Common Nexus 5 problems and how to fix them
androidpit nexus5 problems 16
Now that the Nexus 5 has made the jump to Android 6.0 Marshmallow it's time to take a look at some of the issues the update brought with it and how to fix them. No Android update is perfect and, as always, there is no shortage of Android Marshmallow problems to work through following the jump to Marshmallow. Let's take a look at some common Nexus 5 problems and how to fix them. As more people get Marshmallow on their devices, we'll add to the list of solutions and workarounds.
How to fix Nexus 5 Android update problems
The problems below generally relate to the latest version of Android, but some are persistent bugs that have carried over from older Android versions. The solutions will be the same for whichever version of Android you're using, however.
Solutions to Android Marshmallow problems should work for the same problems in Android versions too. / © ANDROIDPIT
But keep in mind that some bugs will have been patched in later Android releases, so make sure you have the latest firmware available for your device before you try anything else. Go to Settings > About Phone > Software Update to check whether there's an update available.
Jump to a specific Nexus 5 problem and its solution by hitting the links below:
But first, back everything up
As always, you should always make sure you have a done full backup before you start troubleshooting Nexus 5 problems. You can follow our guide on how to back up Android or make use of Google's default backup option, which can be found in the settings under Backup and Reset.
androidpit nexus5 problems 14
The Nexus 5 is to battery problems what peanut butter is to jelly: inseparable. / © ANDROIDPIT
Nexus 5 battery drain
As with all Android updates, battery drain is usually the most immediate problem you'll have to deal with. So if you're suffering Nexus 5 battery drain following the update to Marshmallow, never fear. You're not alone. Fortunately the solution is quite simple.
You have three options: clear your app cache, clear your system cache or do a reset. These are guaranteed to clear up any Lollipop leftovers that might be causing excess battery consumption. The first step is to clear your app cache. To do this you can go to Settings > Storage and USB > Cached Data > OK.
androidpit nexus5 problems 2
The first cache you should clear is the app cache. / © ANDROIDPIT
If your Marshmallow battery drain persists, the next step is to clear the system cache. Turn your Nexus 5 off, press and hold Power and Volume Down to access the Fastboot menu and use the volume buttons to highlight Recovery Mode. Press Power to select.
You'll see the robot with No Command beneath it. Hold Power and press Volume Up once to access Recovery Mode. Use the volume buttons to highlight Wipe Cache Partition and press Power to confirm. Highlight Yes and press Power again. Once you've wiped the system cache you can reboot.
androidpit nexus5 problems 3
The next stop is your Android system cache. / © ANDROIDPIT
If you're still having Nexus 5 battery problems after the cache wipes, your next step is to back up all of your important data – you can follow our guide on backing up Android – and then do a factory reset, either through the Backup and Reset section in the Settings or via Recovery Mode. Then just restore your apps and data and your battery drain problems will be history.
androidpit nexus5 problems 4
A factory reset is the one solution to rule them all. Just back up first. / © ANDROIDPIT
Nexus 5 Wi-Fi problems
Another staple of the Android update problems buffet is all-you-can-eat Wi-Fi connectivity problems. This was a very common Lollipop problem and an equally common KitKat problem, so it's par for the course. If your Nexus 5 Wi-Fi connection is not stable or won't connect at all, there's a few things you can do: toggle Airplane Mode on and off, forget and reconnect to your Wi-Fi network, toggle mobile data on and off, or reboot your phone.
androidpit nexus5 problems 8
You might be surprised by how much toggling Airplane Mode can solve. / © ANDROIDPIT
Another possible solution is to change your Wi-Fi frequency from automatic to either 2.4 GHz or 5 GHz in the Advanced Wi-Fi Settings on your device or to change the frequencies on your Wi-Fi router.
  • Enter your router address into a web browser on a device that's connected to it (usually 192.168.1.1 or 192.168.0.1).
  • Enter your router login details (you can find a long list of default router passwords here)
  • Each router varies, but you'll want to go to the Wireless settings menu (possibly by clicking through Settings or Advanced Settings first), choose the 2.4 GHz or 5 GHz band, then select a channel
  • As a general rule, channels 1, 6 and 11 tend to work well, while channels 12 and 13 are best avoided.
androidpit nexus5 problems 5
Try switching the Wi-Fi frequency on your phone and router. / © ANDROIDPIT
Nexus 5 stability issues
If your Nexus 5 is behaving weirdly after an update, you first need to identify the source of the problem. Work your way through the list of fixes here and see if clearing the cache, looking for the culprit in your installed apps or rebooting solves the problem. If they don't you need to figure out what to blame for your Nexus 5 stability problems.
To see if an app is causing the problem, boot into Safe Mode – easily accessible by long-pressing the Power button and then long-pressing Power Off. Safe Mode disables all downloaded apps so you're only working with what Google gave you and nothing else.
androidpit nexus5 problems 6
Safe Mode will help you diagnose either apps or Android as the source of a problem. / © ANDROIDPIT
If your problems disappear in Safe Mode you know it's an installed app problem and not Marshmallow-related. The next step is to reboot again (to exit Safe Mode) and then systematically disable apps to find out which one is causing the problem.
If the instability isn't app-related you can start with a reboot. Turn your Nexus 5 off and wait for a minute before turning it back on. If that doesn't help follow the steps in the battery drain section for clearing cache. Your last solution is to factory reset your Nexus 5 or manually install Android Marshmallow.
Nexus 5 won't charge
Android 6.0 Marshmallow is intended to deliver prolonged battery life to the Nexus 5 and for the most part, it does. But strangely enough, charging has become a bit of an issue for some users following the Android Marshmallow update.
androidpit nexus5 problems 12
Charging problems seem to be plaguing Nexus 5 phones on Marshmallow. / © ANDROIDPIT
Google's solution to this problem is to do a factory reset, but before you go to that extreme you can try a few of our general charging tips to make sure it isn't related to something else:
If none of these general guides help you out, you should also try to calibrate your Android battery before doing a factory reset. Having said this, a factory reset is nothing to be scared of. It is a very useful technique for maintaining good smartphone health. As long as you back up first you've got nothing to lose and everything to gain.
androidpit nexus5 problems 7
If your battery is behaving strangely, you might need to calibrate your battery. / © ANDROIDPIT
Nexus 5 Bluetooth problems
Just like Wi-Fi connectivity, Nexus 5 Bluetooth problems generally rear their ugly head following most Android updates. The solution here is about as scientific as it is with Wi-Fi problems: toggle things on and off, forget and re-add connections, jump into Airplane Mode and back out again, and generally just fiddle about. Nine times out of 10 that will solve your problem.
androidpit nexus5 problems 9
Updates frequently wreak havoc on Bluetooth connections too. / © ANDROIDPIT
If you're still having Bluetooth connectivity problems, either dropouts or problems connecting in the first place, then you might want to contact the maker of your Bluetooth device to see if it might be related to any associated software. Occasionally all you need is an update to the drivers to solve the problem, depending on the type of Bluetooth device to which you're connecting.
Nexus 5 lags on Marshmallow
If your Nexus 5 lags on Marshmallow, the best thing to do is back up your data and do a factory reset. Some problems are worth fine-tuning, while others require the carpet-bombing approach. Doing a factory reset after a major Android update will clear up 99 percent of the problems that commonly plague users.
Lag or excessive battery drain are so detrimental to your Android experience that doing a reset is definitely the best option. Simply follow our guide on how to create an Android backup and then go to Settings > Backup and Reset > Factory Data Reset > Reset Phone. Once your Nexus 5 has been wiped and restarted, you can restore your apps and data and enjoy a lag-free Marshmallow experience.
androidpit nexus5 problems 11
Lag means general slowness when launching apps or navigating Android. / © ANDROIDPIT
General Nexus 5 problems
If you don't know what's causing your Nexus 5 Marshmallow problems, then there are a few things you can try that might help. First up, turn your phone off for a minute and then turn it back on. Toggle Airplane Mode on and off. Forget and re-add Wi-Fi and Bluetooth connections. Calibrate your Android battery.
Try Safe Mode to see if an app is the culprit. Make sure your apps have all been updated since you updated your Nexus 5 (there are lots of Marshmallow-specific updates coming out for apps at the moment). Try disabling or uninstalling apps systematically to rule app problems out.
androidpit nexus5 problems 13
If you have no idea what's wrong you can still run through some common solutions. / © ANDROIDPIT
Next, try to clear the app cache and the system cache (as outlined in the battery drain section). If neither of those works you can try a factory reset. If that still doesn't help you can manually install Android Marshmallow on your Nexus. If you're still at a loss you might have a genuine Google problem on your hands that will require an official patch to solve.
What problems are you experiencing? Have you found any other solutions to these Nexus 5 problems?
Review: Google Pixel 7
Go to comment (60)
Kris Carlon
Kris Carlon
60 comments
    Floyd3000 Mar 14, 2019 Link to comment
    Google usage and diagnostics turning off automatically when I back out of the page and return to see it turning on in front of my eyes . what's up?
    Google usage and diagnostics turning on/off automatically I can visually see it returning to the page. What's up?
  • parthasarathy srinivasaraghavan 1
    parthasarathy srinivasaraghavan Aug 9, 2018 Link to comment
    My Google Nexus 5 is not booting and messaging " unfortunately UI has been stopped" Please let me know how to fix this problem
    mehr Jul 14, 2018 Link to comment
    hi,my nexus 5 can not turn on?
  • Anker Yang 1
    Anker Yang Nov 20, 2017 Link to comment
    It is good and I have written another article about how to fix Nexus 5 Wi-Fi Problems, learn more here:etradesupply/blog search fix Nexus 5 Wi-Fi problems
  • Mohamed Busneina 1
    Mohamed Busneina Jul 9, 2017 Link to comment
    I am facing battery drain problem, and I am trying your solution, I'll let you know if it worked with me ,, thank you
    • Brittany McGhee 21
      Brittany McGhee Jul 12, 2017 Link to comment
      Thanks, Mohamed. We look forward to hearing if it worked for you.
  • Bob McArthur 1
    Bob McArthur May 10, 2017 Link to comment
    my Nexus5 is locked on the opening screen {firmware update} and it was plugged in for 12 hours. the screen is locked and on/off ,volume + / - are both locked . HELP what is going on?
    Shoiab Mohammed Mar 21, 2017 Link to comment
    I am using nexus 5 for 3 year,but the wifi wont turn on do you have a solution for it
    I have tried rebooting,format,turning wifi on and off
  • Ġorġ Sciberras 1
    Ġorġ Sciberras Dec 15, 2016 Link to comment
    Having a problem with Photos. There is something that stops me viewing my photos. Notice pops up at random.
    Uma Narasimhan Sep 16, 2016 Link to comment
    Hello everyone!!
    I have been using nexus 5 for past 2years . First i faced the problem of power button.. from oct 2015 whenever I touch power button it reboots automatically. So from then I didn't use power button ( increased my display timing) . Now I'm facing a different problem.. my volume button keeps appearing on my screen ..even though I didn't touch it. Quite annoying as I'm unable to watch Facebook or movies. Can anyone help me with this issue?
  • Bruno Cunha 2
    Bruno Cunha Jul 20, 2016 Link to comment
    The Power button and the vol down works. But after "You'll see the robot with No Command beneath it. Hold Power and press Volume Up once to access Recovery Mode" does not work to get back to recovery mode. I'm with the latest update
    Taha Kidwai Jun 16, 2016 Link to comment
    Hey have u guys noticed overhrating problem on nexus 5. It overheats when i play high graphic game Please suggest any solution for it
  • LaftanZa 1
    LaftanZa Mar 1, 2016 Link to comment
    The power button has a manufacturing fault and it sometimes gets stuck and the phone keeps rebooting!
      ZrillexZ Mar 4, 2016 Link to comment
      yeh, my nexus keeps on turning off when i'm in the middle of doing stuff, do you know if there is a fix or do you think i should be looking into a new phone?
      • 16
        Viktor jovanović v. Apr 4, 2016 Link to comment
        Yry to clean cashe and uninstal some apps which you don't need to get more storage.
        I slso have Nexus 5 2013 and haven't any problems with it. Good lyck.
  • Priya Surana 1
    Priya Surana Feb 27, 2016 Link to comment
    Hie all
    I am using nexus 5 since last 1.5 yrs. But from last 20 days my phone is not catching 3g, although airtel 3g recharge has been done. Also network dropping issue is there. I have done everything. factory reset, network reset, preferred network -3g, LTE, Flight mode on off....... but its s till 2g. though my sim is working finr in other phones, connecting to 3g and no connectivity issue. But in nexus 5 its not catching 3G. Can anybody help me in this?
    Needhi Feb 17, 2016 Link to comment
    Hi
    I have been using Nexus 5 since more than 1 yr ,suddenly my phone got switched off , checked with LG gallery , they says it's a mother board issue , only solution is the replacement of mother board , which cost around 13000
    How can it happen all of a sudden
    Really upset with it
    Kindly suggest what can be done
      Sandeep Arya Apr 4, 2016 Link to comment
      I am having US made motherboard which I will give u for Rs 7000. Contact no is 9911033522.
  • Kayla 1
    Kayla Feb 16, 2016 Link to comment
    What about boot loop???
    Jasmine Montez Feb 11, 2016 Link to comment
    You forgot to add that it constantly reboots because of the faulty power button
    LaftanZa
    Vinay8484 Dec 27, 2015 Link to comment
    I bought nexus 5 in nov 2013.Recently updated with latest 6.0.1.
    Now days this device getting me nervous as anytime it got hanged and when restart shows 2-5% battery.
    How? I was using camera, clicked some pics , phone got hanged and power off automatically when i restarted it shown me 2% battery.i came back home when i put phone in charge in 10 min it shows me same % battery which was before switch off. Means 53%. I checked it many time. I am facing this problem from last 10 days. I am afraid to carry my phone as it can switch of any time and you are helpless untill u connect it with charger.Google Android team , pls do something.
  • Ron Simpson 1
    Ron Simpson Dec 8, 2015 Link to comment
    I had the same problem with my Nexus 5 but doubted if it was a software problem as the same upgrade worked fine on my Nexus 7. I used the fix shown on this You Tube video and it solved the problem both on the mic and the speakers. I recommend it. Sorry the forum is preventing me from posting a link but you should be able to find the video under this reference.
    Fix the Nexus 5 Microphone! (Hack #3)
    Hem Chandra Nov 30, 2015 Link to comment
    I have problem with my camera on nexus 5 which shows cannot connect to camera. This problem arouse after updating my phone to marshmallow. I have to restart my phone everytime I use my camera to work .
    • Jonathan Vergucht 1
      Jonathan Vergucht Dec 27, 2015 Link to comment
      It's not a Marshmallow problem. I have this too and already in Lollipop. Flashlight doesn't work anymore after 20 sec at most. Works only back when restarting. Or there is some app interfering with it or there is a hardware problem which occurs after a time.
    I have an issue with network. My phone shows no network for airtel and DoCoMo but it can recognise Bsnl or idea networks. It used to recognise the networks before I updated to marshmallow. I also checked the sim on other phones which could recognise the network properly.
    Waldo MacTavish Nov 29, 2015 Link to comment
    I have an issue on my n5 with Android marshmallow, when let it block for an hour the phone always turn 20 min or 2hours back, a few days ago when o woke up the phone had 2h and 12 delay since I updates I had that problem, someone know something about it ?
    manjunath Nov 24, 2015 Link to comment
    I am using LG Google Nexus5 from last 1.5years, the mobile is working very good. but from last 1 week it is going shut down mode automatically, this is happening frequently, Kindly suggest what i can do to fix this issue ?.
    Nayara Parveen
    • 16
      Viktor jovanović v. Nov 25, 2015 Link to comment
      I'm using Nexus 5 6.0 too, buth havent eny problems like you. Try to clean cashe, turn it of and restart again.have you any secure on phone?
      If you havent try with AMC Secure, it clears automaticaly cashe too.
      Nayara Parveen Dec 18, 2015 Link to comment
      I have the same issue as Manjunath. I too using Nexus 5 from last 1.5 years.
      I think it is happenjng in india. Same problem i'm facing.
        john Jan 29, 2016 Link to comment
        hello guys,
        can u suggest me a fix, as i m experiencing same from past few days.
        thanks in advance.
    Richard Ellis Nov 12, 2015 Link to comment
    It time to address the no speaker sound issue with nexus 5 after the 6.0 update.
    mikep
    • mikep 1
      mikep Nov 18, 2015 Link to comment
      Well, I've got the same issue on my 5X
      • Onder Secen 1
        Onder Secen Apr 19, 2016 Link to comment
        I have the same problem
    Hector Suarez Nov 9, 2015 Link to comment
    No active Wi-Fi and Bluetooth, it remains in activation process and apparently wears the battery, it does not allow to disable them. I already reestablished to factory settings and I did deep cleaning from the bootloader, this happened a moment to another.
    Sunil Sareen Nov 9, 2015 Link to comment
    I hv switched from IoS to google nexus 5X 32GB recently. Not able to locate pictures saved from google chrome anywhere on my mobile. Could you please suggest issue/solution.
    Anthony Jones Nov 1, 2015 Link to comment
    My phone could not register any wifi routers and I ended up doing a factory reset but that did not work and now my data won't come on. It comes on randomly for about a minute and then it's gone even when I put it on airplane mode.
  • Steven Braithwaite 1
    Steven Braithwaite Oct 30, 2015 Link to comment
    After the backup, shouldn't you copy the file to PC before doing the factory reset?
    I'm assuming that the backup file will be deleted... So how can you then restore?
    Deactivated Account Oct 28, 2015 Link to comment
    I am currently going back and forth with Google Play support regarding poor audio quality during video recording. I had it on one device, RMA'd it with Google, and it still occurs on the replacement device... even after factory reset and in safe mode. Here are the samples compared to iphone 5s recording the same scene at the same time.
    Copy and Paste with http prefix (sorry it website won't let me post a link)
    drive.google.com/open?id=0Byi1C-MrlLo4Yll5RENfbkk5NW8
    Henk Oct 21, 2015 Link to comment
    My issues:
    - Data cannot be accessed from a PC (for example photos);
    - Keyboard does not appear most of the times;
    - Problems with an app losing information (this could of course need to be fixed in the app);
    - Even when wifi network is available it is not conecting automatically.
      Lucas Oct 27, 2015 Link to comment
      Hi Henk,
      Regarding you data access from PC, after plugging your phone to USB port, your phone being unlock, when sliding down the notification displey, you should see a message " USB for charging connect - Touch for more options", that will allow you to choose "MTP" option and let you acces your data on your PC again.
      Hope that it will help.
        Annitha Nov 28, 2015 Link to comment
        Hey Lucas, my nexus is doing the same thing however, even if I select MTP option, I am still unable to see my DCIM and Picture files. The folders are empty
    Dominic Lalonde Apr 2, 2015 Link to comment
    Nexus 5 with Videotron, since the last update (2 weeks ago) to lollipop 5.1 When I send pix by SMS the person at the other end will receive it several times continuously and my phone will send me an error message mentioning that the picture was not sent (even if the receiver got it several times). I then, have to erase the conversation. It does that everytime. And also my app Hangouts will crash every hour or so.
    Any solutions ??
    Niner604 Mar 22, 2015 Link to comment
    The issue I have is that my mic stopped working shortly after the Lollipop upgrade. The 5.1 update didn't fix it. Basically, the person calling me can't hear me. Even the "Okay Google" command doesn't work. Only if you connect a headset with a mic or a Bluetooth earpiece that you can actually use the phone feature. Apparently, this is a common issue with many Nexus 5 users, yet there still is no fix. Strange how an OS upgrade disables the primary function of a cell phone... It's mic! I'm hoping this gets corrected soon. I'm planning to try to downgrade to Kit Kat a try to see if that works. If anyone has any helpful tips, please let us know.
    Afreen FirdousFrank NeulichedlPaulWAlexítron3030
      Nizar Al Mar 24, 2015 Link to comment
      I have the same problem, it works when put it on speaker phones and headset. hopefully they fix it ASAP.
      Alexítron3030 Apr 4, 2015 Link to comment
      I have the same problem, i can only get it to work if I am on loudspeaker.
    • Frank Neulichedl 16
      Frank Neulichedl May 12, 2015 Link to comment
      I've encountered that problem also with the Nexus 4 ... it seems like an OS problem more than a device problem.
    Kim Johansen Jan 28, 2015 Link to comment
    I have this problem that my battery sometimes won't charge fully, even though it is charging all night. Apparently this is only when my original cover is closed. It appears that I when I don't shut my cover during the night it does charge fully. Does anyone else have this issue? What can I do to try and fix it?
    Rafael Lucas Jan 23, 2015 Link to comment
    And to fix lollipop touch screen issues, which doesn't reponse correctly when is charging?
    Gowdham K Jan 23, 2015 Link to comment
    I bought Nexus 5 last month. Right now i am facing issues in cellular network getting dropped frequently. I have choosen LTE (Recommended) in Preffered network option followed my switching off and On my device. But its of no luck. I dont have the APN settings. During the availability of network i have seen the APN settings.
    Is the problem is with my handset or network ? Please advise as i bought it recently only :)
    IShop BD Jan 20, 2015 Link to comment
    Very nice post. More discuss this matter welcome to our www.ourschat.blogspot.com
    Vinay8484 Mar 12, 2014 Link to comment
    I bought it when google started N5 distribution in india. Problem increasing day by day now.
    1- battery drain
    2- Heating issue
    3- speaker less sound
    4- Heating issue
    5- Camera issue . its shows cant open camera app
    I think google should start working on replacement of initial launch devices.
    • 10
      Jack Smith Jan 20, 2015 Link to comment
      Maybe not all initial devices! My "day after release" Nexus 5 didn't had any hardware problems, my Nexus 6 also :) maybe im lucky or the initial devices in switzerland aren't that buggy?!
    Dhruv Kumar Mar 1, 2014 Link to comment
    Hi,
    I did it , what you told to do for wifi ? still wifi is not working.......can u give me some other tips
    Which should work on Nexus 5 mobile.
    Thanks In Advance
    Dhruv Kumar
    Dakota Simpson Jan 25, 2014 Link to comment
    I recently got a N5 from a GNex. Its interesting as I keep reading about battery issues and Ive found my battery life is miles ahead of the old phone. My GNex and my Android phone before that was horrible. Even with minimal use, I could never even get past 2 or 3pm before it died. While the speakers on this phone still aren't great, they are substantially better than the GNex…and Ive found the screen so bright that when Im at home, I have to put it on 3% so it doesnt hurt my eyes. The location battery saver settings seem to work too and I don't find that affecting any apps
    I do keep having problems with the camera and gallery…and I hate Hangouts and the forcing of Google Plus on everything when I don't use it. And don't want people being suggested to me to text when I don't know any of them.
    I also wish they would let GOOGLE NOW work with more than 1 Google account. I have one personal/casual and one professional and thus don't get information with both
    Clive Jan 23, 2014 Link to comment
    And other failures like my Nexus 5 (4.4.2) Bluetooth won't pair with any other devices (hands free car kit, Sony Smartwatch). When is Google going to fix it's failures?
    Sander Schaeffer Jan 22, 2014 Link to comment
    I'm missing the category Gps hardware failures.. Which plague alooooottt of Nexus owners
      Nathan Yang Jan 30, 2014 Link to comment
      Yep. The rattling power button and GPS issues were common in the first batch of Nexus 5's released (mainly those ordered on the first day). Anyone seeing those problems should've RMA'ed their device.
      • 10
        I have (had,now N6) first batch Nexus 5. recived mine a day after release and didn't had ANY problem expect the Google Play Services Battery Drain bug. Only when gps on and this is on all devices i tested!
