How to fix LG G3 problems the easy way
androidpit lg g3 update hero
The LG G3 is a great phone, but, like all phones, it has a few problems. From overheating to lag to camera bugs, here are the main LG G3 problems and their solutions.
14
Every LG G3 has its problems. But we have the solutions. / © ANDROIDPIT
Note: a lot of common problems, such Wi-Fi dropping in and out, automatic restarts (or shutdowns) and Bluetooth connectivity issues are very common and are easily fixed with a factory reset of the LG G3.
Make sure you do a full backup first, then go to Settings > Backup & Reset > Factory Data Reset. Or you can turn off your G3 and press and hold Power and Volume Down until you see the LG logo, release them quickly and press them both again until you see the Factory Reset screen. Choose 'yes' and then reboot and restore your data.
androidpit lg g3 teaser
KnockOn is great on the LG G3, but not from inside your pocket. / © ANDROIDPIT
LG G3: assorted Lollipop issues
Upgrading to Lollipop hasn't been a sweet experience for some LG G3 users, and issues such as poor battery life, very hot running, desperately slow performance, crashing and spontaneous reboots are well documented. A Lollipop update ought to fix that, but it seems that LG may skip Android 5.1 and go directly to Android M. In some respects that's good — Android M, yay! — but it means waiting even longer for hoped-for fixes. In the meantime, some of the following tips may help.
LG G3 turns on in your pocket
Problem
KnockOn is a great addition to LG's repertoire, but for some odd reason the sensors don't always seem to notice that the device is in your pocket, and you'll find that your G3 has turned itself on.
Solution
Disable KnockOn or use a flip cover to avoid unnecessary pocket activity. If you simply love KnockOn (as I do), then the best solution I've found is to face the screen of the G3 away from my body. Not exactly ergonomic but it works.
Here's how to disable KnockOn, which is now located in a hidden menu. For the international G3, go to the dialer and enter 3845#*855#, scroll down to the KnockOn setting and turn it off.
If you have a carrier branded G3, substitute the previous code for the following: ##228378 for Verizon3845#*850# for AT&T, 3845#*851# for T-Mobile and 5689#*990# for Sprint.
AndroidPIT LG G3 Android 5 0 Lollipop hidden menu knockon
You can turn KnockOn off in the LG G3 hidden menu. / © ANDROIDPIT
LG G3 overheats
Problem
The LG G3 occasionally overheats either when accidentally turned on in your pocket or under heavy processor loads.
Solution
Reduce your display brightness, as this is the biggest power sucker on both the battery and processor when watching movies or playing games. Don't perform demanding tasks when charging the G3, and don't let it sit in direct sunlight.
Finally, keep an eye on running apps and processes in Settings > Battery > Battery Usage and Settings > Apps > Running to make sure you don't have excessive activity going on in the background that is causing your G3 to overheat.
Sadly for some users, the overheating issue appeared with Lollipop and didn't go away. Hopefully Android M will fix that.
AndroidPIT LG G3 Android 5 0 Lollipop battery usage running apps
In the LG G3 settings, Battery Usage and Running Apps are good places to spot runaway apps. / © ANDROIDPIT
LG G3 is laggy
Problem
Despite razor-sharp specs, the LG G3 still seems to suffer from occasional lag.
Solution
Ever since the update to Android 5.0 Lollipop update, I haven't noticed anywhere near the amount of lag as before, so your first step should be to make sure you have the latest Android version on your G3.
Some G3 owners have reported bugs with touch responsiveness. This can be adjusted in Settings > Accessibility > Touch Feedback Time to change between slow, medium or long.
AndroidPIT LG G3 Android 5 0 Lollipop Accessibility touch feedback
If your LG G3 screen response is slow, try changing the touch feedback time. / © ANDROIDPIT
You can also boot to recovery and clear the LG G3 cache (but only if you have previously installed a custom recovery like CWM or TWRP). Turn off your G3, then press and hold Power and Volume Down. When you see the LG logo, briefly release the buttons and then press them again.
You'll see a Factory Reset screen. Important: if you have stock recovery installed and you say 'yes' you will reset your phone. If you choose 'no' your phone will restart. Only if you have a custom recovery installed should you select 'yes.' This will then take you to recovery mode where you can clear the cache partition and then reboot.
Another solution comes courtesy of XDA Developers, where you access the hidden menu mentioned above and turn on High Temperature Property. From here you want to power down for a short while, then reboot and wait a minute before unlocking. Go back to the hidden menu and turn on Thermal Daemon Mitigation. I have no idea what this does but if XDA says it works I trust it.
AndroidPIT LG G3 Android 5 0 Lollipop hidden menu thermal temperature
In the LG G3 hidden menu, turn these two thermal settings ON. / © ANDROIDPIT
LG G3 has audio playback issue
Problem
On Android KitKat, there was occasionally a weird high pitched noise when you plugged headphones into the LG G3.
Solution
Following the update to Lollipop I haven't heard it again, but if you're still on KitKat you can switch from Dalvik to ART in your Runtime options. These are located in Developer Settings. If you don't already have these settings enabled, go to Settings > About Phone > Software info and tap Build Number 10 times until you see the toast notification that you are now a developer.
Go back to the main Settings page and you'll see Developer Options down the bottom. Just switch your runtime from Dalvik to ART (this option no longer exists in Lollipop, which uses ART by default).
androidpit art dalvik
ART is the default runtime in Android Lollipop, but you can still choose in KitKat. / © NextPit
LG G3 has battery problems
Problem
The LG G3 has had spotty battery performance. For some people it drains very fast.
Solution
The update to Android 5.0 Lollipop has improved the battery performance on the LG G3 significantly, but for some the update process leaves worse battery life than before. Try installing a custom recovery (as mentioned above) and heading to recovery mode so you can clear the cache partition and do a reset if the problem persists.
Usually clearing the cache partition following an update is enough to clear up initial battery bugs though, and things tend to settle down after a few days.
If this still hasn’t fixed the issue, you might want to do some detective work. Keep an eye on Battery and Running Apps to see which apps and processes are consuming the most resources.
You could also install an app such as Greenify to hibernate apps forcefully or Battery Doctor for further diagnosis. Make use of the LG G3's battery saving mode too and keep your screen brightness as low as you can handle.
${app-com.oasisfeng.greenify}${app-com.ijinshan.kbatterydoctor_en}
AndroidPIT LG G3 Quick Circle case 2
Just because the LG G3 battery is removable doesn't mean you should suffer from battery drain. / © ANDROIDPIT
LG G3 camera app crashes
Problem
The LG G3 has a great camera, but it does freeze or crash on occasion, whether you are shooting photos or video, especially when zooming.
Solution
This is a software bug that has also been fixed in the Lollipop update. Alternatively, you can ditch the stock camera app for something like Google Camera or you can try clearing the cache and data for the stock camera app and as a last resort do a factory reset. Make sure you backup everything before though.
AndroidPIT LG G3 Android 5 0 Lollipop camera app clear cache
Clear the stock LG G3 camera app or replace it with Google Camera. © ANDROIDPIT
What problem is your LG G3 experiencing? Got any fixes we missed?
Go to comment (85)
Kris Carlon
Kris Carlon
85 comments
    realmattify May 31, 2020 Link to comment
    hello a me have g3 and version problem how to fix version problem G3
    • marco sarli 39
      Jun 1, 2020 Link to comment
      Please explain what your problem is. It is not clear. Thanks
  • Mark Rakowitz 1
    Mark Rakowitz Jan 11, 2017 Link to comment
    LG G3 - After digitizer / screen replaced .........
    Sim card error comes and goes. Works fine then doesnt.
    Sometimes Message - "Sim card removed insert valid card then restart". Then it restarts.
    Sometimes- "Invalid card" on lock screen, upon reboot or during operation or just siting.
    Did factory reset , changed sim card. Same card works fine in other G3 and other phone.
    Had reader and all points checked. Can work fine for hours or 5 minutes.
    Nothing seems to trigger it , like using app or not, handling it or just on desk, charging or not. Help.
  • Roberto Enriquez 1
    Roberto Enriquez Oct 1, 2016 Link to comment
    Hi my LG G3 camera dont start even with the Factory Reset I also try other apps and doest seem to work could you please help me
  • AaDi RaNa 2
    AaDi RaNa Jul 7, 2016 Link to comment
    my lg g3 D851 T mobile turns off automatically it looks like that someone has pulled the battery out..... but no one has remove the battery... after that happens i am not able to turn it on... i have to pul the battery out or plug in the charger then it turns on.... I dont know what to do... please help
  • Sharon Griffin 1
    Sharon Griffin Jun 27, 2016 Link to comment
    I love my G3. However the speaking volume is so low I can't hear it. This started yesterday. I need my text messages spoken but now I cAnt hear them. The volume button is at the highest setting. I haven't recently added any apps. Help!
  • Jayk Tyler 1
    Jayk Tyler May 17, 2016 Link to comment
    I have been absolutely loving my LG G3, but when I got the Android 6.0 Marshmallow update I have noticed a significant increase in charge time, the battery drains about twice as fast under normal use, and all audio (through phone speakers, bluetooth headset, and 3.5mm audio jack speakers) is much quieter for all things. I heard repeatedly that clearing the cache partition might fix this, but as you are aware, you can't actually do that with stock recovery, which is all I have. I really Really do not want to factory reset as I have apps on my phone that I use all the time that are no longer available on google play. If you have any suggestion for me, I would be more than happy to hear them. As a side note, whenever I try to access the "Hidden Menu", it starts to run the USSD Code, but then simply pops up says Connection Problem or invalid MMI code.I have an AT&T version, but I have tried all of them and none work. Thank you in advance for any time and help anyone may be able to provide.
    Fred Flintstone Apr 18, 2016 Link to comment
    My D850 rooted with KitKat started having major wifi connectivity issues last week. This happened suddenly one day with no prior problems. There were no android updates and no app installed recently that would have prompted any issues. Factory reset, back to stock...ota update now running M...not rooted. Same horrible wifi issues. G3 will not "see" major networks that are strong and active. When signed in and a network is activated, it will suddenly turn off. Although Saved Wifi still shows the wifi network..it cannot be activated. Once in a while rebooting reestablishes the connection. Most of the time it does not. This is true on all the wifi networks I have in my life.
    Since the phone has been wiped and reset and I'm current with android...this appears to be a 100% hardware issue. Completely frustrated. About to throw the phone away because without wifi, it's not worth much.
    Do not believe that simply doing a factory reset will solve this problem as the author has suggested above. It goes deep.
    • Ryan Bray 1
      Ryan Bray Jun 13, 2016 Link to comment
      We had the same problem running stock marshmellow from LG/AT&T. Factory reset did not fix. I spent half a day flashing/rooting/ROMing to get stock Kitkat and then CyangenMod 13 (marshmellow) on our LG G3. We also bought a new battery (third one) for this phone. To no avail, wifi and power/restarting problems remain. For us at least, it's definitely a hardware issue with the phone, which really sucks because it's not even 18 months old an has always been in a protective case. We did an insurance claim on it, AT&T's insurance carrier is sending a replacement LG G5. Really disappointed in the G3, we have owned 3 Samsung phones and only had one (GS3) have a GPS issue after almost 4 years but otherwise it still works great. I've now owned a TV, fridge, and phone from LG, every single one of them had problems.
    fazenbaker Mar 9, 2016 Link to comment
    I'm having problems with my son's phone powering off soon after it comes on then powers up and back off and so on. I removed the battery for 10 sec. And put it back in and after some time it does it again. Do you have anything for this type of problem? Thanks
  • Jeevi Canales 1
    Jeevi Canales Jan 22, 2016 Link to comment
    How about the problem on my lg g3 d850 that became d855v? I thought everythings ok after update using lg pc suit but i noticed that i have no network so i cant call and text? Any solution for it?
    Zubis Emmanuel Jan 16, 2016 Link to comment
    Good news, i have found a solution for the over heating of LG G3.. just install another launcher and stop using the original launcher it came with, my G3 over heats when i use it from the range of 15 minutes up, but i decided to see how go launcher will look like in the G3 but after installing it, my G3 never over heat like before and this is the 4th day without over heat, please some one should try it and confirm. one luv.
  • 14
    Carlos Trentini Jan 14, 2016 Link to comment
    Hi there. If you are using an microSD card and having heavy battery drain, maybe, one of the reasons, could be the microSD card corrupted or in end of life. First test, reformat the microSD; second, remove the card. Try to avoid migrating apps to the card.
  • FAHIM ANJUM 2
    FAHIM ANJUM Jan 1, 2016 Link to comment
    MY LG G3 D851(T-Mobile) Android 4.4.2 is reboot or restart automatically although i change battery but all in vain.... Now the issue is come when i call some one from message inbox then it restart or 2nd when battery less then 30% if i receive the call it restart or shut down.
    First i bought LG G3 AT&T D850 but same problems.
    I reset mobile many times
    Hard reset, Factory Reset but all in vain
    some 1 can help me out ??????
    John Joseph Meidl
      do a factory reset i think it maybe an App that is causing it, i had that problem some time ago but i did a factory reset and it was solved, there maybe a particular App that is causing it
    • AaDi RaNa 2
      Fahim bhai.... koi solution mila??? mery pas b same model ha... nd now i m facing the same problem. chalta chalta apny aaap he bund ho jata ha with out any reason.. or phir on b nai hta asani se
    Allan Dobbin Dec 16, 2015 Link to comment
    Phone was good to start with. Now after 8 months I've changed battery 3 times...lagging badly and now for no reason the touch screen isn't coonnecting with my finger making txt imossible... For amp...if I press the centre it opens something at the top or bottom.....never
    again
    VAC Dec 13, 2015 Link to comment
    worst phone i have ever owned never a lg for me again.. From the beginning the aux plug didn't work (rgets mic inputs but my headphone is stereo without a mic ) nog i have the fone fo about a year battery life kinda sucks largely to blame to the crazy high resolution. Thats the only good thing about the screen... Low lid vallues, poor collors and power hogger... Last but not least the phone is getting really slow for all these high end spec..
    dhananjaya Kurukulsooriya Nov 25, 2015 Link to comment
    hey!!i got lg g3 d855 international version.there is a rattling sound near the camera when i shake it..when i open the camera app and then there is not any sound..plz frnds tell me something about this...
    Oliver Jenner
      Oliver Jenner Dec 10, 2015 Link to comment
      I have exactly the same problem. I have no solution I'm afraid, but revealing that the open camera app eliminates and/or reduces the rattle greatly (which it does in my case) proves that it's a design fault/not caused by the owner. So thanks :-)
      • Elias 1
        Elias Jul 13, 2018 Link to comment
        I noticed this with my g3 but the sound is the sensor not being stabilized while it's not in use. When it's being used the electronic stabilization activates thus no rattle is heard.
    Paul Wallace Nov 5, 2015 Link to comment
    My G3 frequently crashes and turns itself off when I'm using the camera app, but also sometimes just on unlocking the screen. It won't power up without me removing and replacing the battery either. Nothing I've tried to fix it will help. It's driving my crazy, i'm stuck in a contract with it for another 14 months!
  • Paul Surratt 1
    Paul Surratt Oct 21, 2015 Link to comment
    Ever since upgrade to Lollipop, my Lg3 has randomly gone into Do not Disturb with that little star icon. I have no DND settings configured How can I stop this?
    • Tamiya Williams 1
      Tamiya Williams Nov 5, 2015 Link to comment
      I believe that has something to do with your sound.
  • mathew Kidman 1
    mathew Kidman Oct 19, 2015 Link to comment
    This is a **** Korean phone that chooses tech gimmicks over practicality! what use is a ******* HD display if battery is dead in 2 hours!, I see a lot of Korean fake LG techs on here crying about apps etc.. WtfWtf! I have a Xperia z2 that works twice as long! Why is the g3 such a **** battery hog? Because over clocking and gimmicky screen and stupid features make if this way... Same to Sammy also, people wake up you have a **** phone, next time get Apple or Sony.
    Yenny Chia Oct 14, 2015 Link to comment
    my g3 all the sudden doesnt want to connect to wifi bluetooth and data networks. i need to turn off then turn it on to be able to connect to wifi and then the phone keep restarting itself.. once it restart the connection problem come again. i tried factory reset my phone for 3x but it didnt work, i still face the same issue. not to forget, my battery drain very fast even though i didnt do anything with it. anyone know to fix this????
    thanks
  • mathew Kidman 1
    mathew Kidman Oct 13, 2015 Link to comment
    LISTEN CLEARLY I HAVE THIS SHITTY PHONE ALSO. Next time do yourself a favor and stop buying SHITTY Korean garbage. I went and bought a Sony Xperia and we'll Iphone is not bad either, lesson learned. KOREANS MAYBE BE GOOD AT stealing IDEAS AND TECH BUT THEY DO NOT know jack SHIT ABOUT MASTERING THEM. Stay clear away from LG garbage they make good as unit's I heard and of course Koreans stole /bought their way into the LCD world. That's all they know so fuck this Korean garbage.
  • Pauric Donnelly 1
    Pauric Donnelly Oct 1, 2015 Link to comment
    You had said that to stop the automatic restarts, you had to backup the phone then factory reset it. Done all that but now it seems to be doing it even more, in fact, it doesnt even let me unlock it at some stages unless in connected to the charger. Any suggestions?
      Jar Oct 5, 2015 Link to comment
      maybe a bad battery try a new one
      Hassaan Khan Oct 14, 2015 Link to comment
      I am having the same problem. can you help?
      marisa o Dec 19, 2015 Link to comment
      I havent reset mine yet, but it is currently turning on and off every minute. I've had problems with it since I got it a year ago. My second battery is crap and wont keep the phone on. Apparently it only stays on when plugged in. Incredibly frustrating to not be able to use it at all.
        Denver Dogwe Feb 19, 2016 Link to comment
        mine too. it wont turn on if not connected to the charger :(
    Jeremy Brooks Sep 28, 2015 Link to comment
    Updated my lg g3 to 5.0.1 and now when i use headphones or an aux cord in my truck, google voice pops up. Super annoying.
    John Kelley Sep 27, 2015 Link to comment
    Just got my LG g3 loved it I done the update and now it won't play videos on YouTube tried to uninstall YouTube but still have same problems
  • ZakiSFgame 2
    ZakiSFgame Sep 23, 2015 Link to comment
    After the unwanted upgrade to Lolipop 5.0 my LG G3 cant load SIM cards. Tried different ones, none works after the update. Anyone got any ideas on fixing this?
    Michael Campbell
    Lynda G Sep 18, 2015 Link to comment
    Loved the LG G3 at first. Did Lollipop Upgrade. Text messaging has been problematic ever since. The screen is very very very slow in responding. When I receive a text, and tap the Message icon, it takes about 30 seconds to click in to my list of messages, then another 30 seconds to respond to try to read the message. A lot of time the screen goes black. Everything but Text Messaging seems to be OK. With Bell Mobility in Canada. Lucky the phone is still under warranty. This is a big hindrance and very disappointed with my first LG device. I have checked for further updates; there are none. I'm up to date. I took the battery out and re-inserted it. Didn't solve the problem. I'll be contacting my mobile carrier for assistance and see what they say.
      Lynda G Sep 23, 2015 Link to comment
      UPDATE: I contacted Bell Mobility (Canada). The tech support guy was a jerk. He was Googling the issue while I was waiting, as if I can't do that myself (which I did). Then he had me go into Developer mode but had no advice on what to change once in that mode. I thought that was sort of a dangerous path to take. I'm not a developer - not even close. Then he told me to send the phone back for repair, without walking me through any diagnostics whatsoever. Later I installed the new Google Messenger app and made it the default SMS/MMS app on the LG G3. Voila! There is no lag using Google Messenger or any black screen. The response receiving and sending SMS and MMS messages is quick, just like it should be. To me this indicates a software rather than hardware issue, the issue being with the Messaging app built in to Lollipop. The built-in Android/LG Messaging App was the only thing that was problematic on this phone. The new Google Messenger is an OK app, but it doesn't have very good Notifications when you receive a text, and the colours are god-awful with no capability to manage your own colours. Hope these things come in future releases of Google Messenger.
      John Kelley
      • Mallory Wooten 1
        Mallory Wooten Sep 29, 2015 Link to comment
        THANK YOU. This is the only post I can easily find with the same EXACT issue I've been having on my G3. (I use T-Mobile.) Since the problem seems mostly regarding the default sms message app, I was hoping to see if the Google sms app might work better. I'll give that a go!
        Kyle Nov 15, 2015 Link to comment
        Thanks for your post. Seems that it is a rare issue because there is so little info on it. I will be going to a secondary messenger.
    Lexi Cleghorn Sep 14, 2015 Link to comment
    Hello all! Please help! My front facing camera is a small square in the middle of my screen...i dont know how to fix this!! The only time it happens is when i want to use my regular camera app..snapchat Facebook and all others the front facing camera works just fine.
      Jan Wintermans Sep 15, 2015 Link to comment
      I cn think of two things: either your quick cricle is active,
      Or if there is bright white around the front camera video, your flashlight is active.
      Lou Waller Sep 16, 2015 Link to comment
      Turn your flash off. I had a pinky screen on mine and thats so u get better light in the dark when doing selfies:)
      Shanti Ratnavali Sep 23, 2015 Link to comment
      Small square is not an issue. It's coz lg g3 enables flash brightness for front cam too. Jus click on flash symbol on d screen above d square. It ll show complete screen.
    Jan Wintermans Sep 9, 2015 Link to comment
    I have a problem with the lg g3 quick case. If I flip the cover to the back of the phone, it activates the quick cirkle. Is there any way to lower the sensitivity of the sensor for the quick circle?
  • Ian Saville 1
    Ian Saville Sep 4, 2015 Link to comment
    Hello. I have a problem with my LG G3. Every time I start the phone app, and go to the contacts tab, I get a revolving circle and the message "contact list is being updated", or "contact list is being updated to reflect change of language". This goes on for several minutes, during which I can't use the phone. Any idea of a solution?
  • stephan kinsey 1
    stephan kinsey Sep 3, 2015 Link to comment
    Change your batt works 100%
    joe richard Sep 1, 2015 Link to comment
    I just upgraded my G3 and the phone keeps wanting to upgrade again and again. Also getting message at start up telling me how to swipe to other screens. Thanks for nothing LG
    Scott Morley Aug 29, 2015 Link to comment
    I cannot turn off the sms auto response! It's not in driving mode and it's not for rejected calls, but every text msg gets the auto response. Grr help!
    Woytaz7 Aug 25, 2015 Link to comment
    Hi everyone. I have a solution! Get a new battery ! Your phone will be fine again, no restarts. I had the same problem ( lg g3 restarting all the time) and I changed the battery! Now everything is fine.
      zachary white Sep 23, 2015 Link to comment
      i have gotten three new batteries and two replacement phones and it is still restarting constantly
      I Changed the battery, its still happening
    Aubz Uy Aug 24, 2015 Link to comment
    My LG G3 just wants to restart all the time
    i cannot open my lg g3 phone..everytime i try to open it, it continues to reboot. How can i fix it?
  • Eric Larkin 1
    Eric Larkin Aug 22, 2015 Link to comment
    My issue with the LG G3 is with the phone & contacts. Periodically throughout the day; the phone will want to update the contacts. I am unable to make or receive any calls & I am unable to send any texts. The history of calls disappears along with all of my contacts. It usually takes 5 minutes for the phone to cycle through the updates. If I try to reboot during this to unlock the phone or clear all open apps as a work around...it only delays things further. I haven't contacted verizon or LG about this yet and was hoping to find a solution by GTS'ing.
  • D.J. Coop 1
    D.J. Coop Aug 18, 2015 Link to comment
    Overheating and restarting... I've had this problem for about a month now. Did factory reset, no help... Tmobile sent me a replacement G3 and it was OK for about a week, now its back to restarting all the time. Blah
      worst high end android i have ever owned...
    Tracey Reimer Aug 17, 2015 Link to comment
    Cant send mms. No videos will send on chomp or factory installed messenger . stupid ive troed it all
      Devin H. Aug 19, 2015 Link to comment
      I had the same problem with the LG G3's factory installed "Messaging" app. The solution that worked for me was downloading Google's "Messenger" app and setting it at my default. Hope that helps.
    Hendriek Burggraeve Aug 11, 2015 Link to comment
    My LG G3 was restarting himself all the time, the thing is, every time I opened an app, the phone shuts down and restarts. For example snapchat, the camera app and so on.., it seems like every time he needs a lot power from the battery to open an camera app or something else that needs power he shuts down. I also kept an eye on the battery, if i was on 20% battery life and he restarted, he only had 11% left. I thought that it was the battery itself. Also when i shook my phone it restarted too. It is also weird he only restarts when he is almost out of power. I tested the phone when he was charging around 15% and nothing happend so I decided to buy a new battery online and it works perfectly fine now :) I hope I can help people with this, buying a new battery could solve your problem. I think its a more a battery failure than a software bug.
    caleb bailey Aug 11, 2015 Link to comment
    My LG G3 just wants to restart all the time now as well. :(
    Mansour Muhi Edin Aug 8, 2015 Link to comment
    Hello
    My phone lg g3 . I backup system .
    When i wanted to restore it (because i installed another rom) it still switching on ( lg symbol)
    Any help !!
    Rana Haroon Aug 5, 2015 Link to comment
    My LG G3 keeps on restarting again and again, the android version is 5.0, i have done a factory reset but it was of no use and the phone while charging through my computer restarted about 4 times in 2 hours !
    Junior Diaz Aug 5, 2015 Link to comment
    I got into a system of pressing the greenify widget, then going into my settings by holding the square, and going into battery and stop any apps like Google maps that were running in the background. So now every time a go to setting by pressing the square seeing automatically shits me out unless I go to battery
    Nayr Aug 4, 2015 Link to comment
    This is my first and last LG phone. Too many frustrations within just a year of purchase. Can't wait to get rid of it.
    Natalie Upshaw
    Nurhasyanah Syarifuddin Jul 29, 2015 Link to comment
    I had problems with my cell phone LG G3. while I restart my phone appears the phrase "wrong battery" and suddenly turns off itself. when I tried to charge my phone can not connect. Please help me
  • Adarsh Badoreea 2
    Adarsh Badoreea Jul 20, 2015 Link to comment
    Hi my lg g3 keeps going off then acts as if its going to restart but switches straight off again a few seconds later if i plug it in to the charger it works fine but as soon as its out does it again I've done factory reset but still does it any ideas or anyone else had this problem the ohones not
    really old
    Caren Beltran
      Caren Beltran Aug 2, 2015 Link to comment
      That is happening to me too. Have you figured out how to fix it?
      George Emery Aug 17, 2015 Link to comment
      Exactly the same issue
    • stephan kinsey 1
      stephan kinsey Aug 29, 2015 Link to comment
      Mines the same currenty on charge now then wont go past lg screen if i unplug going to try new battery will let you know how it goes
        i have the same issues i have gotten a replacement phone and a new battery for it and it didnt work at all for me
    Craig Allen Jun 4, 2015 Link to comment
    really old
      Art Dej Jun 11, 2015 Link to comment
      I just went to LG service centre due to phone keep rebooting. They said maybe a battery issue as it not design for you to keep charging the battery like other phone.
        dan man Jun 13, 2015 Link to comment
        I have the same issue, my LG G3 is restarting on it's own without any reason or error message or whatever, and also when i'm turning on the mobile data. What would be the problem? Can anyone helps us. Thanks
        Nick James Jun 23, 2015 Link to comment
        My LG G3 in the last few weeks did this a lot! I factory reset the phone with no avail! But after experimenting I have only noticed it happening when it's been in my pocket. I turn it on. After doing something on my phone, even just unlocking the screen or put Wifi/Data on or anything that adds extra heat just reboots it. I just take it out of my pocket and leave it off for 5 mins, then switch on again and it's totally stable! Mind you I have a plastic case round it. I will experiment without it!
      gina Jul 2, 2015 Link to comment
      Am facing the same problem. Any one who has a solution for it? Or knows what the problem could be???
        Nick James Jul 2, 2015 Link to comment
        Found out the last several days our weather has been hot and humid. Been rebooting quite regularly now! But behaving much better first thing in the morning and late at night as long as it hasn't been a humid night. It's been a pain as I have tried factory settings with no success. Anything non software based (eg recovery, bootloader and when apps are updating after applying update or deleting cache) are totally fine even in humid conditions but the moment the software loads up and the phone is too hot (after playing an intense game or screen brightness for too long) it reboots straight away and will keep rebooting until the phone cools down! Have also tried placing in my pocket without my plastic case with no success either.
    madyury07 May 12, 2015 Link to comment
    running 5.0.1 on my t-mobile lg g3.....recently having issues with SMS sending via various apps (google messenger, stock app, hangouts) so here is the issue: whenever on WiFi it takes forever to send a text or MMS...after WiFi turned of the 4G icon do not show up on the status screen......need to turn airplane mode on and then of.....
    going to try factory reset tonight
    Niranjan May 11, 2015 Link to comment
    i am using LG G3 with its quick circle case that came along with the product. As long as i was with Kitkat i was able to change the clock face by swiping the clock face. however after updating to Lollipop i can't change the clock face on the quick circle case. when i go to settings (General>QuickCircleCase>Select apps> ) i cant click the settings option in it which allows me to enable the option to change clock face. i tried unchecking other items but the option to check the settings box is unavailable.
    can anyone help me to fix this so that i can change the clock face?
    Corey James Bartlett Mar 20, 2015 Link to comment
    does anyone know if a case would absorb some of the heat from the g3?
      Christina Waters Jul 13, 2015 Link to comment
      Nope, cases just make it hotter. I have a body glove case and seen temps over 113
    Ahtasham Khan Feb 11, 2015 Link to comment
    Not really,
    I used 3 galaxies 1, 2 and 3(4g) but this phone is lot smoother. I am glad i changed from Samsung to LG. I think also coz its Lollipop, but at least it has got knock code, rear button and wireless charging. All great. I must say i've never had to reboot my phone coz it hangs or so which was quite normal with the previous. I would recommend you to update to the Android 5. Also the battery life is great. You get around 5 hours screen on time and with moderate usage u still have 30 or 40 % at the end of the day.
    Thanks
    Niel Feb 11, 2015 Link to comment
    If I understand this article correctly, lollipop fixes almost everything? :)
    I got the update to lollipop notification in December, but I decided to wait. Now the notification has disappeared and I can no longer update? I have the international LG G3 from Belgium (Europe). When I look for an update it now gives a notification that I'm on the latest firmware, while for 2 months it displayed there was an update to 5.0?
      I had the same problem. One day i connected to the LG PC SUITE software and found the update. I have even had another OTA update after that.Just try that.
        Thank you. Have you noticed any bugs in the new OS? I have bad experiences in updating on my previous smartphones (samsung).
