Galaxy S4 tips and tricks: get the most out of Lollipop
androidpit samsung galaxy s4 hero 5
Ever since the Galaxy S4 got the Lollipop update, the old beast has been chugging along just fine. We're so fond of the S4 that we thought we'd share our ultimate list of Galaxy S4 tips and tricks, specifically for the Lollipop update. The Galaxy S4 is still a great phone, but read on to see just how much better you can now make it.
Jump directly to:
Battery tips
Save battery with smarter Wi-Fi
If you have your Wi-Fi set to disconnect whenever the screen is off, you might think you're saving battery. That's not the case. Most of us turn our screen on an average of 150 times a day, so keeping Wi-Fi connected is actually better than turning it off and on, and then searching for connections every time. Go to Settings > Wi-Fi, tap the soft menu key and then Advanced and set Keep Wi-Fi on During Sleep to Always.
AndroidPIT Galaxy S4 Lollipop Wi Fi settings off while asleep
Keeping Wi-Fi on continuously is actually better for battery life. / © ANDROIDPIT
Get better battery life
The Galaxy S4 doesn't have the stock Android Lollipop Battery Saver mode, but it does have Samsung's Power Saver Mode. Go to Settings > My Device > Power Saving Mode and flip the switch to enable it. It works by disabling certain functions in order to conserve battery life. You can choose which functions these will be in the settings.
AndroidPIT Galaxy S4 Lollipop power saving mode
Power Saving Mode will help extend your S4's  battery life. / © ANDROIDPIT
Disable pointless gimmicks
Samsung has always been known – at least until recently – for packing its phones with some occasionally less-than-useful features. Some of these features are enabled by default and are continuously sucking battery and processor power to work, even if you never use them. If you're not a gesture kind of guy, why not turn them off? Go to Settings > Motions and Gestures and turn off the features you don't want. The same goes for Smart Screen and Air View.
s4 tips 4
If you're not using it, disable it. / © ANDROIDPIT
Display tips
Always get the best display
One of the best things about Samsung displays is that they adapt to different conditions, so you always get the best possible viewing experience, whether you're reading, looking at photos or watching a movie. Just go to Settings > My Device > Display > Screen Mode and choose Adapt Display, or check out the other options.
s4 tips 1
Optimize the Galaxy S4 display. / © ANDROIDPIT
Activate Smart stay
Smart stay uses your phone's front-facing camera to detect whether you're looking at the screen or not, and makes sure that the screen remains on for as long as you look at it. This is great if you want to have a short screen timeout but also do a lot of reading on your phone.
To activate Smart stay, go to Settings > My device > Smart screen and press Smart stay.
s4 tips 9
Smart stay means your phone stays on as long as you're reading or otherwise looking at the screen. / © ANDROIDPIT
Software tips
Disable S Voice for faster navigation
S Voice can be launched by double-pressing the S4's home key. This shortcut actually slows down the home key response. TouchWiz will momentarily pause after the first press to see if you press it a second time, and then take you to the home screen. Go to S Voice, press the menu key, select Settings and uncheck the box next to Open via the Home Key to make home key navigation faster.
AndroidPIT Galaxy S4 Lollipop S Voice home button shortcut
Ditching the S Voice shortcut will speed up home key navigation. / © ANDROIDPIT
Secure your lock screen notifications
Lollipop comes with lock screen notifications, meaning you don't have to completely unlock your phone just to read a text or email. That said, you may not feel comfortable having the contents of your notifications plastered all over your screen for all the world to see. If you do, go to Settings > My Device > Sounds and Notifications. You can select which apps will display content on the lock screen in Application notifications and the level of content in While locked.
AndroidPIT Galaxy S4 Lollipop lock screen notifications
Choose your lock screen notification apps and content settings. / © ANDROIDPIT
Turn off annoying Samsung sounds
While you're at it, why not turn off some of those annoying Samsung sounds? Even if you do like them I can assure you that everyone on the train, at work and in the supermarket hates them. So, do the world a favor: go to Settings > My Device > Sounds and Notifications > Other Sounds and uncheck the boxes for as many sounds as you can live without.
AndroidPIT Galaxy S4 Lollipop turn off samsung sounds
Do the world a favor and lose those annoying Samsung sounds. / © ANDROIDPIT
Customize your lock screen
Don't settle for a boring old lock screen, add a camera and dialer shortcut, select a clock or private message and give it some pizzazz with a custom wallpaper. Go to Settings > My Device > Lock Screen and check the box for camera, then customize your lock screen widgets.
s4 tips 7
Customize your lock screen so you can access what you need more quickly. / © ANDROIDPIT
Supercharge your camera
Install the Samsung Smart Camera app and connect your phone to your camera with NFC to transfer photos faster, use your phone as a remote viewfinder (hello, selfie sticks!) and more. Best of all, your camera will automatically connect to your phone when it's on.
AndroidPIT Galaxy S4 Lollipop smart camera nfc pairing
Pairing your phone to your camera is very worthwhile. / © ANDROIDPIT
Customize your Quick Settings
Why settle for the standard Quick Settings when you can curate a custom batch of the most useful toggles and switches for the way you use your phone? You can even arrange them exactly how you like. Swipe down from the top of the screen, tap the little grid in the top right corner and then the little pencil to edit, and then rearrange your Quick Settings.
s4 tips 5
Add your favorite shortcuts to your Quick Settings. / © ANDROIDPIT
Make security smarter
Why would you want to unlock your phone with a PIN or pattern when you're at home where (I hope) you can trust everyone? That's where Lollipop's cool Smart Lock feature comes in. You can save yourself the trouble of unlocking your phone in certain places by adding a trusted face or voice, or a smartwatch or other trusted device.
AndroidPIT Galaxy S4 Lollipop smart lock trusted device
Smart Lock is one of the coolest Lollipop features. / © ANDROIDPIT
Use Do Not Disturb mode
Another great Lollipop feature is Priority Notifications, also known as Do Not Disturb mode. It lets you set times so you won't be interrupted, except for the most critical notifications or alarms. You can keep calls from your family and boss on the white list, set days and times of the week and choose between calls, messages and calendar reminders. Go to Settings > My Device > Sounds and Notifications > Interruptions and get busy - or not.
AndroidPIT Galaxy S4 Lollipop priority interruptions
Enjoy a little peace and quiet with Priority Notifications. / © ANDROIDPIT
Use shortcuts to call or message contacts
Why use messy menu buttons when a single gesture will suffice? In your contacts list you can simply swipe someone's name to the left or right to instantly call or message them. Now you can stay in touch more easily and save time while you're doing it.
AndroidPIT Galaxy S4 Lollipop contacts shortcut message call
Call or text your friends even faster with gestures. / © ANDROIDPIT
Always get the best photo
Let's face it, not all of us are Pulitzer Prize-winning photographers. So when a moment really maters, why not shoot a burst of pics and then have your S4 choose the best one for you? Just open the camera app, tap Mode and Best Photo. Hold down the shutter to shoot a bunch of pics and let your phone automatically choose the best one.
AndroidPIT Galaxy S4 Lollipop camera best photo
Best Photo always knows which shot is best. / © ANDROIDPIT
Enjoy Silent Mode
The Galaxy S4 is one of the few devices to enjoy true Silent Mode, even on Lollipop. You can go to Settings > My Device > Sounds and Notifications > Interruptions > Sound Mode > Mute or you can use the toggle in the Quick Settings to switch from sound to vibrate to mute.
AndroidPIT Galaxy S4 Lollipop mute mode
The Galaxy S4 is one of the few Lollipop devices still with mute mode. / © ANDROIDPIT
Get a custom sound profile
If you have very discerning ears, or simply like to have complete control over what comes out of the device you use to speak to people, why not get a custom sound profile? Go to Settings > My Device > Sounds and Notifications > Adapt Sound. Put in some headphones, tap Start and then follow the prompts.
AndroidPIT Galaxy S4 Lollipop adapt sound
Getting a custom sound profile makes everything sound better. / © ANDROIDPIT
Tricks
Make the keyboard smarter
If you're using the stock Samsung keyboard, make sure you have both predictive text and swipe typing enabled.You'll be amazed at how much time they can save you. Go to the keyboard and long press the button to the left of the space bar. Tap the Settings cog and make sure Predictive Text is on, and that Keyboard Swipe is set to Continuous Input. You could also replace the keyboard with SwiftKey or another keyboard app.
AndroidPIT Galaxy S4 Lollipop keyboard settings swipe
If you're not swipe typing with predictive you're living in the early 2000s. / © ANDROIDPIT
${app-com.touchtype.swiftkey}
Try the floating keyboard
Depending on what you're doing, a smaller, floating keyboard might be more suitable. This neat little feature doesn't lock your keyboard to the bottom of the screen.  Go to the keyboard, long press the button to the left of the space bar and tap the tile with the two overlapping boxes. Your keyboard will shrink a little and then be movable.
s4 tips 2
A mini floating keyboard can be really useful. / © ANDROIDPIT
Make Chrome easier and better
Chrome on Lollipop is a little annoying. By default your Chrome tabs will live individually in your recent apps list (accessed by long pressing the home button). If you prefer the old way – all your tabs contained in Chrome itself – go to Chrome, tap the three dots in the top right-hand corner, select Settings and turn off Merge Tabs and Apps.
AndroidPIT Galaxy S4 Lollipop merge chrome tabs
Keep Chrome old-school and don't merge tabs and apps. / © ANDROIDPIT
Make things simpler with Easy Mode
If you're a bit bamboozled by all the Samsung widgets and doodads in TouchWiz, give Easy Mode a shot instead. It'll clear things up. This way you'll only see the most important stuff, as well as enlarge icons and make everything easier for you to manage and navigate. Go to Settings > My Device > Easy Mode to make the switch.
s4 tips 3
Easy Mode is great for beginners, the elderly and visually impaired people. / © ANDROIDPIT
Get lazy with Hands-Free Mode
If don't want to miss any incoming messages or notifications, and your hands are otherwise engaged, why not use the Galaxy S4's Hands-Free Mode? Incoming calls, messages and notifications will be read out to you, so you always know what's going on. Go to Settings> My Device > Hands-Free Mode and flip the switch. Tapping the entry will let you choose what is possible.
s4 tips 6
Samsung has even hands-free options for the lazy amongst us. / © ANDROIDPIT
Use your phone to control the TV
Download the Peel Smart Remote app and use it to set up your TV guide, favorite channels, control your TV and set-top box, and plenty more. You can even put it on your lock screen or the notifications shade to make sure you're always the couch commando.
${app-tv.peel.samsung.app}
AndroidPIT Galaxy S4 Lollipop WatchOn remote control
Use your Galaxy S4 as a remote control. / © ANDROIDPIT
Use your voice for hands-free control
Did you know your S4 has lots of voice control options? You can use your voice to turn off alarms, take photos, play music and answer or reject calls. Just go to Settings > My Device > Voice Control and flip the switches for the commands you want to use. You can also use S Voice to set reminders or check the weather.
AndroidPIT Galaxy S4 Lollipop voice control settings
Use your voice and save your fingers from working too hard. / © ANDROIDPIT
Multi-Window and recent apps
The S4 can display your most recently opened apps, but did you know it also has a Multi-Window function that allows you to have two open windows at the same time? It is well hidden, but very handy! We've dedicated a whole article to showing how to use Samsung Multi-Window since it's so tricky to figure out.
multiwindow moto g4 plus androidpit
Multi-Window is tough to figure out, but really handy. / © NextPit
Common problems
No sound
Some users have had a software bug which silences their Galaxy S4. When there is no sound, it is due to a crashed app that is accessing the audio driver and blocking it. Restarting your phone will usually fix the problem.
Wi-Fi connection problems
When you're at home, you may well have noticed that your phone sometimes seems to have trouble connecting to your wireless network. This is usually the case when the Wi-Fi signal is weak, but it can crop up at other times as well.
s4 problems 7
Having trouble staying online? Try disabling mobile data. / © ANDROIDPIT
You may find that you are plagued with messages informing you that your internet connection has been disabled because of slow speeds. While this may sound counterintuitive, try disabling mobile data – you may just find that it helps. Swipe down from the top of the screen and toggle the Mobile Data setting to off.
s4 problems 8
A hidden menu provides access to Wi-Fi power-saving options. / © ANDROIDPIT
Another option is to disable Wi-Fi Power Save mode. Fire up the dialer and type the code *#0011# to enter Service Mode. Tap the menu key and select the Wi-Fi option. Under the Wi-Fi Power Save Mode heading, tap the On button so that it changes to Off. Press the back button to return to the home screen.
Video playback not working
Many users are having a hard time playing videos sent via WhatsApp on the Galaxy S4. When you get an error message from WhatsApp telling you, "video playback not possible" it can be fixed. Go into your settings and find the application manager, then reset your app defaults. If that doesn't fix the problem, download VLC media player.
${app-org.videolan.vlc}
Advanced tips
Access the Galaxy S4's hidden settings
There's a great app called Note 2 Hidden Settings that also works with other Galaxy devices, including the S4. It won't work with some carrier-branded models, but it's worth installing and giving it a shot because there's heaps of cool stuff in this app.
s4 tips 8
Hidden Settings aren't visible on all S4s but it's worth finding out if they are on yours. / © ANDROIDPIT
Fix bugs in Safe Mode
If your Galaxy S4 is acting strangely, you might want to restart it in Safe mode until you can solve the problem. To do this, simply turn your S4 off and then back on again. As soon as you see the Samsung screen, press and hold the volume down key and you will see that many apps will have been disabled when it boots up. To get out of safe mode, just turn your phone off and back on again.
s4 tips 10
Safe Mode lets you play around while most apps are disabled. / © ANDROIDPIT
Get a better launcher
If TouchWiz feels a little slow to you, why not replace with a faster launcher such as Google Now Launcher, Nova Launcher or Action launcher? Give them a try – they're free and you can always switch back if you want to.
s4 tips 11
Mix things up with a custom launcher. / © ANDROIDPIT
Make your own Qi wireless charger
If you want the wireless charging experience that the Galaxy S6 offers, without needing to fork out a small fortune to actually get an S6, why not buy a wireless charging pack? All you'll need to do then is take the back off your phone and align the tab as instructed in the packaging, then replace the phone's back panel.
phone battery
Get a wireless charging pack online so your S4 can enjoy the benefits of wireless charging. / © NextPit
Access the hidden developer settings
To access your Galaxy S4's hidden developer settings, go into your device's settings, tap More, and go into the software information. In the About device section, tap the Build number seven times, and you'll then have access. Then you're ready to change the animation speed, limit background processes, and use USB debugging, among other interesting things.
Root your device
To gain access to advanced features for your S4, you can root your device. This can be done at your own risk, and will likely void your warranty. You can find a full explanation of what rooting is, how it is done and reasons why you should or shouldn't do it in our full guide to rooting.
root s5
Rooting a Samsung device isn't too complicated. / © NextPit
Get Android 6.0 Marshmallow with CyanogenMod
The Galaxy S4 sold very well, and many people still have the devices. So, there are many volunteers who continue to provide software updates for the older device. You can get a Custom ROM update to Android 6.0 Marshmallow. For the full steps on how to get the update, see our article.
Did you try any of these Galaxy S4 tips and tricks? Do you have any others? Share them in the comments.
Go to comment (20)
Eric Ferrari-Herrmann
20 comments
    bellagreen Mar 20, 2017 Link to comment
    my battery life span so short
    Mohit Maheshwari Jan 14, 2016 Link to comment
    In my s4 device android 5 not working properly my application was close automatically in few second of use
    Oluwaseun Ola Nov 15, 2015 Link to comment
    Please help! Since i did the most recent software update about a week ago, the "back" and "menu" buttons on my samsung S4 have stopped working. Inly the middle button works. Thanks
  • PretBurg 78 1
    PretBurg 78 Oct 6, 2015 Link to comment
    Just a quick note, for point 12 you can use 2 fingers to scroll down the top screen and voila, the full list will be there, whereby 1 finger will only display a summary..
    Michel Tisdale Aug 20, 2015 Link to comment
    Just updated my samsung nook device and now there's a folder that acccesses my files and i don't even want to look at let alone have it in my face all the time. how do i get rid of it and get my nook last read back??? please help a sister out. thx
    Colleen Martin Jul 28, 2015 Link to comment
    I received a s4 as a gift 2 weeks ago with a new replacement battery, and my phone screen went into sleep mode and now it won't turn on or take a charge. Also, when charging phone I had to power off the phone and play with the charger connection to phone so it would charge up. This is my very first Samsung phone and if this is how these phones work, I think I will be going back to Apple... Also, this phone has never been dropped and has a Otterbox protective case on it.
      Jody Hagedorn Aug 2, 2015 Link to comment
      Dont give up on your droid; I much prefer t it over the iphone. It sounds like u received a used phone & the charging port is worn out. It is an inexpensive repair. U can even buy the part on ebay for $5 if you're up for doing it yourself. Watch the video on how to. In the meantime, wrapping thr chargng cord tightly around the phone activated mine to charge until I got it repaired locally. Sleep mode may just be a setting issue but obviouly u need it charged first.
    Gail Maxwell Jul 24, 2015 Link to comment
    Just updated my phone to lollipop and now I can no longer use my widgets nor can I mute or put my phone in silent mode. How can I default back to old system? I don't even like how it looks. The screen almost looks like something designed for seniors with large print.
    Shane Jun 30, 2015 Link to comment
    Before the update, my lock screen would show percentage of battery charge while it was plugged in. Now, nothing but the battery symbol. Is their a way to change it back? It was nice seeing 55% charged versus a battery image that's half full :-(
      Jamie Rose Jul 22, 2015 Link to comment
      The option is located in the settings under Display. At the bottom of the display settings list there is an option to "Show Battery Percentage". :D hope this helps
  • 10
    Douglas Nolan Jun 12, 2015 Link to comment
    Root, and install Cyanogenmod 12.1 Lollipop.. Runs sweet..!!!
    Mark Rgs
      Mark Rgs Jun 12, 2015 Link to comment
      Try resurrection replay it's even better 😊
    Amber Harmon Nov 2, 2014 Link to comment
    I have tried to flip the switch on the Favorite apps and camera to on but it's grayed out and won't turn on. How do I turn it on?
    joy kant Nov 1, 2014 Link to comment
    tips & tricks for note 2???
    Edward Netherton Oct 31, 2014 Link to comment
    It's good to know the hidden features of Galaxy S4 to make the most out of it. The features and functions of your S4 should be all in used.
    Vindictive
    Nelson Ford Jan 21, 2014 Link to comment
    With my Galaxy S4, I have more hiden features when I unlock that.
    There are a few tutorial where you can unroot samsung galaxy s4. You should see that you can use more hidden features. Thank anyway for these insights.
    Vindictive
  • Ali Raza 3
    Ali Raza Dec 29, 2013 Link to comment
    I love Smart camera app
    Moni Mihailov
    Dr. Alan Mandel Dec 28, 2013 Link to comment
    I have the MSL code from sprint for my phone and can get to the #data# page, but what can I modify on it to to improve my phone? I used to have the HTC evo3d and modded some settings but I have no idea what to do on the galaxy s4. Any info and ideas would be helpful and appreciated. Happy holidays!!
    Angel Ramos Dec 23, 2013 Link to comment
    ha just when I think I figured this phone out there is more to learn. plenty of pretty neat options with this
    VindictiveMoni Mihailov
