How to save your phone from water damage
arguments samsung galaxy s7 waterproof resistant a eau image 00
© Venture Beat
If you act fast after dropping your phone in water, you might be able to prevent damage. Follow our tips below to try and save your device!
Obviously, you should first remove the phone from the water as quickly as possible. The longer it stays there, the more water or liquid will seep through the cracks and openings. Once it's out, there are certain things you need to do right away, and others you should absolutely avoid doing, in order to prevent water damage.
What not to do
  • Do not turn it on
  • Do not plug it in/try to charge it
  • Do not press any buttons or keys
  • Do not shake, tap or bang the phone
  • Do not blow on it. This could send water into other internal parts of the phone that it hadn't already reached, causing more damage in the process
  • Do not use a blow dryer - it can have the same effect as described above. Heat could also cause further damage.
AndroidPIT Wet samsung galaxy S5 5196
Your phone can still be saved! Try the following steps before giving up. / © NextPit
10 steps to saving your water damaged phone
1. Turn it off if, it isn’t already, and hold it upright.
2. Remove your SIM and microSD cards from their slots.
3. If you have an older phone, you might be able to open up the back and remove the battery. However, since most current smartphones do not have removable batteries and are hard to disassemble, the best step would be to take it to a phone repair shop before attempting to take it apart yourself. There are DIY repair kits and YouTube tutorials you could follow, however, if you are not tech-savvy, taking it to a professional is always better.
AndroidPIT Wet samsung galaxy S5 5220
If you can, remove the battery. / © NextPit
4. Use a cloth, sleeve or paper towel to dab your phone dry. Avoid spreading the liquid around, because that could push it into more of the phone's openings. Just soak up as much as possible.
AndroidPIT Wet samsung galaxy S5 5215
Tab the phone dry with a cloth. / © NextPit
5. If the water damage is more extensive, you can use a vacuum to carefully suck out water stuck in the cracks that are harder to get to. Make sure any small parts, such as the microSD card, SIM card, and battery, are out of the way before attempting this.
6. Bury the phone in a ziplock bag full of uncooked rice. Rice is great for absorbing liquid and this is actually a common method for drying smartphones and tablets. You can also buy dedicated phone drying pouches, which are worth having at home if you're the clumsy type. If you don't have them already, don't bother going out to buy one. Time is of the essence, so get your phone into rice as soon as possible.
7. Let your phone dry for a day or two. Do not be tempted to switch it on to see if it still works. Put your SIM card in an old phone, or ask a friend or relative if they have a spare device you can borrow.
AndroidPIT Wet samsung galaxy S5 5208
Let your phone dry for a day or two. / © NextPit
8. After a couple of days, you can remove the phone from the rice, insert the battery and switch it on.
9. If your phone doesn't turn on, try charging it. If that doesn't work, the battery may be damaged. You could try a replacement battery, or consider taking your smartphone to a repair shop to be checked by a professional.
10. If your smartphone has turned on and it is running as it should, you should still keep a close eye on it for the next few days, to see if you notice anything out of the ordinary. Play some music to check the speakers and ensure the touch screen still responds as it should.
AndroidPIT Wet samsung galaxy S5 5222
Hopefully, it will start up as normal again. / © ANDROIDPIT
In the future, avoid taking the phone with you when you go to the pool, use the bathroom or do the dishes to avoid the possibility of accidents.
Water resistant cases
Hopefully these steps have helped you rescue your phone from death by drowning. If you want to protect your phone from water damage in future, you can also purchase a waterproof phone case. There are some good options available from brands such as Otterbox, Griffin Survivor and Catalyst.
Water-resistant and waterproof phones
A number of phones are advertised as water-resistant or waterproof. Be aware that when phone manufacturers say this, it only applies under a special set of circumstances. A phone's resistance to water often depends on the clarity of the water, the depth of submersion, and the length of time for which it is submerged. We wouldn't advise testing your smartphones' water resistance capabilities by putting it in the washing machine or throwing it in the pool.
Samsung Galaxy S10 05
Phones like the Galaxy S10 are almost fully waterproof. / © NextPit
Pay specific attention if your phone has an IP53 rating - that means it is only partially water-resistant and will not withstand water sprays. Although manufacturers might claim otherwise, smartphones with this rating can even get damaged if used in the rain.
It's also important to remember that no smartphone is fully waterproof. However, devices with an IP67 and IP68 rating are as close as you can get at the moment. Phones with these ratings are also becoming more and more common, especially among flagships compared to a few years ago. That's not always the case with mid-range devices.
Here is a quick list of some of the current smartphones with IP67 and IP68 ratings:
Do you have any other tips on how to save a smartphone from water damage? Did our advice help you? Let us know in the comments.
Review: Samsung Galaxy S23+
Review: Samsung Galaxy A54
  • $1,199.99
  • $999.99
  • $1,799.99
  • $1,799.99
  • from $999.99
  • $999.99
  • $699.99
Go to comment (147)
Loie Favre
Loie Favre
147 comments
    Md Arif Sep 7, 2021 Link to comment
    PlayStation 5 is the newest variant in the PlayStation series released on Nov 2020. Since then, it has taken the market by storm, with millions of pre-orders and being sold out in more than 10 countries,
    just right after its release.
    solution for ps5 repair Newcastle becomes a top priority.
    storm Sep 16, 2020 Link to comment
    Uncooked rice method has been largely debunked. Ifixt and plenty more say it's worse than doing nothing.
    Update the article to current factual standards please.
  • Goldvin 11
    Goldvin Sep 15, 2020 Link to comment
    Cool! Thank you!
    AsiaSin
    MirandaStown Aug 25, 2019 Link to comment
    Useful information, thanks.
    nice info
    very nice
  • marco sarli 39
    never had and hopefully will never have the problem. I never take the phone to the bathroom
  • eSparkBiz 14
    eSparkBiz Aug 6, 2019 Link to comment
    I have Samsung Galaxy A50. After reading this, I just astonished that is my phone water-resistant or waterproof. But at last, I came to know that no phone is totally waterproof. But, if this kind of situation comes then the solution given here can be used and phone can be fixed.
  • MariaAnhHoly 1
    MariaAnhHoly May 14, 2019 Link to comment
    I dropped my new phone Vsmart Joy plus from Vingroup into the toilet. IT IS EMERGENCY BECAUSE IT IS NOT MY PHONE. PLEASE HELP ME AS FAST AS YOU CAN !!!!!!!!
  • Konstantin 1
    Konstantin Mar 22, 2019 Link to comment
    So when I drop a phone with IP67 or IP68 in water, when can I charge it again or use the USB-C Plug for headphones? Doint this with a wet plug seems critical, isn't it?
    TechSally Dec 11, 2018 Link to comment
    Actually, if you only dry it by hand you won't be able to remove the corrosion which will start to form when your device hits water. You might be able to turn it on, but it will slowly die because of the corrosion inside.
    My mom dropped her phone in the toilet - twice! But we found a repair center who works with this company Techsave which has a special technology to save your phone from water. And it worked - both times - and all her photos where still there and all. Just saying.
  • Mauro Ghiglia 4
    Mauro Ghiglia Dec 7, 2018 Link to comment
    Unfortunately, despite many people think the most damage is made by the water, the big problem is in the mineral salts that are contained in the water. If water comes in contact with the electronic circuit, it can leave a layer of minerals on the circuit. Minerals, little by little attract humidity and can become very corrosive, causing damage even after months. If you phone is completely filled with water after a long permanence, the first thing is to remove the battery (if possible) and the second should be (I know it may sound strange) to wash it in highly distilled water.
  • 12
    harshatecordeon Dec 7, 2018 Link to comment
    Super information.
  • ariful islamcsc 1
    ariful islamcsc Oct 13, 2018 Link to comment
    Soon after the water does not enter the set, pick up the mobile set or remove it from the water. Together turn off the mobile switch. I hope it will be good.
    InfiniteStupidity Sep 24, 2018 Link to comment
    I did most of the things you arent supposed to do... Do i throw mine away, or is it still even worth a try?
    Edit: i shook my phone, tried to turn it on 20 times, blew into every hole, and pressed basically every button before i read this, did the steps, and checked on my phone 25 hours later. It was about 80% functional. i found a few problems, such as the back button not working, the wifi not connecting, and the screen having way more problems than usual. im going to let it dry in rice for about 12 more hours or so and update this when i get it back.
      Lola Lawal Jul 1, 2020 Link to comment
      hi, i did the exact same thing before reading this. can you tell me how it went? an it was shampoo that got into mine not water, is that better or worse
  • Venu Prasad 1
    Venu Prasad Sep 4, 2018 Link to comment
    Hi Friends,
    Today my baby have put my Samsung J7 Max in water bucket, immediately I tried to switch off the buttons was working but I cannot select the power-off option then I have hit the bottom side on my thy few water drops came out then I kept it in sun light for 10-15 mins still not working, I immediately went to mobile repair shop he shocked me with answer : there is only 50-50 changes as it should be removed from front side as we cannot take the battery out I tensed.
    I run home again kept in sun light but this time putting a silk cloth wrap and kept for 15 mins checked later the touch is responding but there are few white marks on the screen. After watching few videos I have kept it in rice box hope this should work.
    I suggest you not to panic and do keep your mobile in sun light and try few steps it should work, I will post again once I take my mobile out of the box ;-)
    Keep digging for the answer folks....
  • Ionut Costean 1
    Ionut Costean Jul 25, 2018 Link to comment
    i did all thing that shouldnt .. before reading this article.
      Did your phone ever work?
    Alessandra Jul 18, 2018 Link to comment
    Hi,so today I went to the springs, and I had put my phone into a water case and I had closed corrrctly but my mom had found some water in the case, I dont know why it was there, but... I put my phone in uncooked rice and took the battery out. But then, I had found that my phone was pink at the top and I know that's not good. So, if it is pink will it still work?? Btw, the water had gone in the phone the charging hole. I also did carfully dry the phone got wet. Plese give me some advice!!
    Vulijjinhlong Jun 25, 2018 Link to comment
    Moisture damage I turn on the phone because i dont know how to do it, it cannot work how can i do
    Alessandra
  • Layla Mai 2
    Layla Mai Jun 24, 2018 Link to comment
    I've tried all this yet my phone is not turning on. It's working fine as I'm getting notifications but the screen is still black.
    Mr.Rizer
    • Mr.Rizer 1
      Mr.Rizer Jun 3, 2019 Link to comment
      did your phone ever start working again because my phone is still functioning other than the black screen. it just KIND of came back on after about 2 weeks but still mostly black screen so im wondering if eventually it will work or should I just abandon all hope.
  • Nikhil Nayak 6
    Nikhil Nayak Jun 1, 2018 Link to comment
    I can confirm that the rice method is the most effective!
  • MarVelljones 6
    MarVelljones May 31, 2018 Link to comment
    Silica gel, which "phone drying packs" are typically made of, is far superior to uncooked rice. That being said, don't expect miracles unless your phone is at least partially water resistant. You can get your phone to work again, but it's time to start looking for a replacement once this happens.
  • Rusty H. 33
    Rusty H. May 31, 2018 Link to comment
    Or, just throw it away and buy a new one ;)
    Or, DON'T get it wet.
    It still amazes me, when I see coworkers & friends complaining about broken screens, headphone jacks, charge ports not working. I've had 5 smartphones in 8 years. NONE have ever had a broken screen, dropped, dunked in water/wet or anything. The Note1 I had, I did have to replace the charge port multiple times because the $%^&# battery wouldn't make it through the day (which is why my last 3 phones have had 4,000mAH batteries).
    Deactivated Accountzoeyst
      zoeyst May 31, 2018 Link to comment
      Some people are just so careless about their phones, of course other things as well. Some people's carelessness is really amazing. @0@
  • 46
    Deactivated Account May 31, 2018 Link to comment
    I love it, how to fix a water damaged phone #3. Remove the back and battery LOL unless your like me and stick to old phones with that option your out of luck. With a removable power source you do not need IP68 rating, removing the power source stops the damage. Let it dry and it is fine. My Note 4 and S3 have both been drowned several time and they are both still running fine. Simply because I could remove the battery. Non removable batteries are all about planed obsolescence and nothing else. Just greed from the manufacture that decide how long you should use your phone so you have to buy a new one sooner.
    Rusty H.
    John Shepard May 9, 2018 Link to comment
    Lol, it reminds me of my stupidity when I had a Droid turbo back then and when it's screen was dirty, I always used to wash it with a lot of water. It never hurt my turbo in any way. But one time I was listening to a music and while the speaker was playing the music, I placed the phone under a running tap and speaker volume went too low and it went dead. Earpiece was also not working. I was not worried and just turned the phone off. And after half an hour I turned it on, speaker was working but earpiece worked after shaking the phone. Another method I have heard working is to deeply inhale the speaker area with your mouth and try to suck the water.
  • me...ok 1
    me...ok Apr 24, 2018 Link to comment
    I left my phone in a bucket outside and it rained, when I remembered were it was it had been under water for at least two days...
    what now?
    Leah Cairns Apr 1, 2018 Link to comment
    No
  • Tristan Holder 1
    Tristan Holder Mar 4, 2018 Link to comment
    ok so all i need to know if this works for an alcatel onetouch pixi 4
    SK Thahrani Jan 21, 2018 Link to comment
    I dropped my phone in the river water and it was completely submerged in water I took it out and used rice method, but it is not working. I have checked also other sites like but I did not get any solution.
    Rabiya Wikimonks Jan 6, 2018 Link to comment
    This article tells about fixing smartphone dropped in water.
    Zachary Ludington Nov 27, 2017 Link to comment
    so i dropped my phone (lg k20 v) in toilet couple hours ago and i dont have any rice what do i do? Please tell me right away.
    • JC Albritton 1
      JC Albritton Jan 19, 2018 Link to comment
      put it in a bag and use a vaccum to suck the air out
  • Joe Goldstein 1
    Joe Goldstein Oct 19, 2017 Link to comment
    Rice and paper towels are great, but you really have to try using distilled water.
    michael sheeran Sep 28, 2017 Link to comment
    i just got used LG phone, and it has water in the screen. what should i do? it has been in rice for 3 days and still does not charge.
  • Jen 2
    Jen Sep 7, 2017 Link to comment
    I own the moto g5
    ok so it was pretty stupid but I dropped my phone in the toilet and it was completely submerged in water I took it out and dried it off and tried turning it on a few times before seeing this post, but I didn't put it in rice straight away, I put it in a while after, it's been in rice for a couple of hours now, is there a chance it will still work if it wasn't put in straight away?
    michael sheeran
  • Kathy Melinda 2
    Kathy Melinda Aug 11, 2017 Link to comment
    this past Tuesday morning I dropped my Samsung g6 into toilet. screened turned black. was going crazy and put it into a Rubbermaid container covered in rice, top to bottom. later in the day I put it in a larger container with much more rice. 4 o'clock this afternoon tried turning on, nothing. tried charging, nothing. took 3 - 4 tries and finally started charging, very slowly. it's now charging, I have gotten texts, sent texts, etc. so far, so good. going to try other things later and see what goes. have a lot of hope right now!!!!
    michael sheeran
  • Malstron 4
    Malstron Aug 9, 2017 Link to comment
    I used the rice method two times in one year ( ゚д゚ )
    michael sheeran
  • kitty_ Kat 1
    kitty_ Kat Aug 1, 2017 Link to comment
    Help my. phone fell in water but it worked so I didn't do anything and now it cant turn on woud the rice still work
  • Vitanie 1
    Vitanie Jun 7, 2017 Link to comment
    "do not be tempted to turn it on and see if its working"
    Me: wtf do you mean, im the type of person to whats app every fucking second
  • JulieB 1
    JulieB May 1, 2017 Link to comment
    What they don't tell you is that you'll keep getting grains of rice stuck in your charger port.
  • Kirito12200 1
    Kirito12200 Apr 17, 2017 Link to comment
    My phone fell on water it turns on but the touch screen doesn't work is there anyway to fix it
  • Littlemighty MANN 1
    Littlemighty MANN Apr 10, 2017 Link to comment
    So about 10 mins ago, I spilled some milk on my phone on accident. (Samsung galaxy j7) The damage isn't so bad however, it's home, back, and window buttons randomly activate and are unresponsive sometimes. I took it all apart, battery and micro sd. I couldn't get the sim card out so i left it considering the only areas hit with milk where the bottom holes for the charger, headphones, and a random little hole. its now sitting in rice. Anything else i should do?
    • HP Forever 1
      HP Forever Apr 17, 2017 Link to comment
      Dude I have the same phone and idk what to do I dropped in it the bath tub after I tried playing music and it's in rice right now I took the battery out but I'm not sure if it'll help what did u do also please tell me if this works cuz I rlly need to know anyway please reply if this works for u
      Lorna Donnelly Sep 3, 2017 Link to comment
      Hi I spilled milk over my Samsung j5 17 in milk two days ago I'm looking to no if it worked with it phone putting it in rice. Thanks.
  • Travis Godbold 1
    Travis Godbold Apr 2, 2017 Link to comment
    My cellphone got wet from a soda spill, for days it would not recharge, because of overheating. I disassembled the phone, with the circuit board exposed, dabbed it with a wet cloth to clean it, blew into the holes of the steel protective cases housing the cpu,etc. then placed the phone in the freezer. After 5 hours, took it out of freezer, saw it was moist with wet residue from the freeze process, let it dethaw, and recharged phone. Phone works great now.
    Craig Anderson Mar 16, 2017 Link to comment
    Tips to help with water damaged phone:
    - follow common sense and common knowledge steps
    that's how helpful this article was
    RothmanZaman Adnan
      julian lopez Mar 30, 2017 Link to comment
      wow your really rude
      • Zaman Adnan 1
        Zaman Adnan Apr 3, 2017 Link to comment
        you're
  • Venkata Sai Krishna T 1
    Venkata Sai Krishna T Mar 16, 2017 Link to comment
    I have dropped my Corby 2 in detergent water. Its been 30 min. How should I recover it??
    • Isaac Vaughn 1
      Isaac Vaughn Dec 14, 2017 Link to comment
      Don't. That phone was ready to die.
    Alicia Garcia Mar 6, 2017 Link to comment
    Hi Shivan sorry I forgot to say thank you because I did save my photos!! I was very happy until I noticed i cant send or receive texts, I put it back in the rice and see what happens please if you have any more tips of what else i can do :(
    Hi I left my phone in rice for two and half days, apps and wifi work well but I cant recieve or sent text messages, any ideas please,
  • Tj Martin 2
    Tj Martin Feb 26, 2017 Link to comment
    Mine was in my pocket in a hot tub for 30 minutes my S5. A few days later the screen stopped working. I turned on my oven to just a hair under 200 degrees and put my phone with the battery out and the back cover off on a piece of wood glass side up. I left it in for five minutes pulled it out it was hot but I could still grab it with my bare hands. Then I placed it in my freezer on a bag of ice for five minutes. After this one or two of my numbers to unlock the phone worked but the rest of the screen was still unresponsive. I repeated this procedure two more times for a total of three times. The last time I left my phone in the oven for almost 10 to 12 minutes. After it was cool from the ice I put the battery back in and the touch screen was fully responsive again in all ways. My theory is that heating it this way evaporated or removed all of the water inside of the phone and any on or in the display as well. It is now two days later and my phone still works great in every way just as before this happened. I never did try the rice technique or any other technique prior to this good luck. Perhaps heating it two 160 degrees or so or longer let's say for 15 to 20 minutes might be a safer approach. I wish I had several water logged phones to test this hypothesis.
    Andrea Wray
    • gymnystic girls 101 gym girls 2
      gymnystic girls 101 gym girls Sep 27, 2017 Link to comment
      My little one dropped mine in the toilet! Rice for 2 days,no luck. Oven this morning lowest temp 20 min. Thak you so much!!! You saved my phone!
      Andrea Wray
    • Andrea Wray 1
      Andrea Wray Oct 9, 2017 Link to comment
      Hello Tj Martin. THANK YOU THANK YOU THANK YOU!!! For the first time EVER I put my phone in my jeans back pocket and when I went to use the toilet, "plop" went the phone in the bowl!!! I didn't panic, I turned off the phone immediately and wiped as much water off as I could (My phone is a Samsung A5 so I could not remove the battery) . Then I filled an ice bucket with rice and submerged the phone in it upright. But during that night I read your suggestion and so after 24 hours in rice had past I placed my phone, glass screen up in a toaster oven at 160 degrees for 20 minutes. Then I let it cool to room temperature and now... MY PHONE IS WORKING FINE!!! Thanks again for this "oven drying" method!
    Sierra Banks Feb 1, 2017 Link to comment
    Does it have to be a ziplock bag? I don't have any big enough for my phone. I have it in a bowl with foil & a lid right now.
    • Shivam Yadav 2
      Shivam Yadav Feb 1, 2017 Link to comment
      It doesn't have to be neccasirly a zip lock bag. It should be consealed properly in whatever case or bag it is.
    Lyall Cornish Jan 23, 2017 Link to comment
    About 5 hours ago I dropped my phone (Vodafone smart prime 6) in my dogs water bowl somehow. I immediately turned my phone off (holding down the power button once then shutting down.) and I grabbed a container, filled it with rice and submerged my phone into it. I then realized that there would be moisture stuck behind the back plate/cover so i removed that, though I haven't removed the SIM or microSD and the battery isn't removable. Only after reading this just now have I moved it into a plastic bag full of rice. If there is anything I have done wrong or anything else I could do please let me know as it would be very helpful. Thanks
    • Shivam Yadav 2
      Shivam Yadav Jan 31, 2017 Link to comment
      Hi Lyall, I don't know if it is good to leave sim and memory card inside the phone or not. But would recommend to remove cards from your cell.
      As you said your phones battery is irremoveable how did you manage to switch off your cell?
      Read my comment with the name Vibhor Gupta, what I did?
      This thing needs a lot of patience.
  • Vibhor Gupta 1
    Vibhor Gupta Jan 11, 2017 Link to comment
    2hrs ago I dropped my Lenovo Vibe K4 note in a bucket of water,took it out as soon as I can. Seemed fine for first few minutes then it started to show sign as it shows while starting up but couldn't start and kept on doing so then some chinese or korean or japanese text came on screen till then I started to diassemble it so don't know if it got shutdown due to short circuit in IC or because I undid some connections it. While diassembling it I destroyed my battery but all the parts are apart now. Kept them under a warm led bulb as it is the only the that I have at 06:00AM in the morning for a little warmth for water droplets to evaporate. I am seeing forward to order a new battery and
    a strip of some silicon wire, I guess. Which was under the battery connecting motherboard to some other part which I destroyed.
    Also waiting to go out and grab some silica gel packets to keep with my mobiles parts to get out every drop of water rice will be 2nd in my list of options.
    Hope it does the trick and my smartphone works again.
    Please advice, what can be the best thing to do now?
    I am writing this from my roommates mobile and his account.
    (Mine is : yshivam.yadav7@gmail.com)
    Anyone if interested, write me up.
    And would suggest any one not to do what I did if you don't know about your phones interior.
    • Shivam Yadav 2
      Hi all, I am the same guy who commented the above comment.
      Last year my brother was also in the same situation when he dropped his phone in water. He didn't know what to do and left the cell as it was, after a month or so when he went to the service center they charged him amount that was equivalent to the phones value, stating that it has carbon in somewhere and motherboard needs to be changed(maybe they were true). But you can't believe these service centres. I had no option but to take risk and open every bits and pieces of my phone(because my battery was irremoveable). I have been to service center and they were charging me ₹1500 $22) for the battery and ₹7000 ($103)for the motherboard, I came home ordered a battery online for ₹675 ($9.9)and received it today and installed it in my phone and now it works fine.I am happy that it saved me ₹7825 ($115).
        Navin Sharma Feb 20, 2017 Link to comment
        Hii shivam I think I am same situation I was using lenovo vibex2 and I dropped my phone in ocean water which is salty but I try to open and I think it get spark and as I was staying in island in Maldives didn't have service center facility so I waited 5 month and after 5 month of that incident I send my phone Delhi,India my friend went gafar market which is famous for mobile repair and this people said your phone can't repair again..I didn't understand why...Can u tell me that where your brother repaired it
  • Rennita Saldhana 1
    Rennita Saldhana Jan 8, 2017 Link to comment
    my MotoG4 Plus fell in water, it took around a minute or 2 to get it out. it still worked so i used it for another 5mins and answered a call after disconnecting the call the touch stopped working, though the fingerprint sensor and the display worked perfectly the touch still didnt work. i tried shaking my phone and some water came out. the touch worked again so i switched it off. but i wanted to check again so i switched it on again and after a while the touch stopped working. my phone doesnt switch off as i require the touch to shut it down. its showing some fastboot thing on screen. i even blew in the phone & basically done everything told not to do. i do not know what to do now. please help!!!!!!
  • Kim Cox 2
    Kim Cox Dec 29, 2016 Link to comment
    Happy ending! My phone recovered.... eventually. Hope the details in my story (below) help!
    I had had a stressful week! I thought it would be awesome to watch anime on my phone while I soaked in the tub! Relaxing right?! Until my phone slipped into the bathtub!! NOT relaxing!
    It took a good month for my phone to completely recover but here's what I did- good and bad:
    I took the case off! Yay!, now the water got in more and there are w tiny pieces of paper that turn red when there's water damage. That's okay, I got the warranty that covered everything!
    WRONG! I was confused by what the salespeople told me when I bought the phone and somehow it wasnt covered.
    SO, when it happened, I removed sd cards and battery- good. I put it in rice- good. Kept pressing buttons- bad. My dad put it halfway in the oven on lowest temp- bad. We used a hair dryer- bad. I put it in rice- again- good. Also, I prayed.
    Okay so a quick note:: Yes a phone is trivial thing to pray about. But I was so broke. God is cool- He always understands what I'm going through. He helped me calm down about it and stop worrying as much.
    Signs of life: First few days, when I'd turn it on, it shut itself off to a blue screen. Next few days, it turned on for very short periods, but touchscreen didnt work. The only way I could turn it on, was to reinsert the battery several times in a row- I literally had to do this dozens of times a day. It shut off in the middle of whatever I was doing. Then, it only shut itself off when I wasnt using it for a few minutes. After a couple weeks, I still had to reinsert the battery a few times a day to turn it on after it shut itself off, but it was working for several hours at a time.
    After a month- it was all better!! I hope your phone gets better too!
    Pakan Morena Dec 29, 2016 Link to comment
    I dropped my Galaxy S4 in a bath tub full of water. I dried it with a towel immediately and it worked normally. After a few seconds the screen just went black. I took out the battery then put it back in and then I tried switching it on but I had no luck. I then put it in some rice.
    It's the second time it falls into some water. Will that affect it?
  • Joshua Sarabia 1
    Joshua Sarabia Dec 29, 2016 Link to comment
    I accidentally dropped my phone in the water but i took it out of the water as quickly as possible just like the article above said. after the accident i dryed it by my shirt and dry almost all visible spots .But the only mistake i made was that i turned it on right after taking it out of the water. actually it didnt turned on, but a few minutes later i took the battery off my android and tried inserting it again and it turned on. but it wont swipe or touch to shutdown. second time i took out the battery again and it turned on .. and this time i can now swipe it and touch it .. it was a relief so i turned it on sleep again like nothing happen. but when i checked it out again for a few minutes ... it was looping in its booting logo again and again. i took out the battery again and buried it in an uncooked rice for about 3hrs but it still looping idk if theres a possible way to fix it pls help me.
    • Kim Cox 2
      Mine did the same wierd things. It took a few weeks for it to get totally better. I suggest putting it in rice. Keep turning it on and try to use it, it will hopefully get better and better. My phone wasnt usable at all for the first week. Only a little better the second week, then got a lot better until normal. I hope yours does too!!!
      Shivam Yadav
    • Shivam Yadav 2
      It needs more time than 3hrs to dry. Maybe around a week or so, I guess.
      Read my experience (above).
      Alicia Garcia
    Mark Robert Dec 29, 2016 Link to comment
    I used Stellar Phoenix Picture Recovery
    I recovered back 80% of photos through using a tool but my search is still on and hopefully I find something better than that!
  • Albin Foro 30
    Albin Foro Dec 22, 2016 Link to comment
    Never used with a phone, but the rice thing really worked to rescue an MP3 player that drowned in a downpour while on a run. It took several days in the rice, and I'd already ordered a replacement after the first couple of days. One other suggestion when the phone is dry but seems bricked - a "hard reset" works on various models. I used it three times after dropping my old LG phone on hard surfaces so it wouldn't restart. Instructions for models that support hard reset may be in the user manual or at the hard-reset[dot]com website.
  • 19
    Moni Mihailov Dec 22, 2016 Link to comment
    1 or 2 years ago when i still had my S3 Mini i dropped it in a glass of water (was playing some game on top of the glass and it slipped, yes sounds awesome xd) and then it started pressing buttons and such things on its own. i switched it off and it couldn't turn on again (i almost had a heart attack xdd). Then i held it in front of the heater for half an hour (my band was burning). Then i turned it on immediately and it showed that battery was at 60 or 70 degrees Celsius. i left it on the bed whole afternoon to cool off and when i took it from there in the evening the spot was hot like a meteorite had fallen down there. Since then i kept it away from water :D
    But few months ago my S5 (current phone) was hot cuz i played some game long time so i washed it in the sink with cold water to cool it off. Until then i had done this before a lot and it was fine. Well not this time, screen started pressing itself randomly, capacitive buttons were pressed randomly by themselves and i had to spend 50 bucks to replace the screen sensors under the display. Now none of my phones are going anywhere near any water, even if they make them better water survivors than submarines. xD
    Kim Cox
    • Shivam Yadav 2
      Electronic goods and water can never be good friends.
  • Maria Tsag 3
    Maria Tsag Dec 20, 2016 Link to comment
    Thank you !!
    Kim Cox
    Anne Kei Dec 17, 2016 Link to comment
    My huawei phone was dropped in a pond while I was at the park, and I had to wait for about an hour before I could get it in rice. Now, when I turn it on, the screen is not working and there are whitish streaks around the edges. Another thing to add is that a couple months ago I cracked my screen, would this have anything to do with the screen not working??
    Kim Cox
  • Kassy R. 1
    Kassy R. Dec 13, 2016 Link to comment
    My Nexus 5x got water in it or on it or something not sure what really happened, my phone was on a table off and I turned it on and the screen only showed lines. It still vibrates when notifications happen (it won't let me turn it off). I have it in rice but will that really help if water got in it because I am unable to take it apart, it does not come apart. What should I do???
      Raluca Banu Dec 20, 2016 Link to comment
      your phone it s working now?
    • Shivam Yadav 2
      Any updates with your phone?
  • Kent Gerona 1
    Kent Gerona Nov 16, 2016 Link to comment
    need help<is it still possible to fix the phone even if i pressed the power button a few times until i realzed this post lol cause i left my phone on the table and my younger cousin kinda pushed the phone and it fell down right into a bucket undeer the table i noticed the brightness going up and down and i removed the battery i pressed the power button to open it but it wont work so can i still open my phone?
    • Shivam Yadav 2
      -Removing battery is the first thing one should do.
      -Then keep patience and let the drying agent(rice,silica gel etc.) do its work.
  • maggie espinoza 1
    maggie espinoza Nov 4, 2016 Link to comment
    what happen you don't have rice! what do, i do?!
  • Mina Turner 1
    Mina Turner Oct 3, 2016 Link to comment
    i dropped my phone into the loo. I did put it in rice after. The battery definitely isn't damaged, it charges and vibrates when i turn it on. The little notification light flashes and my phone even makes notification sounds. Only thing is, the screen won't light up. Maybe it is useful to mention that about 2-3 weeks ago i had to get my phone screen repaired because the LED screen was smashed. Was it the water damage or the bash it got from dropping that is why the screen won't turn on? Is there any way i could fix it myself? Also my phone is a HTC Desire 626 so the battery can be pulled out a bit but it's attached with wire to the phone (I did pull off the battery a bit when i put it in the rice).
    Meenu Justin Sep 17, 2016 Link to comment
    I accidentally dropped my phone, Nokia Lumia 635 in the loo. I've always dropped it on the ground but it never had a effect only now that its in water. Oh god! But i took it out in seconds and i took everything out (battery and sim) and i saw that there was so much water so i soaked it up using a towel and then i started shaking and slightly banging it on the cloth to shake out all of the water but then gave up and came to this and many other websites that said to put it in uncooked rice. So it was in there till morning and OMG!!! it worked !! it turned on! thanks so much
    Murthy Viswa Sep 8, 2016 Link to comment
    Very nice post. Here my problem is for Lenovo A7000. It is water damaged phone. Since the owner does not know to immediately remove battery, sims and memory cards, he kept the phone aside and after 10 days he gave it to me. The phone is turning on, able to enter RECOVERY, FACTORY, META modes also. And sometimes, it normally boots . Touch and LCD are also working fine. Flashed the Stock ROM also and it went on very well.
    Camera also damaged. The only problem is continuous restart. Is there any solution for my issue ? I have 3 Lenovo phones like this water damaged. Expecting an early reply to REMOVE THE WATER DAMAGE...
  • Angelique Claessens 1
    Angelique Claessens Sep 7, 2016 Link to comment
    I was sitting on the toilet with my phone (yes, i know) when it fell into the toilet.. i grabbed it out and the home button woldn't work. there was water damge in my screen but everything worked fine. i dropped my phone in rice for 4 hours and it worked again! well.. it constantly goes to home whitout me pressing the button it's so frustrating.. someone has this problem? ;_;
  • Cole Penner 1
    Cole Penner Aug 30, 2016 Link to comment
    I was listening to music in the shower with my phone on the counter beside the shower, the phone has water damage inside the screen but it still works, it's just the discolouration is really annoying. Any tips? Btw it was 2 days ago, I put it in rice overnight and nothing changed. Should I wait a couple days?
  • jonjo hartley 1
    jonjo hartley Aug 15, 2016 Link to comment
    I spilt abit of water on my phone without knowin i only noticed the next morning its not been working the same help
    Locoroco Aug 2, 2016 Link to comment
    I was washing the dishes this morning when my dog came and knocked my phone(Samsung J7) down onto a wet puddle on the floor. I thought it got soaked but it did not. I checked everything and it was surprisingly dry. But when I was about to take a picture using my front camera, all I could see was a blurry me. Upon closer look at the camera I can see little water droplets inside. I'm going to put it inside a ziplock with uncooked rice inside it overnight. I hope this works. And I hope I'm doing it right. But if not, please help me. I don't want to tell my Father this 'cause I know for sure he's going to get mad at me. Again.
    P.S. Phone is working. Just the screen flickers.
    Salvation Alberto Jul 22, 2016 Link to comment
    I did some of the things it says not to, like turn on the phone multiple times. Could it still be salvaged?
  • Chin 1
    Chin Jul 21, 2016 Link to comment
    My phone was soaked with water this morning, I saw it was still working so I just wiped the excess water off the case. Few minutes later when I'm in the bus, it wouldn't turn on so I opened the case to see water everywhere. I wiped everything then blow dried it. Still won't work. I wish I have read this article much sooner so I am aware what to do and what not. It's been 5 hours, is there any chance that my phone gonna work again? Please help I'm doomed
  • Kkelly 1
    Kkelly Jul 21, 2016 Link to comment
    When I dropped mine in the sink, I took the battery out and put it in a plastic bag for 2 days. I tried to turn it on and it did but the screen was black and I could hear buttons pressing when I touched it. I put it back in the bag and put it in my car for an hour in the heat, then vacuumed the rice dust out of it. Put the battery back in and turned it on. It works, no problems! Hope this helps someone else too.
    • Jason Marinello 1
      Jason Marinello Sep 30, 2016 Link to comment
      THANK YOU
    • Jerry Singtoyhu 1
      Jerry Singtoyhu Nov 23, 2016 Link to comment
      What was the phone,same thing happened to me it worked directly after i dropped it but like an hour later the screen was all white but the phone was on and the notification sound was on ,i tried to charge it thinking maybe the heat might help and soak the water out of the system but still nothing. My phone is LG K4
  • Alane Gavagni 2
    Alane Gavagni Jul 12, 2016 Link to comment
    I've noticed when enough people voice their concerns about a common (it would seem) problem and Not one person responds to address their issue it's time to go a different route people! I challenge the cell phone manufacturers to build us a phone that is WATERPROOF OR BETTER YET WATER FRIENDLY!!!!, My God we have a satellite in Jupiter's orbit but we can't make a phone that takes a little moisture!!Please! While you're at it how about creating an app that can automatically charge your phone ohhhh there's an idea....hang around I'm just starting on a roll.
  • Aniketh Maniath 1
    Aniketh Maniath Jul 9, 2016 Link to comment
    I dropped my lenovo k4 note and removed it within seconds my phone is not turning on what should i do
  • Gopcpro App 2
    Gopcpro App Jul 4, 2016 Link to comment
    Protect Accidental Damage and Liquid Damage instal Gopcpro app
    Alane Gavagni
    • Alane Gavagni 2
      Please view MY absolute water fix of 7/12/16
  • Gopcpro App 2
    Nice Posting............
  • Renee McDermit 1
    Renee McDermit Jul 3, 2016 Link to comment
    Can anyone tell me what to do next after my samsung phone got a soaking from my water bottle. And stupid me was in a state of panic, tried to turn the phone on & the screen went white. Then someone advised me to take the battery out & let it dry out.....about 6 hours later I've put the battery back in & tried the phone & the screen is still white....I have taken the battery out again & put the phone in a container of uncooked rice. My question is ....have I cooked/fried my phone & will I have to buy a new cell or can it be saved?
  • Ka Mark Joseph Penedilla 2
    Ka Mark Joseph Penedilla Jul 2, 2016 Link to comment
    hello. Last night, I put my phone beside the sink and hets wet. Now, I can't power it off because the touchscreen don't work and when I press the power button, it restarts.I can't remove the battery either because it is built in.The screen bcomes defected, what should i do?
    Je Nae Gordon Jun 30, 2016 Link to comment
    Should have read this article quicker, I did everything (except for the heat and cool thing) it told me not to do. I'm screwed :(
    Brittany Casella Jun 28, 2016 Link to comment
    My infant son was chewing on my case and me not.realizing his drool got into the case and into my phone it will.not turn on it is a galaxy e5
    Any suggestions on what to.do?
  • Javanni Apihai 1
    Javanni Apihai Jun 12, 2016 Link to comment
    can you help i have a phone with the battery mounted to the phone
    and i scared to do anything
    i recently dropped it in the toilet
    My phone is a Vodafone smart prime 6
    DarkFusionz May 30, 2016 Link to comment
    So it was just a normal day and me and my family went to the pool next to are apartment. And I decided to bring my LG d415 in my pocket. So then we go there and I forget and walk into the pool with my phone for at least a minute or two and then get out realizing my phones in my pocket!! I was scared so I took apart my right away, take the battery out and grab my shirt and start drying it all over, but my dumb mistake I just realized was then I just set my phone down and wrapped in my shirt leaving it there for but 2 hours. So then I get inside and use blow dryer on it for a bit and then put in a bag full of rice. I hope it works but from the other comments it seems like it's working. So I'll keep it in there for a day or two. Help me what should I do?
  • Dubu Rin 1
    Dubu Rin Apr 10, 2016 Link to comment
    I am scared right now. I actually tried to press the buttons and tried to turn on my phone after drying it with a towel. I also actually tapped and shook the phone. I didn't read this beforehand so I didn't know it was wrong to do it. Right now I really hope my phone would be fine after being in a container full of uncooked rice :( Also, my Samsung phone is really hard to remove the back cover so I cannot retreat the battery and sim card out of it :(
    Abbey ******* Apr 9, 2016 Link to comment
    ok so i took a bath with my phone (moto g 2015 model ) just scrolling through assignments and the shower head turned on so i took all the cases off and put it in a bag of rice for a hour (im not the brightest person as you can see..) then spent a hour trying to get the rice out which actually only kindia failed then i tried to charge it but it isnt charging help please ;_;
    and i need my phone for college so i really cant put it back in rice for longer then a day considering all my assignments and notes are there NO WAY i can buy a new phone or really buy anything to that matter
    Aspen Mansfield Mar 30, 2016 Link to comment
    I took my phone to the pool today... It was in a waterproof case and i was swimming with it for several minutes before i noticed that water was inside the case. I tried to turn on my phone and so did my mom. After a while it started vibrating so we took out the battery. I just barely placed it in rice and I'm praying it will work. Do I have any chances? Please respond...
      it might work! it helped for me tho.. just keep praying! :D
  • russel junior 1
    russel junior Mar 26, 2016 Link to comment
    I've drowned my HTC butterfly 2 and water seeped in the screen.. The phone is okay.. Just the screen is messed up.. I've placed it in rice and left it there for a week and magically.. It looks like new
    Caleb Ellis Jan 28, 2016 Link to comment
    I dropped my phone in water and I immediately put in rice its been a few hours so I decided to check on it (before reading this) I turned it on to see if it still works did I make it worse by doing that
  • Androsurf 3
    Androsurf Nov 12, 2015 Link to comment
    Good article...
  • 21
    Peter Harwood Nov 11, 2015 Link to comment
    dropped mine in a stream for at least half hour got it worked perfectly with no drying! it was a z3compact though
    • russel junior 1
      Dude.. that phome is waterproft
  • Tim 1
    Tim Oct 22, 2015 Link to comment
    I dropped my phone in water, and left the case on and didnt know that I should've done these things, now my wifi doesn't turn on. Do I buy a new phone?
      Kiran Bajaj Oct 22, 2015 Link to comment
      I had to get it fixed. Cost me 15000 but it's working fine now.
    Kiran Bajaj Oct 13, 2015 Link to comment
    I bought a new Samsung note 4 few days back and unluckily dropped it in water. I immediately took out the battery and removed the sim card and dried it up. Later I vacuumed it and then put it in bag of rice for 2 days. Now when I switched it on its not working. What should I do?
  • Debmeet Banerjee 1
    Debmeet Banerjee Oct 5, 2015 Link to comment
    I dropped my phone moto g second gen in the washing machine and it stopped working. I haven't done anything about it!! Help!!
    Also guys I've seen a lot of people drop Samsung and Motorola smartphones in water!!
    That's just my opinion.
    Daniela Adams Sep 1, 2015 Link to comment
    I dropped my phone in water twice. When I did it the first time, I got it out of water almost immediately and I put it in rice for a few days. Incredibly enough, it worked! However, when I dropped it the second time, the trick didn't work and I had to get it fixed... Thanks for the helpful tips, I am getting this phone drying pouch you mention in your article!
    www.devicedr911.net/samsung-repair/
    Debmeet Banerjee
  • Mahmudul Hasan 8
    Mahmudul Hasan Aug 9, 2015 Link to comment
    Good topic.
  • Diz 7
    Diz Aug 9, 2015 Link to comment
    Couple of things, if you're going to the beach, camping, hikes in the rain etc? put your phone in a Ziploc bag, be safe and get the good ones with the double zip at the top, it'll save you lots of grief and money.
    Also those silica dry bags you get with shoes, electronics etc? save them too and put them in a bag with rice, and super dry it , I've been using mine for years and they work like a champ, just don't eat the rice afterwards.
      Tijuana Turner Aug 14, 2015 Link to comment
      so did it work??
  • vismit magotra 2
    vismit magotra Jul 27, 2015 Link to comment
    Dropped my Samsung Note 2 yesterday into the water.. I tried to switchoff my phone by pressing the button,. Meanwhile screen showed like empty battery sign and it turnoff automatically. I removed the battery and placed it over my table. Next morning i put my phone into my car dashboard and i placed my car in the sun heat.. Because the temperature is high these a days and inside the car it is like almost 48-50 DigCel.
    I will try to turn on my phone at the evening,. Let's see if it works..
    Debmeet BanerjeeJames Easter
    Kay Kraw Jul 26, 2015 Link to comment
    I dropped my Samsung Galaxy S3 mini (out of contract now) into a full mug of hot coffee (totally submerged). I immediately pulled it out. Dried the outside first with clean paper towel. Removed the outside holster case, the back panel of the phone, the battery and the SIM card and dried all of those carefully with paper towel. I dried the exposed phone as well. Then I let everything sit for about a half hour (finishing getting ready to go to work). Put it back together, turned it on and it booted up but kept saying "Sim card removed...Unable to read Sim card...Your device will restart" with a white bar below with "Restart" printed in it. I hit the restart prompt and it restarted. Well, again, after a few seconds gazing at the home screen the "Restart" thing kept showing up. I asked some coworkers (younger than me) what to do and they said to buy a bag of rice. A grocery store was next door so I bought a bag of rice and placed the phone with the back and battery removed (left the SIM card in this time in case it needed more drying off) and left it in the rest of the work day. When I got home, I removed it from the rice and put it back together again. Same thing happened with the restart, but it wouldn't show
    up as quick as before.
    Long story short it is now exactly two weeks later and the phone works as it used to except that the lighted "menu" and "back/return" buttons on the bottom are the only things that still do not work. So I just went under settings to "Accessibility" and scrolled down to the "Dexterity" section and clicked "ON" the Assistant menu. After you click that, a little white square box pops up with 4 smaller light gray squares inside of it. When you click on that, you'll immediately see four functions to choose from. The home and settings are permanent, you cannot move them from the basic screen but you can add 2 or more functions (there are 13 more to choose from). I really just needed the menu and back/return functions but you can add any or all of what are shown. The home function takes you back to your home screen but the settings function is for this "Edit" section of Assistant Menu" in case you ever want to change the functions you want to use here.
    To customize the small white box with your own function choices just touch the "Settings" function shown in the white box. You will then see "Dominant hand" and "Edit". When you "touch" Dominant hand, you make your choice. That takes you back to the same screen where now you would "touch" Edit - Reorder or remove menu. Now a large screen appears with 13 more functions to choose from. Press and hold on one of them until it turns light gray then move it up to the upper box. You will notice that you cannot remove the home and settings icons.
    The square white box will now be on any screen you work on. It can be annoying in that it shows up and blocks you from seeing a vital portion of your viewing screen, but all you have to do then is just touch it and move it where it will be out of your way.
    In short I was hoping my phone would eventually work, again. For me it was worth waiting two weeks because the main feature I love about this phone is the "mini" of it. I like it smaller because I clip it to my belt/waist which is very convenient for the type of work I do all day. My phone is 3 years old and the original battery lasts two days without recharging, probably because I rarely have my Mobile Data turned on. I only use the internet to check UPS orders twice a week. If I could, I'd keep this phone until I die.
    • 19
      And i thought my reply was long XD
    Gary Brunt May 26, 2015 Link to comment
    Believe me the Nexus 6 is not waterproof. Dropped my down the toilet 2 weeks ago, had it in rice etc. Now dead as a do do!!!!
  • Kelly Basden 3
    Kelly Basden May 25, 2015 Link to comment
    Grammar issues.
    Michael Latimer Mar 29, 2015 Link to comment
    The problem with rice is that it can't tell you when it's finished drying the device. People get antsy and try to charge/turn the phone on before it's fully dry and in so doing ruin the phone. Plus the rice dust isn't good for the phone.
    If you happen to be in the United States, find a local store with a Redux machine. (Redux.com) This machine is amazing. Steps 9 and 10 in this article are the steps that actually can damage a wet phone beyond repair. Just getting your phone wet doesn't kill it...running power through a wet phone kills it.
  • 19
    Moni Mihailov Mar 11, 2015 Link to comment
    When my S3 Mini gor wet what i did was i just took the back of and held it in front of the heater for around 10 mins and then it was 50 degrees Celsius so i waited for it to cool down and everything was working fine after that :)
    Anon Ymous Feb 28, 2015 Link to comment
    I dropped my Motorola Moto G (2015 model) in the toilet the other day and it stopped working...
    I basically did the majority of what was suggested NOT to do, including the following, in my panic following the incident:
    -Do not turn it on if it was off or use it in any way.
    -Do not press on any buttons or keys.
    -Do not shake, tap or bang the phone.
    -Do not take the phone apart, this could void your warranty. If you absolutely need to take it apart, do this only if you have experience.
    -Do not try to blow on it. This could send water into other internal parts of the phone which haven't been reached yet, causing more damage in the process.
    -Do not apply heat of any kind, including a blow dryer or microwaving it. Also, don’t do the opposite and stick it in the freezer.
    I did do the majority of the recommended things though too...
    What should I do? I only got it a couple of weeks ago...
    Kishore YerraMoni Mihailov
      Odbayar Tumendemberek Jun 3, 2015 Link to comment
      I've also dropped my phone (moto G) into water yesterday. Unfortunately, I turned it off, shook it and blew inside to dry out. It was working yesterday, but it is not working this morning. I put it into silica gel and planning to wait 1-2 days according to the recommendation. I am worried... What should I do?
      helpneeded Aug 5, 2015 Link to comment
      Hey Anon Ymous same thing happened tome. I did the same things you have mentioned. just wanted to know did your mobile start working?
      • vismit magotra 2
        vismit magotra Aug 5, 2015 Link to comment
        It is better to place it into the rice. Make sure it is airtight.
        What i did is, I placed my phone in my car and with the excessive sun heat all the water and moisture dried away. My phone is working fine now
      Ankit Sahu Aug 8, 2015 Link to comment
      Same thing happened and did same....someone plz tell what to dooooo
      shit this happend to me i shaked it to get the rice out
    Feranmi Aderonmu Feb 16, 2015 Link to comment
    happy to find out about this.Hope it will still work for my phone that dropped into water like 8 hours before i buried it in a bag full of uncooked rice.
    Moni Mihailov
  • Rogue Tomato 15
    Rogue Tomato Jan 25, 2015 Link to comment
    Rice really does work. It saved a very old Blackberry my daughter dropped in the cat's water dish. I had to hack the little cursor trackball which was ruined, but the phone worked.
    Moni Mihailov
      Preeti Kaur Jun 12, 2015 Link to comment
      I want to ask u something.....That if we had used uncooked rice does it works???
    Somercamb Feb 5, 2014 Link to comment
    Interesting that you say DO NOT push any buttons and yet the first WHAT TO DO is "turn off the phone" which means pressing a button....
    Moni MihailovHarsh Mauryasam pack
    • Loie Favre 33
      Loie Favre Feb 5, 2014 Link to comment
      In the best case situation, it's better to avoid pushing any buttons. However, turning off the phone is important as well...what people shouldn't do is go crazy and press buttons repeatedly to see if the phone works right when it's fished out of the water.
      LibdtMoni Mihailov
      • Rogue Tomato 15
        You could simply remove the battery (if it's a phone with a removable battery). I'm pretty sure the phone turns off that way. ;)
        VulijjinhlongMoni Mihailov
