CyanogenMod Installer: A simple solution
cm installer teaser
© CyanogenMod/nextpit
There's no doubt that custom ROMs are popular, but many people shrug off the possibility of getting them on their devices just by the sheer requirements needed to install them.  Unlocking your device, rooting it, backing up everything, and then flashing a new firmware makes some people balk at the idea of doing anything and just stick with their standard issued ROMs. The team behind CyanogenMod has therefor out on my Nexus 7 (2013).
cm installer teaser
© CyanogenMod/AndroidPIT
The CyanogenMod installer consists of two parts: an Android app and a Windows installer. Both work hand in hand during the installation phase, but at this point in time you'll actually have to make a request to become a beta tester for the installer before you can do anything. Head over to the Google+ community and request an invite to try it out for yourself.
Android Installer
The Android portion of the process really just serves one purpose: To prepare your smartphone for the installation process and make sure you've got the right settings enabled. It will check to see if you have USB debugging enabled on your device as well as the PTP USB Transfer mode enabled, and prompt you to enable them if they aren't already. As well, it gives you a step by step process and then prompts you to what you need to do on your PC.
CM1
Being approved as a tester and the welcome screen on the app. © NextPit
CM2
Walking you through enabling the right options and leading you to continue on your Windows PC. © NextPit
Windows Installer
Once you've done everything you need to get done on your Android device, you will be prompted to download the CyanogenMod installer for your Windows PC. Once the download is done and you fire up the installer, it'll start downloading any updates and other files it'll need for the process. This takes a good chunk of time (about 15 minutes in our tests) so feel free to go grab a coffee, let the dog out, or do whatever quick task you've been neglecting. Once the update is complete, the installer will prompt you to disable your anti-virus software (although, in my case, I didn't need to do this and it still worked) and tell you to connect your device.
cm installer windows anti virus detect device
Disabling the anti-virus and detection of your device. / © NextPit
Once connected, the installer will recognize the device and start downloading the recovery software specifically for your device, CyanogenMod, and the Google Apps package. As well, this will take a bit of time to perform as it's quite a large download and will depend on how busy the CM server is and your internet connection.
cyanogenmod installer download system apps
Downloading the necessary files for your device. / © NextPit
Once the downloads are complete, the CyanogenMod installer will be all good to go and will inform you that during the process, a factory reset will be performed on your device. As such, all your data on your device will be wiped. If you want to keep anything (contacts, messages, files, etc) make sure to perform a backup before proceeding past this point.
cyanogenmod installer cm ready install
All ready for the install process! / © NextPit
Once you click install, the installer performs all the tasks associated with having to install a custom ROM on your device: unlocking the bootloader, installing recovery software, and finally flashing CyanogenMod and Google Apps package to your device. All in all, this process takes about five minutes from start to finish and when completed, you'll have CyanogenMod installed on your device!
cyanogenmod installer cm ready install recovery
....and getting everything onto your device! / © NextPit
As a quick overview to the time that the entire process took for us, check out our table below:
Process Time
Updating the installer 15 Minutes
Downloading the required data 60 Minutes
Installation on device 5 Minutes
Total Time 80 Minutes
As long as you have a supported device (please see the end of the article for this information), the process of installing CyanogenMod using this method is both idiot proof and ridiculously simple. I even talked my fiancée, , who is by no means tech savvy, through the process while watching and she had no issues whatsoever with getting through it. While this does dumb-down the installation of a custom ROM quite a bit, it also provides a nice gateway for non-technical users to try something other than stock Android or whatever pre-loaded configuration came with their device.
Here's a list of the currently supported devices for the CyanogenMod Installer. Please note that this is being updated on the fly by the developers and you should check out the Google+ page (once you've been invited to the beta) for a more complete and updated list.
Supported devices as of October 9th, 2013:
  • find5 - Oppo Find 5
  • crespo - Google Nexus S
  • crespo4g - Google Nexus S
  • maguro - Google Galaxy Nexus (GSM)
  • toro - Google Galaxy Nexus (Verizon)
  • toroplus - Google Galaxy Nexus (Sprint)
  • grouper - Google Nexus 7 (WiFi)
  • tilapia - Google Nexus 7 (GSM)
  • flo - Google Nexus 7 2013 (WiFi)
  • mako - Google Nexus 4
  • manta - Google Nexus 10
  • skyrocket - Samsung Galaxy S II Skyrocket
  • hercules - Samsung Galaxy S II Hercules
  • i9100 - Samsung Galaxy S II (Intl)
  • i9300 - Samsung Galaxy S III (Intl)
  • d2att - Samsung Galaxy S III (AT&T)
  • d2spr - Samsung Galaxy S III (Sprint)
  • d2tmo - Samsung Galaxy S III (T-Mobile)
  • t769 - Samsung Galaxy S III (T-Mobile)
  • jfltexx - Samsung Galaxy S4 (Intl)
  • jfltespr - Samsung Galaxy S4 (Sprint)
  • jfltecan - Samsung Galaxy S4 (Canada)
  • jfltecri - Samsung Galaxy S4 (Cricket)
  • jfltecsp - Samsung Galaxy S4 (C Spire)
  • jfltetmo - Samsung Galaxy S4 (T-Mobile)
  • jflteusc - Samsung Galaxy S4 (US Cellular)
  • n7000 - Samsung Galaxy Note (Intl)
  • quincyatt - Samsung Galaxy Note (AT&T)
  • quincytmo - Samsung Galaxy Note (T-Mobile)
  • t0lte - Samsung Galaxy Note II (GSM LTE)
  • n7100 - Samsung Galaxy Note II (GSM)
  • t0lteatt - Samsung Galaxy Note II (AT&T)
  • t0ltetmo - Samsung Galaxy Note II (T-Mobile)
  • i605 - Samsung Galaxy Note II (Verizon)
  • l900 - Samsung Galaxy Note II (Sprint)
  • m7ul - HTC One (Unlocked)
  • m7tmo - HTC One (T-Mobile)
  • m7att - HTC One (AT&T)
  • m7spr - HTC One (Sprint)
So, has anyone else tried out the CyanogenMod installer? How did the process go for you?
Go to comment (22)
Sterling Keys
Sterling Keys
Freelance Editor
From all the way over on Vancouver Island, Sterling Keys started off his smartphone adventure with an HTC S710 equipped with Windows Mobile and knew there had to be something better. Over the next few years, and countless different operating systems, he has finally found his home on Android.
22 comments
    Jacob Scott Stockton Apr 21, 2015 Link to comment
    No, but make sure you know the code before you flash. You'll need to enter the code to access the SIM card once you've finished installing the ROM. Otherwise, you can remove the lock, ROM it, and reinstall the lock. If you forget any of this, go to your carrier to restore it, but you could lose many of your phone's contacts. Oh, and make sure you remove the SIM card and Micro-SD card before doing a flash. I made that mistake the first time I flashed my Galaxy S1. I lost half my friend's list; fortunately, I had my old-school black book.
    John Cunningham-Smith Aug 7, 2014 Link to comment
    Does the phone need to have the Network (SIM) Lock removed?
    Brendan Higgins Jan 30, 2014 Link to comment
    on the wiki page it says my i605 Galaxy Note 2 (verizon) isn't supported, but here it says that it is?
    Ped Dec 4, 2013 Link to comment
    now if they do one for the Ergo GoNote I bought my 6year old son to find that there is no provision to update the OS at all I would be straight in there. No way to update the version of Android that is on it typical British design. Pinky
    Allan Lariviere Nov 24, 2013 Link to comment
    Would this work for a Telus Canada S3 I747M?
    Kah Haur Nov 13, 2013 Link to comment
    Support token: fff1d0f7-8f86-48e5-b223-cae7a8faedd3
    Noly27 Oct 28, 2013 Link to comment
    It says its not supported when I connect to the phone
    Doesn't work on HTC one tmobil
  • CJ Brown 29
    CJ Brown Oct 21, 2013 Link to comment
    What? No LG models? :-/
    Art Oct 19, 2013 Link to comment
    Hey guys I love the concept but once CM is install how do you return to stock ROM. When I had my GS3 I had TWRP recovery and could back up your stick or existing ROM how do you do that with this method?
    Cesar Sanpedro Santiago Oct 17, 2013 Link to comment
    how can i uninstall this ? someone help please i did everything but i dont see google play and other apps help please
    my browser is askin me for a username and password...
  • Melroy van den Berg 1
    Melroy van den Berg Oct 14, 2013 Link to comment
    No, no need to root your phone at all. Your phone is also not rooted after the installation.
    Mike Tyrrell Oct 13, 2013 Link to comment
    Do I have to have my phone already rooted for this to work on my phone.
    Noly27 Oct 11, 2013 Link to comment
    Nice I can't wait
  • Sterling Keys 12
    Sterling Keys Oct 10, 2013 Link to comment
    Apolzan, like I said in the article, they are currently trying to update the list to include as many devices as possible. You'll have to check out their Google+ community page listed in the article to see what the current supported devices are.
    Apolzan Marius Oct 10, 2013 Link to comment
    all i see in that list of phones r just a few,what about of all other phones ? i have a samsung galaxy young gt-s6310 and after i tryed all the root programs i came up empty,nothing worked and my phone is still unrooted,and i don't see it in the list for this either,r many phones that r not highend that should be takin care of too...
  • Sterling Keys 12
    Richard: Head over to https://plus.google.com/communities/103540722025986617902 and request to be allowed to join. I got my acceptance in about 12 hours.
    Bruce: That it does. It removes any manufacturer firmware and installs CyanogenMod on your device (as long as its compatible). I put it on my Nexus 2013 and it works great. Love the new features. Just make sure that you do create a back up of your data and whatnot prior to doing anything. It does require you to do a factory reset on your device, so everything will be wiped during this.
    Bruce Arnold Oct 10, 2013 Link to comment
    I'm one of those people this app is meant for. I'm reasonably tech savvy, but not sure of my ability to got through the process manually. So I'm looking forward to this release. It will take all the bloatware off my phone, right?
    Dan Epps Oct 10, 2013 Link to comment
    Notably missing from the list is the AT&T Galaxy S4 i337.
  • patrick bath 5
    patrick bath Oct 10, 2013 Link to comment
    This guy works for samy?
    Richard Amber Oct 10, 2013 Link to comment
    how do I get an invite to join google+ community? it seems they're like the Illuminati.
