To convert a Lotus Notes NSF file into Outlook, you can choose a manual method and convert it to PST. However, manual methods need technicalities and can also increase the chance of data loss. If your mailbox data is essential, you shouldn’t take any risk and use a third-party SYSessential NSF to PST Converter to convert Lotus Notes NSF to Outlook.
In this case, you can choose SYSessential Converter for Lotus Notes because this is the most popular and recommended by top IT admins.
Let us now follow the steps of conversion:
Step 1-Firstly, download the NSF to PST app on your operating system.
Step 2-Install the application
Step 3-Now, select the Lotus Notes NSF files you want to convert.
Step 4-Preview those selected Lotus Notes NSF files.
Step 5-Locate the path for saving the converted Lotus Notes NSF files.
Step 6-At last, click the convert now button.
I hope the above information helps you to choose the best NSF to PST converter.
— modified on Aug 9, 2022, 1:14:47 PM by moderator
