Nexus 5 camera tips: 9 ways to take better photos
androidpit nexus 5 hd 02
The Nexus 5 is a great phone, its camera, not so much. With an 8 MP sensor, an aperture of f/2.4 and optical image stabilization, it sounds like a recipe for perfect photos, but the results don't back that up. These tips and tricks will help your Nexus 5 camera achieve its full potential.
1. Update Android
Make sure you have the most up-to-date version of Android. The Nexus 5’s camera was plagued by a number of issues at launch, but many of them were fixed in subsequent updates. Lollipop, in particular, improved things by enabling support for RAW image files in compatible camera apps. RAW images are photographers’ favorites because they don’t process the image or compress it like a JPEG does.
AndroidPIT google nexus 5 screen comparison
From sunsets to selfies, upgrading Android massively improves the Nexus 5 camera. / © ANDROIDPIT
2. Turn on HDR+ mode
If you set your default camera mode to HDR+ (you can do that by opening Google Camera, bringing up the menu and selecting the HDR+ option in the middle) you’ll see an immediate difference in your photos. The contrast, motion blur and low-light performance all improve, and there's little in the way of negative side effects, bar a very slight drop in battery life. We’re sure you’ll think the difference is worth it.
android 4 4 1 nexus 5
HDR+ mode combines multiple shots into a single image. / © Google
If you’re wondering what HDR+ is doing, it’s taking a burst of photographs with slightly different settings and then combining them to get the best picture – so it might take the best shadows from one picture and the best highlights from another to produce an image that’s more balanced than either.
Nexus 5 camera sensor
The Nexus isn't really designed for low-light shooting but HDR+ mode helps. / © ANDROIDPIT
3. Turn off the shutter sound
We’re not against shutter sounds, but it’s a shame that the bad behavior of a few creepy smartphone users mean that the rest of us can’t turn them off. Why can’t we snap a surreptitious shot of somebody who looks really silly without letting them know we’re doing it?
While shutter sounds are generally hard-wired, you can still mute them on the Nexus by muting your entire device, plugging in headphones, using a third-party app that doesn’t make a noise or by renaming your camera sound file. That last option for how to turn off the Nexus 5 shutter sound requires rooting.
4. Clear the cache if it crashes
As our very own Scott Adam Gordon writes, clearing the app cache is probably “responsible for fixing around 98 percent of all smartphone problems”. It definitely helps if the camera app suddenly stops working. Go into Settings > Apps > All, find the camera app you’ve been using, tap it and then select Clear Cache. Do the same for the gallery app if that doesn’t do the trick.
5. Take a photo while filming video
You’ve upgraded to Lollipop, right? Then you can take a photo mid-shoot by tapping on the screen, while continuing to recording your video.
6. Explore Google Camera’s options
If you stick with the Google Camera app you’ll get some nice photos, but they’ll be nicer still if you tweak its settings. Swipe from the left and hit the gear icon in the top-right corner (or the bottom-right if you’re holding the phone in portrait mode) to go into Settings and change Panorama Resolution to Maximum and Lens Blur to High. Your panoramas and blurs will take a little longer to process, but they’ll look a lot better.
GoogleCamera Teaser
Google Camera is great, but its options can make it even better. / © ANDROIDPIT
7. Try L Camera
That’s L Camera, of course, the experimental and excellent Android camera app that enables you to explore the possibilities of the latest Android camera API. It delivers manual focus, manual exposure and ISO settings, DNG output (a RAW format that’s becoming popular with snappers) and 30 fps full-res, 60 fps 1,080p res and 120 fps video at 800 x 600. You don’t need a rooted phone to use it unless you intend to try the 60 fps video, which requires modification of a system library on the Nexus 5.
lcamera
L Camera unleashes Lollipop's SUPER MEGA CAMERA POWER! / © PkmX
8. Shoot under better lighting conditions
The Nexus 5 camera was designed for easy point-and-shoot operation, and while that’s great it doesn’t suit everybody: its maximum shutter speed isn’t very long and that means it struggles a bit in poor lighting conditions. HDR+ mode helps a bit and the flash can cast a bit of a glow in close-up shooting, but there’s no substitute for good lighting.
9. Try third party apps
There are lots and lots of camera apps out there, many of which specialize in things that the default camera app doesn’t do very well. The right app really depends on what you want to do, but we’d recommend checking out the excellently named A Better Camera, the time-lapse app Lapse It and the sharing-focused VSCO Cam.
${app-com.almalence.opencam}${app-com.ui.LapseIt}
vsco cam app teaser
VSCO Cam focuses – sorry – on image sharing. / © ANDROIDPIT
Do you have a favorite camera app for the Nexus 5 or does Google Camera tick all the right boxes? Any top tips we’ve missed? Let us know below!
Review: Google Pixel 7
Go to comment (9)
Gary Marshall
Gary Marshall
Freelance writer
9 comments
    Steve McIlree Nov 3, 2015 Link to comment
    I have been extremely satisfied with the results I get with my Nexus 5 camera using the Camera FV-5 app. It gives the user the same control over camera functions which are found in DSLR cameras, including DNG output. I have been quite happy with the pictures I've taken using this app, and I'm delighted they fit the same Lightroom workflow I use with shots from my DSLR. Although limited to still photo capture, the developer also offers the Cinema FV-5 app with delivers increased functionality for video.
    Rama Feb 8, 2015 Link to comment
    Camera 360, this app works better for nexus devices.
    Vicky Feb 6, 2015 Link to comment
    No lag so far, not even a single glitch since last 7 months. that makes me a proud owner of Google nexus 5. Accept it or not it is the most talked about device on android pit and everywhere else :)
    Ankit Rami Feb 5, 2015 Link to comment
    Hi friend first I installed freedom but don't open my play store then after me hard reset but no solution plss u support me for that how continue play store anyone plss
    uday vallabhaneni Feb 5, 2015 Link to comment
    I'm using nexus 5 with Android 5.0.1 lollipop version. I have a problem with Google camera when it is opened it shows the alert can't connect to the camera. May i know what is the reason to get the alert is there any issue with the lollipop or any problem in my phone i don't know.For previous version kitkat also i got the same issue. Can any one please help me regarding this.
      Paarthu Feb 5, 2015 Link to comment
      Reboot ur device.
      It will give instant solution..
      Get into safe mode if still problem persists then remove all third party apps especially 3rd party camera apps..
      Now u vl be solved..
        uday vallabhaneni Feb 6, 2015 Link to comment
        Thanks for your suggestion i did the same thing but again it shows the same issue. And i don't have any third party camera apps.
      Honza H Feb 5, 2015 Link to comment
      it's bug in Android 5.0.x related to RAM usage. Reboot will give you a temporary solution.
      Google announced Android 5.1 today and RAM overloading problem is on the list of solved issues.
        Thanks for you valuable suggestion. I'm also waiting for the 5.1 update
