These IFTTT recipes will improve your phone's battery life
samsung galaxy s6 8
If you're new to the world of IFTTT (If This Then That), allow us to enlighten you. It's a free web platform that helps you connect all kinds of apps and services to suit your needs. It can do everything from text you weather alerts to repost your Instagram photos on Twitter, and it integrates tightly with the Android ecosystem as well.
The Android app itself is called IF and you can create 'recipes' (combinations of triggers and actions) from your mobile or via the IFTTT website. One of the channels added recently is the Android Battery Channel, which lets you take action based on your device's battery level. Here are some examples.
Creating recipes
As we've already mentioned, recipes can be built from the IFTTT web portal or through the Android app. You first need to choose a trigger (such as a low battery level) and then determine which action it will lead to (turning the Wi-Fi off, for example). If you play around with the channels, you'll see what IFTTT is capable of.
androidpit ifttt channel
IFTTT on the web. / © NextPit
We won't explain how to create each of these recipes in detail but they're fairly straightforward — just work through the prompts as they come up on the IFTTT website or app (which you will need to install to monitor the current battery level of your Android device).
androidpit ifttt app
The IF app on Android. / © NextPit
Turn off Bluetooth when the battery is low — IFTTT lets you build your own customized battery saver mode by turning off Bluetooth when your battery is running low. Without Bluetooth enabled, your phone or tablet uses up less power, so you can eke your battery life out a bit further.
Turn off Wi-Fi when the battery level is low — you can do the same trick with Wi-Fi, turning it off to conserve power when your battery dips below a certain point (IFTTT doesn't specify what this point is). This is obviously not one to apply if you rely on high-speed data transfer from your device at all times.
Mute the ringtone when the battery level is low — another way of conserving what battery life you have left is to mute your device's ringtone - playing those tunes uses up more energy than you might think. Again, the action happens automatically, so you might not even notice.
Send an alert when the battery level is low — perhaps you don't want IFTTT to do anything when the battery level is low, but you want to know about it so you can take action yourself. Choose Android Notifications as the action in your recipe and you can get an alert when there's a battery issue.
Keep track of charging times — IFTTT can trigger an action whenever you plug your device in to charge. You can use this option to add a line to a Google Drive spreadsheet or send yourself an email, and work out when your battery is dying (and then what you might be able to do about it).
Review: Google Pixel 7
Review: Google Pixel 6a
Go to comment (6)
David Nield
David Nield
Writer
6 comments
    Sean Dent Jul 27, 2015 Link to comment
    I have to say, I hate these vague comments in articles like "playing those tunes uses up more energy than you might think". For one thing, I doubt the phone ringing for 3 seconds uses much battery. But if it is using, say 25% of my battery, that's what I need to know if I am going to tell my phone to stop alerting me when I receive a phone call since it then turns my phone into ... I don't even know what.
  • Bob visser 14
    Bob visser Jul 26, 2015 Link to comment
    I use macrodroid it's easy to use but still has lots of options
  • 13
    Arjun Paliath Jul 26, 2015 Link to comment
    Tasker is actually quite useful although the primary battery killer on Android is the background processes of unwanted apps. So to tackle this, Google introduced batter saver on lollipop which is quite good at cutting down on background processes. And in combination I use Leandroid with root on all my devices to get a great standby time. :)
      There's also a great new app called Battery Saver Lollipop Shortcut which can automatically turn on Battery Saver under certain conditions (temperature, a certain app running, battery level, screen off, etc.)
  • Junaid Q. 17
    Junaid Q. Jul 26, 2015 Link to comment
    I use tasker but, will give a try to this
  • Kyle 8
    Kyle Jul 26, 2015 Link to comment
    Naaaaaaaaaaaah, TASKER is my babe.. sorry.
