- Forum posts: 23
Nov 29, 2020, 7:36:47 PM via Website
Nov 29, 2020 7:36:47 PM via Website
Volume sound equalizer is an essential tool for the music lover. You need this sound equalizer tool to adjust the sound volume on different music beats. You can custom select a sound and adjust and equalize the sound. This can also be a volume booster for the mobile speakers.
Sound equalizer and bass booster enables your sound bass adjustable using the equalizer options. Sound bass can be boosted without any rooting devices. Your mobile can be used as a DJ (Disk Jokey) while controlling the sound bass and tunes.
Important Features of Volume Sound Equalizer:
i - Bass and sound booster without rooting devices.
ii - Control sound volume and equalize sound.
iii - Easily adjust the sound bass with easy to use sound controller options.
iv - Share sound equalizer with friends on social media easily.
Note:
This sound equalizer is only a tool to provide assistance for adjusting sound volume using volume controller. This can damage your hearing problem and mobile speaker if you are using this app then check the mobile volume before switching the app.
Recommended editorial content
