LG G5 problems and solutions: get more G-force
AndroidPIT lg g5 friends 0360
We called it The Modulator: the LG G5 is designed to be physically flexible, with modules you can pop in and out to change the phone’s powers. It’s clever stuff but like any smartphone the LG G5 can also suffer from the odd bug or irritation. Here are the most common LG G5 problems and solutions.
LG G5: unable to download the latest Nougat update
Have you received the update notification announcing the arrival of Android 7.0 Nougat but haven't been able to download the 1272.9 MB package for the simple reason that the dedicated download screen button has disappeared? We found out we had the same problem. To resolve this issue, change the date and time on the device and set it to the automatic start of the specified download period. Restart your LG G5 and you should now be able to proceed with the download. In some cases, it is necessary to repeat the operation, but it is an effective way of getting around this problem.
AndroidPIT lg g5 0806
The corners should be dark when the screen is. If not, you may have a hardware fault. / © NextPit
LG G5: display problems
The backlight’s too bright in the wrong places
Some early models of the LG G5 suffered from “backlight bleed”, which is where the backlight is overly bright and light bleeds into the display, especially at the corners. There’s a free app you can install to check your device, but if your G5 is one of the affected ones it’s a warranty job and should go back to the shop.
${app-com.joeleveque.backlightbleedtest}
It’s worth asking about bleed if you’re considering a second hand G5 on eBay or from an Amazon marketplace seller: you want to be certain that you’re not buying an affected G5.
androidpit lg g5 2
The proximity sensor should know when you're holding the phone to your face. If it doesn't, your screen may stay off after calls.  / © NextPit
The screen misbehaves during or after calls
There are some known issues with the proximity sensors in some LG G5 devices. Its job is to tell when you’re holding the phone to your face and turn the screen off, but users with screen protectors report that it thinks you’re still holding the device up when you’re not. As a result, you can’t access features during calls or when a call is over - the screen stays off.
To resolve this issue you can:
  • Remove the screen protector
  • Download the AIDA64 app to confirm the sensor is functioning normally
  • Recalibrate the sensor by typing *#546368#*model number#
  • Now go into Device Test > SAAT > Service Menu Manual Test > Key Press Test > Call Start
lgg5
Battery problems? Make sure you're not running features you don't need. / © NextPit
LG G5: The notification LED is flaky
Multiple users report the LED staying off when it should be telling them about incoming messages or third party app notifications. If your LED is doing the same:
  • Go into Settings > Sound > Notification LED
  • Make sure the switch is set to on for notifications
  • Then just simply select the notifications you want the LED to flash for when you receive them
If you have already activated them, try turning them off again and then restarting your phone.
AndroidPIT router wifi 2
Wi-Fi issues? Reboot this first. / © NextPit
LG G5: the Wi-Fi isn’t working
This is one of the most common smartphone issues, and our initial reaction is to blame - and to reboot - the Wi-Fi router. But if that isn’t the villain, try switching Wi-Fi off and on again, and if that doesn’t work go into Settings > Wi-Fi and forget the network before joining it again. If that doesn’t fix it, have a look in your power saving settings: they can disable Wi-Fi as your battery gets low.
It’s a similar process with Bluetooth connectivity problems. Unpairing and re-pairing devices often solves erratic connection problems.
androidpit lg g5 23
The LG G5 doesn't use an app drawer, although you can bring one back if you like. / © NextPit
LG G5: the app drawer isn’t there
That isn’t a bug: it’s a feature. Apps go to the home screens, not the app drawer, but if you miss the old way of doing things:
  • Go to Settings > Display > Home Screen > Home
  • Select EasyHome to recover your app drawer
The main downside to retrieving the app drawer this way is that it also makes the text bigger. If you don’t like how that looks, you might be better off with a third party app launcher.
androidpit lg g5 3 w782
The LG's battery is swappable, but you shouldn't need a spare for everyday use.  / © NextPit
LG G5: the battery drains too fast
If this is a recent development then the culprit is probably a rogue app.
  • Go into Settings > Battery & Power Saving > Battery Usage
  • Have a look to see which are the hungriest apps
  • Adjust the individual settings for your apps to reduce the amount of battery they take up
If the battery drain has been constant since day one, you may just be driving the G5 too hard. Have a look in the notifications to see if there are features running that you don’t need, try turning the display brightness down a bit and tweak the power saving modes in Settings > Battery & Power Saving. You can also turn off features such as Always On and services like GPS and Bluetooth, as these can also push your battery usage over the edge.
androidpit lg g5 9
Are you getting static instead of Spotify? Playing a file might fix it. / © NextPit
LG G5: headphone jack makes a terrible noise
Some users have encountered noisy static from the headphone jack when they plug in headphones or an AUX cable.
First of all, try a different set of headphones or a different cable, and if that doesn’t solve the problem try connecting when the G5 isn’t connected to a power outlet: the issue seems to be more common with phones that are also charging. Failing that, you might find that opening Music to play the Life’s Good Hi-Fi track temporarily solves the problem - although it only does so if the Music app wasn’t the source of the static in the first place.
Have you encountered any problems with your LG G5? How did you fix them? Share your experiences in the comments below.
Go to comment (3)
Angela Palmer
Angela Palmer
Working Student
Originally from Australia, Angela has a deep-seated interest in technology. She relocated to Berlin in July 2015 to study for a Masters degree at the Hertie School of Governance, where she studies Public Policy. Whilst being at AndroidPIT satisfies her need to keep up with the latest developments in all things Android, outside of work you'll most likely find Angela travelling, reading, fencing or studying - of course.
3 comments
    taher Feb 16, 2017 Link to comment
    g-force =/= GEFORCE 😉😉
  • Shawn Prewitt 2
    Shawn Prewitt Nov 20, 2016 Link to comment
    My LG g5 won't clear all my back ground apps. It always leaves the same one on my back ground running apps Witch happens to be my phone contacts. Why is that?
  • Parvind Chahal 21
    Parvind Chahal May 23, 2016 Link to comment
    lg g5 is a big prblm no solution for it.......lg should focus on mid range phones and screen production sector......g5 not gonna help lg
