • from $999.99
  • $999.99
  • $699.99
Go to comment (25)
Eric Ferrari-Herrmann
25 comments
    Hasantha Hathurusinghe Jul 19, 2016 Link to comment
    Nice phone Nexus 5x you will never regret
    Kaustubh Pendse Jun 24, 2016 Link to comment
    Hi I'm using Nexus 5x for last 3 months ...... I have noticed no lag till now as I'm a heavy gamer and is on wifi 24/7.....
    Well this phone has just 2gb of ram ..... but no issue ..... as it's a stock Android phone ..... also it will get Google updates than any other phone in the market.....
    I know I had to made some compromises like price and specs but just believe in me I have totally no issue regarding this phone ...... I M sure it will last for next 3 yrs easily and having same performance now after 3 yrs also which means just flawless!!!
    I will say go for it with eyes closed!!!
  • Zach 4
    Zach Dec 21, 2015 Link to comment
    me to.. i think wait nexus 7
  • R.J. Moser 1
    R.J. Moser Oct 26, 2015 Link to comment
    Erm... I think I'll wait for the Nexus 7 2015 Version.
    sangeeth kris Oct 23, 2015 Link to comment
    Google should have scrapped the 16 gb version. fine with everything else.
  • 31
    Deactivated Account Oct 22, 2015 Link to comment
    I like the design, but this is what should have come out last year and with those bezels it sort of looks 12 months old...
  • Kevin Doran 2
    Kevin Doran Oct 6, 2015 Link to comment
    This is NOT a review...... Cut it out. Stop using the word 'review', this is a 'hands on' at best
    • Joseph 2
      Joseph Oct 14, 2015 Link to comment
      Pretty sure that's why it says "Hands-On" in the title. Nearly every review site calls a first look a "hands-on" review. It always implies that it's just the first impressions after spending a few minutes with the phone.
  • Zach 4
    Zach Oct 4, 2015 Link to comment
    nexus 5x google made it by stability of phone. and nexus 6p for hight perfomance.
    J Gabri-El
  • Kobi 1
    Kobi Oct 2, 2015 Link to comment
    any word on the wireless charging ? is it still there in the new model ?
      Marcus Dickinson Nov 2, 2015 Link to comment
      No
  • Pepe Lepew 1
    Pepe Lepew Oct 1, 2015 Link to comment
    Very Nice but... I had such bad experience with LG Products my Previous Nexus 5 was truly a hardware nightmare i had issues galore with this phones and even the 3 replacements devices as every one of them had issues. not sure i will fall for that again...
    • 16
      Viktor jovanović v. Oct 6, 2015 Link to comment
      I have also Nexus have, buth I havent that problems with it like you and I trust to haw LG made it.
    Vladimir Mamzikov Oct 1, 2015 Link to comment
    I love my N5, and by my look he have more pretty and original design than N5X. Not sure I need upgrade to the new model.
    George L. Oct 1, 2015 Link to comment
    No mention of bloat ware? If this stock android has very little I'll definitely be getting one! However with the Sam G6 for around £350 in the uk atm apart from early android updates this phone is very expensive for what it offers
    Leeu Vryheid Sep 30, 2015 Link to comment
    Nexus 5x suited me fine if it came without fingerprint but with the snapdragon 810 or even 820. Fingerprint should have stayed for the top end nexus 6p.
    I own a nexus 5 and there's no reason for me to buy a nexus 5x if it comes with an adreno 418 and a hexacore. Hardware increase is only about 20%
  • Kevin G 4
    Kevin G Sep 30, 2015 Link to comment
    I was expecting the new Nexus to be an easy upgrade decision for me. Love my current N5. But those top and bottom bezels look quite big, and that makes the N5X a lot bigger than the current N5. What's more, the price! £379 for a 32GB N5X, or you can get an unlocked LG G4 32GB for £290 now (The brown leather version too). Is the G4 a better phone? If I can live without fingerprint scanner, does anyone have an objective opinion on what LG's UI is like? I liked having the stock experience, but looks like I'll be playing £100 more for that and a fingerprint scanner, and a phone that in some ways is inferior to the G4. Any advice?
    sangeeth krismehulpatel
    • Andrew B 2
      Andrew B Oct 3, 2015 Link to comment
      I have recently switched from Samsung GS4 to the LG G4 (after like 4 samsungs in a row) and the UI is much less obtrusive than touchwiz. that being said, I don't totally use it. I installed the Google Now Launcher, and I get almost a vanilla Android Experience with the whole interface except the lockscreen and settings menus. I was a CyanogenMod user on all my samsungs because I hated the UI interference with touchwiz. I will say that I could actually deal with the Optimus UI as it sits, but I am just so used to the stock launcher at this point I thought it to be an obvious next step. So if you want better specs, a better screen, the ability to expand your storage, and the possibility of swapping batteries in a high drain situation, get the G4. If you like to stock experience that much, then get the Nexus 5X, as I think they are both good phones.
    Greg Moffat Sep 30, 2015 Link to comment
    Rather like the look of the new nexus 5x, maybe a little bland. Only comes in 16 or 32gb and not stereo speakers according to Google store. Would have preferred 64gb, ois for photo and video, dual front speakers (as in HTC one series) and amoled display.
    sangeeth kris
  • David Mendívil 2
    David Mendívil Sep 30, 2015 Link to comment
    there is a problem with the article
    " The Nexus 5X price is set at US$379 (£339) for the 16 GB model and US$429 (£379) for the 64 GB version."
    But the table shows 16 and 64 GB, could you clarify it? thanks!
    Scott Adam Gordon
    • Scott Adam Gordon 31
      Scott Adam Gordon Sep 30, 2015 Link to comment
      Well spotted. 32 GB **** Corrected. Thank you!
    J Gabri-El Sep 30, 2015 Link to comment
    This phone is going to be fire. No doubt!
  • Dylan S. 11
    Dylan S. Sep 30, 2015 Link to comment
    I think the nexus 5x is a going to be a great phone but I believe Google should have created a nexus somewhere in between with a combination of what people like about the nexus 6 and 5.
    • Andrew B 2
      that wouldnt make financial sense. this is the first time that they have even given an option of 2 choices anyway. the specs arent that different that a middle ground would have any chance of making any money for anyone involved. splitting the market is not the smartest thing to begin with, diluting it with too many choices is self deprecating.
    • Zach 4
      yes u righ bruh. must have reason why google make it n5x
