Android 5.1 Lollipop: 15 new reasons to update
AndroidPIT Nexus 5 android 5 1 lollipop teaser
OK, so Android 5.1 Lollipop has brought dual-SIM support, HD voice for supported devices and Device Protection (but just for the Nexus 6 and Nexus 9), but what else are you likely to see? Considering the official changelog isn't exactly visual-heavy, you might be surprised at some of the more subtle changes in Android 5.1. Here are 15 reasons to upgrade to Android 5.1 Lollipop.
Android 5.1 knocking the Nexus 5's socks off. / © ANDROIDPIT
1. Notifications can be dismissed to the status bar
With Android 5.1, when a heads up notification comes in while you're looking at the screen, you can now swipe it up to dismiss it but still keep it in the status bar and notifications shade. This may seem like a little change, but it's a godsend for gamers. Unfortunately the notifications ticker is still in limbo though. However, there is a new icon for when no SIM card is inserted. Cos, you know, that happens a lot.
Link to Video
2. Memory leak seems to be gone
It's still early days yet, but attempts to test the notorious memory leak problem on the Nexus 5 on Android 5.0.1 seems to have been dealt with. We'll hold our breath a little bit longer for the confirmation, but for now, it looks like the memory leak has been patched.
AndroidPIT Nexus 5 Android 5 0 and 5 1 comparison lock screen
Android 5.1 on the left, Android 5.0 on the right: no more lock icon circle, and the bounce animation from the Android L developer preview. / © ANDROIDPIT
3. Lock screen changes
On Android 5.1 when you press on the lock screen without swiping, you'll get a little bounce action that reminds you it's a swipeable screen. This was preview in Android L but didn't seem to make it to Android 5.0.
4. Google Play Store animations
If you had the Play Store updated to the latest version (v5.3.5) before updating to Android 5.1, you will notice a bunch of nice little animations when switching between Play Store categories or entries. Basically anything you do in the Play Store will now look a lot nicer.
AndroidPIT Nexus 5 Android 5 0 and 5 1 comparison quick settings
You can see the little down arrows next to Wi-Fi and Bluetooth in Android 5.1 (left). / © ANDROIDPIT
5. Quick Settings sub-menus and toggles
You can now bring up a drop-down menu within Quick Settings for Wi-Fi and Bluetooth connections (rather than being taken to the relative Settings sub-menu). Also, if either of these settings is turned off, when you tap the down arrow for the mini-menu, it will be automatically turned on. Very simple, very nice. We like.
AndroidPIT Nexus 5 Android 5 1 lquick settings wifi bluetooth
Android 5.1 now has Quick Settings mini-menus for Wi-Fi and Bluetooth (Android 5.0 took you to the full settings menu). / © ANDROIDPIT
You can also remove Quick Settings toggles simply by long-pressing them (these toggles appear in Quick Settings once activated in the Settings menu, like color inversion and Wi-Fi hotspot). Again, small details, but small details add up to the nicest version of Android Lollipop yet.
6. LED works in all sound modes
The LED light now works in all sound modes, including ''silent'' mode. Sadly, the standard mute mode (accessed previously by hitting volume down all the way) has still not been resurrected in Android 5.1, but you can achieve the same effect by selecting ''None'' in your volume widget: no noises, no vibrations. Speaking of sound, NuPlayer replaces AwesomePlayer as the default streaming content player in Android 5.1.
AndroidPIT Nexus 5 Android 5 1 Lollipop sound widget icons
Android 5.1 (left) adds little icons in the volume widget. / © ANDROIDPIT
7. New sound widget icons
In Android 5.0 you had a simple volume slider with three entries beneath it: None, Priority and All. The Android Team apparently felt this was a little too vague so they've now added a couple of icons to help you along: a crossed circle for None, a star for Priority Interruptions only, and a ringing bell for all. Makes sense.
8. New clear all notifications animation
When you tap the ''clear all'' notifications button you'll now get a nice little animation as all those notifications are whisked away to never never land.
AndroidPIT Nexus 5 Android 5 1 clock animation until next alarm priority mode
Each section in the clock app has an animation, and you can now turn off all interruptions only until your next alarm. / © ANDROIDPIT
9. ''Until next alarm'' interruptions setting
In your Notifications settings (see screenshot above right), you now have the option to stay in ''no interruptions'' mode until your next alarm sounds. If you don't see this option immediately, it's because you need to have an alarm set to go off in the next day or so.
10. New Quick Settings and clock animations
Basically every action in the Quick Settings menu now has a new animation attached to it, including the screen auto-rotate animation that debuted in the Android L developer preview but got dropped in Android 5.0. Same goes for turning the flashlight or airplane mode on or off. The clock also has new animations: just tap or swipe between any of the four icons at the top to see some cute new animations to go along with each setting.
AndroidPIT Nexus 5 Android 5 1 quick settings toggle animations
Not so easy to show in pictures, but you can see the little animation on the auto-rotate toggle. / © ANDROIDPIT
11. Progress bars mirror app badge color
When an app is in the process of doing something, Android 5.1 now matches the progress bar color with the badge color of the app in question. A small detail, but nice nonetheless.
12. Change the dialer for the SIM card you use
If you've got a phone with dual-SIM you can now attach a color to each SIM. When you go to make a call you'll be asked which SIM you want o use, and you can set a particular color to the dialer for each SIM.
AndroidPIT Nexus 5 Android 5 0 and 5 1 comparison screen pinning
The screen pinning popup in Android 5.1 vs Android 5.0 (right). / © ANDROIDPIT
13. Screen pinning is clearer
Screen pinning lets you grab an app from the recent apps list and ''pin'' it to the home screeen. This means that you can't back out of that app – it stays on screen until you unpin it. Unpinning seemed to be a little complex for some though, so Android team has made it a little clearer in Android 5.1 Lollipop.
14. No more recurring ''cleared'' apps
You know that annoying bug where cleared apps kept rising from the dead and reappearing in your recent apps list? Yep? Well, it's gone in Android 5.1. Thanks Google.
androidpit recent apps teaser
Cleared apps will now stay cleared and not reappear in your recent apps list. / © ANDROIDPIT
15. One swipe to unlock from lock screen Quick Settings
Previously, if you were in the lock screen Quick Settings menu and swiped up, you would be returned to your lock screen, where you would then have to swipe again to unlock. With Android 5.1 you simply swipe up once and go straight to your home screen (assuming you don't have lock screen security set up).
Have you found anything else in Android 5.1? What are your thoughts so far?
Review: Samsung Galaxy S23+
Review: Samsung Galaxy A54
  • $1,199.99
  • $999.99
  • $1,799.99
  • $1,799.99
  • from $999.99
  • $999.99
  • $699.99
Go to comment (35)
Kris Carlon
Kris Carlon
35 comments
  • Nicole Carstairs 1
    Nicole Carstairs Apr 13, 2016 Link to comment
    I have the s6 edge and just did the update. Before when one of my 'edge people' would text me and I pick up the phone, it vibrates so I know I have a message but then their colour would also pop up (with the screen off) and then you can drag the colour to open the message. It no longer does this... Anyone else having this issue??
    Yogesh Dama Mar 3, 2016 Link to comment
    There are plenty of apps those allows recent apps access in notification, i prefer this one:
    play.google.com/store/apps/details?id=com.bhanu.recentapps
    Dave Masterson Jan 7, 2016 Link to comment
    Just updated my a Note 4 to 5.1.1 and I'm not seeing any of the features you mention in this article. Everything looks the same as it did with 5.0.1
    Danielle Wilson Dec 31, 2015 Link to comment
    I just got a new note 5 and in the settings options its a long list. I cant even go to more and do view as for the other feature. this sucks i wish i stayed on my old note as it had way better features than this android 5.1.1 .. just a sad day ..
    Brittany Glover Dec 4, 2015 Link to comment
    I have the Samsung Galaxy Grand Prime and I like my lollipop upgrade and all, but since I've upgraded, my phone has been pretty glitchy. My screen blacks out and I can't always pull down my drop screen to check the status bar. I've only had this phone for about 5 months and it was perfect for me before I upgraded. Can these problems be fixed??? And if not, is it possible to downgrade???
      Mistersome Dec 5, 2015 Link to comment
      Usually you can get that fixed, let's try two things,
      First try clearing cache. To do that follow link (just Google "how to clear cache on galaxy prime" apparently I can't post link as new user)
      If that does well- your good to go, please let me know,
      if not try factory reseting the phone, however that will delete all your apps and settings, so think how you can back up you settings / apps / info
  • Rizwan Khan 1
    Rizwan Khan Oct 18, 2015 Link to comment
    my home sreen button stops working on note 4 what the hell is this .... can anyone help me please?
    Ahmed Paulo Uwk Oct 5, 2015 Link to comment
    Yas
    Anju Saha Sep 17, 2015 Link to comment
    I deeply regret moving out of Kitkat to Lollipop mainly because I lost what was really excellent in the meetings feature. I have a daily one and a half hour meeting where, in Kitkat, I had set options for all notifications to vibration only. With their “improved” lollipop 5.0 and downtime settings, it has been pre-decided that meetings can only last exactly one hour – or I can set it for two meetings i.e. for two hours – I seem to have lost the option of one and a half hours. Also now the phone does not vibrate when I get a call but beeps out loud when there is a message. Is there a solution in version 5.1?
    The second is that they removed group messaging so if there is a shift in the meeting timings I now cannot send a group message to the members – sending individually meant I sometimes missed a few. Any solution for this here please?
    Because of my bad experience in updating to Lollipop 5.0, I am extremely hesitant in going on to 5.1. Fancy animations are fine but will I lose some more basic and essential features? I use a moto g
    Craig Crisp Sep 10, 2015 Link to comment
    Anyone know how I can disable the star that shows up in the notification area up top/left? I find it very annoying! I'd rather see the app specific icon pop up there so i know which apps have messages (etc mail, text msg)
      Michael A. James Sep 12, 2015 Link to comment
      It's most likely associated with some program that runs in the background; go launcher does that for example - puts its icon in the notification area when it's running. Gotta find which program has a star icon, and uninstall/disable it, or go to application manager and disable notifications for that program.
  • Glenn Cameron 1
    Glenn Cameron Sep 9, 2015 Link to comment
    Got my update last night from 4.1 to 5.1.1
    I have the LG Transpyer . downloaded over WiFi .I have Verizon as my mobile carrier "no contract plan"and I live in Wilmington Nc. Everything working fine so far.
    Sept 9, 2015
    john fox Aug 16, 2015 Link to comment
    My note 4 lost call forwarding and call waiting function on the device when I upgraded. Can't down grade or I void my warranty. Google I want my features back.
      Michael A. James Sep 10, 2015 Link to comment
      You can downgrade and it won't void your warranty. It is rooting that will void it. I've downgraded my Note 4 from 5.0.1 to 4.4.4 after having battery issues, and my Knox counter was still 0x0 afterwards. As long as you're simply re-installing stock official OS (any version), and not actually rooting your device, you're fine.
      Just google "note 4 downgrade lollipop to kit kat"; the process is pretty straightforward. If you want to downgrade from 5.1 to 5.0, the process is exactly the same, just replace 4.4 firmware with 5.0, but the same guide still applies.
    Renee H. Aug 14, 2015 Link to comment
    So...just got the upgrade on my Note 4 through Verizon. Hopefully it fixes the battery issue! We will see!
    Marwan Sherin Aug 9, 2015 Link to comment
    Guys, just upgraded yesterday my Galaxy S6 Edge from 5.0.1 to 5.1.1 (OTA update)
    the auto rotation seems to be fixed now, it was working on the 5.0.1 for a while then stopped out of the blue, 3 days later I upgraded to 5.1.1 and it is working again :)
    Yustinus Suhali Jul 30, 2015 Link to comment
    It happens to my Xperia z2 as well. No app locks work as in android 5.0. But I just tried an app from CM AppLock and it works well.
    Afraz syed Jul 30, 2015 Link to comment
    Updated to android 5.1.1 on my sony xperia z2 , and app locker is not working :(
    No app lock app is working on android 5.1 on my device ,dont know about others
    Kheem Vendiola Jul 30, 2015 Link to comment
    Ive almost installed every single app locker on google play. None of them works. PLEASE HELP ME FIX THIS!! )':
    Jim Wolff Jul 26, 2015 Link to comment
    So disappointing Google! You'd figure instead of playing around with a bunch of useless crap that no one cares about, how about fixing the disconnecting and loss of WiFi every time I get in and out of my car. Or out of range with a wifi device I've already put in my password?
    Ashim Chowdhury Jul 25, 2015 Link to comment
    What's about the app locker?????
    I can't lock any apps after upgrading my motor e (1st Gen) into lollipop....
    What should I do now??????
    No other app locker doesn't supported to this function!!!!!
    Is there any way to lock these apps??????
      Have you found a fix for this? I desperately need to have those app lockers working. )':
    Dale Peterson Jul 24, 2015 Link to comment
    What about the battery drain?
  • Anne Sidell 1
    Anne Sidell Jul 14, 2015 Link to comment
    Last update, my Samsung note4 lost the capability to have different alerts for email and text messaging... a very bad feature.. does anyone know if 5.1 corrects that?
    Patrick Jul 11, 2015 Link to comment
    Ever since updating my S6 on tmobile to 5.1.1, i t now vibrates about every 30 seconds or so for no reason. Any ideas how to correct this?
    Alan Howard-Jones Jun 11, 2015 Link to comment
    I installed 5.1.1 on my Samsung Galaxy S5 the other day and now the small notification icons no longer appear at the top of the lock screen. Ie. SMS, email, etc..
    Is this feature disabled in 5.1.1 or is this just a bug?
    Jacques Payne Jun 5, 2015 Link to comment
    Hey Kris,
    About your post on note of: "12. Change the dialer for the SIM card you use
    If you've got a phone with dual-SIM you can now attach a color to each SIM. When you go to make a call you'll be asked which SIM you want o use, and you can set a particular color to the dialer for each SIM."
    I do understand that you are comparing Android 5.0 with 5.1, however, I found that even with Android 4.2.2 this function was/is available, I am able to change the colours of the SIM cards accordingly as well as I am able to choose which one to be used for Data usage, calling function, SMS and video call. So if you are referring that this is a new function it is not, but if you are referring that it is added back again from 5.0 to 5.1 then it would've been actually kinda stupid of the Android developers to remove it as I believe it is kind of a key function when using Dual SIM.
  • 10
    Douglas Nolan May 17, 2015 Link to comment
    Got Android 5.1.1 on my S4, with Cyanogenmod 12.1..Lovely...!!!
    Ahmad alfaraj Apr 20, 2015 Link to comment
    5.1 update destroyed my nexus 5 ....sound keeps going back n forth hanging most of the time...doesn't vibrate..it was completely perfect with 5.0 update
    Prathamesh Shirodkar Mar 21, 2015 Link to comment
    when will it release in India for moto g 2 gen if anyone known plz let me know
    Monty Siladhiel Mar 11, 2015 Link to comment
    15 new reasons to wait for 5.1 for Moto G (1st Gen.) :)
  • 11
    Stuart Male Mar 10, 2015 Link to comment
    Got the g900i. Ill probably have to wait for the s7 before I can get it. Apple wins with updates.
    • 19
      Moni Mihailov Mar 10, 2015 Link to comment
      Why do you need this update if your phone is working correctly?
      • 11
        Stuart Male Mar 11, 2015 Link to comment
        Why do you upgrade your phone?
      • 19
        Moni Mihailov Mar 11, 2015 Link to comment
        i don't. I'm still in 4.4.2 because everything is amazing.
